1998 v70 t5 build - white reaper - Page 2
    Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 36 to 70 of 150
    1. #36
      Oct 2019
      phoenix, az
      Robert DIY is the man - saving for later.
      Air Filter: https://www.youtube.com/watch?v=PWyUcIHcklY
      Big brakes (302mm): https://www.youtube.com/watch?v=rP3ZqrUOlGw
      Brake fluid: https://www.youtube.com/watch?v=nYBkCfhDTTw
      Brakes (front): https://www.youtube.com/watch?v=oNVbH-88UjI
      Brakes (rear): https://www.youtube.com/watch?v=-ViHE64XlNQ
      Cabin Air Filter: https://www.youtube.com/watch?v=2tZ-0Tm6Ai0
      Car alarm: https://www.youtube.com/watch?v=ImO5uf3J0c0
      Coolant flush: https://www.youtube.com/watch?v=LSvcEYoYNCo
      CV boots: https://www.youtube.com/watch?v=gonWl9mJd_Y
      Cylinder head: https://www.youtube.com/watch?v=4UErzCn-oK4
      Distributor: https://www.youtube.com/watch?v=r_CojfnK6J8
      Engine mounts: https://www.youtube.com/watch?v=azZ6HAjRihk
      Front bumper: https://www.youtube.com/watch?v=cfmfISVFWFg
      Front seat removal: https://www.youtube.com/watch?v=tBmSqHzH4n4
      Front struts: https://www.youtube.com/watch?v=DwpcdidgjbA
      Fuel filter: https://www.youtube.com/watch?v=soG0jIt9znI
      Fuel pump: https://www.youtube.com/watch?v=iKTgvLWzoaM
      Head cleaning: https://www.youtube.com/watch?v=TyoFDrbRVuE
      Headlights: https://www.youtube.com/watch?v=9uMKjVI0UEg
      Heater core: https://www.youtube.com/watch?v=OdKzDfvOoQA
      Key fob: https://www.youtube.com/watch?v=Zzuyp3TUadM
      Lower trans mount: https://www.youtube.com/watch?v=lKMyjSSMznM
      Oil cooler line: https://www.youtube.com/watch?v=r6cJ0qMzby0
      Oil pan: https://www.youtube.com/watch?v=I7HfHowOh7I
      Parking brake: https://www.youtube.com/watch?v=r83sfv2fRwU
      Parts Locator: https://www.youtube.com/watch?v=MCsjHI22-pc
      PCV check: https://www.youtube.com/watch?v=FIRoc0VxLd4
      PCV: https://www.youtube.com/watch?v=eEZzqyu2a6c
      Power steering pump: https://www.youtube.com/watch?v=2_MMB__5TUo
      Power steering rack: https://www.youtube.com/watch?v=7Mz-eSmLY5k
      Pre-purchase inspection: https://www.youtube.com/watch?v=L4g-w4OXeBw
      Radiator: https://www.youtube.com/watch?v=WfAfhwrSuqQ
      Rear main seal: https://www.youtube.com/watch?v=wt_eR0A1SaE
      Rear springs: https://www.youtube.com/watch?v=CHPOR8o2JMA
      Restoration: https://www.youtube.com/watch?v=yDlBfUnvnxU
      Seat back recliner: https://www.youtube.com/watch?v=lGITgKXCBbg
      Serpentine belt: https://www.youtube.com/watch?v=vyoNw8B6QWM
      Skid plate: https://www.youtube.com/watch?v=evVrazUjjgk
      Spark plug wires: https://www.youtube.com/watch?v=fOEHckD8Ra4
      Spark plugs: https://www.youtube.com/watch?v=QdyyDTzFP3k
      Sway Bar End Links: https://www.youtube.com/watch?v=5Z-lKDRWuwQ
      Sway Bars: https://www.youtube.com/watch?v=3YIc0KguPpc
      Thermostat: https://www.youtube.com/watch?v=6dPYItyG0lI
      Throttle body: https://www.youtube.com/watch?v=Zzfvh2oPry4
      Tie rod ends: https://www.youtube.com/watch?v=OA0XStSocdk
      Timing belt: https://www.youtube.com/watch?v=SpNgDfvRcVI
      Transmission fluid: https://www.youtube.com/watch?v=kyM3Z-RWvcw
      Turbo boost gauge: https://www.youtube.com/watch?v=ayLXahapDxE
      Turbo coolant line: https://www.youtube.com/watch?v=SGilWieCnOQ
      Turbo lines: https://www.youtube.com/watch?v=x8sXo5gbapM
      Turbo: https://www.youtube.com/watch?v=hfUfFbWdzoU
      Vacuum Line (NA): https://www.youtube.com/watch?v=dKk-KHl2b5k
      Vacuum Lines (turbo): https://www.youtube.com/watch?v=dUDSgUsSwmU
      Valve cover: https://www.youtube.com/watch?v=pYuszsm9v1c
      Water pump: https://www.youtube.com/watch?v=-U9LRBia73k
      Windshield washer pump: https://www.youtube.com/watch?v=gE6k8Jk1pSk
      Wiper Motor: https://www.youtube.com/watch?v=VGxyj0UTDp4
      1998 V70 T5 - Arctic White/Beige - AW42 - 169K
      Oct 2019
      phoenix, az
      is there an alternate solution to fixing up the battery cables/terminals other than replacing? (oem ~$200 for both cables). i suppose the cables are still good, really just the ends/terminals that are in rough shape...
    4. #38
      Jun 2012
      Tidewater, VA
      FCP has a universal “Repair Terminal - Genuine Volvo 30656679” for $3.40 that allegedly will fit, but there’s no picture for it. I’d send them an email to confirm. https://www.fcpeuro.com/products/rep...l-30656679-1-1
      If you need to go with replacing the cables, it looks like AutohausAZ has OEM cables for around $56: https://www.autohausaz.com/pn/OE-9456836
      BD
      Current Fleet:
      1998 S70 Base (New project), 2006 S40 T5 M66 FWD, 2008 C70 Premium Plus M66, 2011 XC90 V8, 2013 C70 Platinum P*
      RIP:
      1994 854T FWD, 2004 XC90 2.5T AWD, 2005 S60 2.5T FWD
      Oct 2019
      phoenix, az
      found a picture of the "repair terminal" on eEuro, and i have no idea what that actually is ?
      https://www.eeuroparts.com/Parts/437...inal-30656679/
      any reason why i couldn't use a (gasp) universal battery terminal connector in this case? having a hard time finding just the connectors and would prefer not to replace the cables. guess i could hit up pick-n-pull
    7. #40
      Oct 2019
      phoenix, az
      Pulled the coolant reservoir, gonna need to replace that because it is in bad shape. Trying to remove the ecu housing box and got stuck.. Can't figure out how to get it loose. It looks like just some clips but i don't understand how it come apart. Any suggestions?
    8. #41
      Oct 2019
      phoenix, az
      Also does anyone know what the insulated pipe is called that goes from the ecu housing to the firewall? Ecu lower pipe duct?? Mine looks kinda crappy but I'm guessing it's just the insulation, the pipe itself may be fine.
    9. #42
      May 2014
      You are correct and seeing everything, it is just the clips. They are just a bit longer travel than you might generally expect and there is a separate 'sleeve' between the bottom in the pic and the lid. The sections are fit pretty tight even without the clips. The upper part of the w/washer reserve just pulls off and will make it a bit easier. Take that off. There is a filter accessible there when you do that you might clean. You'd never know it was there, it just pulls out. Here's a pic:
    10. #43
      Oct 2019
      phoenix, az
      this is a big help - thank you!
    11. #44
      Oct 2019
      phoenix, az
      The ecu housing is still giving me a hell of a time... Decided to take a break from that and start on the brakes. From one problem to the next. Looks like the PO stripped the nuts on the hard lines. Any suggestions?? I know everyone upgrades the hoses to stainless steel, but how much are replacement hard lines? With the lip at the end you can't just replace the nut..
    12. #45
      Oct 2019
      phoenix, az
      Looks like i would need 2 & 14. Driver front & passenger rear. The other two finally came off.
    13. #46
      Dec 2015
      SLC Utah
      Vise grips ? Theoretically they shouldn't be that hard to get off even if stripped
      01 S60 T5M Black, middle sons
      00 S70 GLT Black, youngest sons
      01 E46 325 XI Touring Silver, Wifes, totalled, bought back, repaired
      00 S70 GLT5 SE Moondisaster, T5 Swap, MINE !
    14. #47
      Quote Originally Posted by gr1m_reaper View Post
      Good jy item. The trick is to apply a sharp force so it shocks the nut not slow pressure that bends the monel. Couple heat cycles is good insurance too
    15. #48
      Oct 2019
      phoenix, az
      what brand ATF do y'all use? going to do a drain/refill on the trans
    16. #49
      Mopar atf 4. I get a good deal on it, it’s classic red atf but full synthetic at $2 a quart. Been running it in 4 cars for at least 200k combined miles (74k on my own personal t5a) without a single issue. I’m draining and filling every 10k or alternating oil change interval.
    17. #50
      Oct 2019
      phoenix, az
      $2 a quart?? where can i get a deal like that ??
    18. #51
      Oct 2019
      phoenix, az
      while we're on the fluid subject - can you please help me understand which engine oil viscosity i should be using in Arizona?
    19. #52
      0w40 hits all the specs and temp range you’d see.
    20. #53
      Oct 2019
      phoenix, az
      Replacing the PCV today... Definitely harder than i thought. Getting the manifold off was extremely difficult for me. Hard to get my big arms underneath to get those two pesky bolts. Also highly recommend ratcheting wrenches for this task!
      Got it all installed, just putting it back together now. But something seems to be in the way of setting the manifold back in all the way. Any ideas?
    21. #54
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      maybe you reinstalled the bracket too high?
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 297k.
      1997 850R Estate. B5234T9/M66D. Bright Red/Graphite. 280k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 141k.
      Instagram: Jared's Volvo Page
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 101k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    22. #55
      Oct 2019
      phoenix, az
      Yep - didnt realize the bracket underneath was adjustable. After literally checking everything else, i noticed i had thr bracket on the higher end, so moved it down and it fit perfectly. Sometimes its the littlest things that throw you off!
    23. #56
      Jan 2014
      Boston, MA
      You don't really even need that bracket. The ME7 cars don't have it from the factory and those have an ETM hanging off of them.
    24. #57
      Oct 2019
      phoenix, az
      Next dilemma - i was about to reinstall the fuel injectors when i noticed one tip was not like the rest. If you look closely you can see the little plastic red piece appears to be broken. What is this and what do i need to do about it?
    25. #58
      Dec 2015
      SLC Utah
      I believe they are called Pintels. I have on like that on the S60. Dosen't seem to be causing issues for me.
    26. #59
      Oct 2019
      phoenix, az
      i found a bosch fuel injector rebuild kit online. it was cheap enough to check it out, so i ordered it. might as well try to repair the injector while i still have the fuel rail off. also, i noticed the PCV kit i got only had enough seals for one per injector. do the top seals need to be replaced or is it not as important as the bottom seals??
    27. #60
      Dec 2015
      SLC Utah
      If your bosch kit comes with 10 orings i would use those instead of the ones that came with the kit. If not i would order another five orings since your rebuilding the injectors
    28. #61
      Oct 2019
      phoenix, az
      well i'm basically convinced the PO super-glued and/or welded the hard line bolt on the rear left brake caliper... i've attempted every trick in the book to get it out, and now it's just a bolt with no head remaining and a hole drilled thru it. -___- what does one do at this point? i suppose i could continue drilling out the remaining bolt, clean out any shavings that fell down into the piston, and examine the threads to see if a new bolt would not leak. i don't feel super great about this option, so i'll probably end up just buying a new caliper. i just wanted to avoid the purchase for now so i could replace all four calipers at the same time.
    29. #62
      Jan 2014
      Boston, MA
      just get a new caliper; probably needs a refresh, anyway. paint it before you put it on.
    30. #63
      Oct 2019
      phoenix, az
      and i don't even want to get started on the fact that some of the fittings are 8mm, 10mm, 11mm, 12mm, 14mm, and 15mm....
    31. #64
      Oct 2019
      phoenix, az
      do the original rear calipers have 10mm or 11mm fittings? i believe the fronts are 10mm, but the rears currently on the car have 11mm, and both options are available to purchase. do i just buy 11mm again since that is what the rear right has, or does it even matter?
    32. #65
      Jan 2014
      Boston, MA
      Get what's already on the car, or get the correct PN from VIDA if unsure.
    33. #66
      Oct 2019
      phoenix, az
      Hey what's your opinions on a salvage title car? Looking at adding another project, but hesistant to pull the trigger. I'm guessing it wouldn't take much for an insurance company total out a 25 year old car. If it's just body damage, is it worth fixing up? Will future buyers pass on a V70R that's fixed up right but comes with salvage/rebuilt title? Or would you just use it as a parts car?
    34. #67
      Jan 2014
      Boston, MA
      Depends entirely on what the damage is and what the legal requirements and insurance regulations are in your jurisdiction for salvage title cars. A salvage title car will always be worth less than a car with a clean title of equivalent condition.
    35. #68
      Oct 2019
      phoenix, az
      i don't know how y'all spend all this time working on cars AND taking pictures AND posting excellent write-ups!! i'm having a hard enough time getting the work done that i forget to take pictures and write-up what i do. i'd like to do better at that so i have a good log of everything i've done.
      recent purchases:
      *replacement rear-left caliper (destroyed the flare nut to the point of no return)
      *replacement flare nuts and bleeder screws all around (not easy to track down)
      *bubble flaring kit
      *pcv kit
      *oil filler cap gasket
      *cabin air filter
      *k&n air intake
      *brake rotors/pads
      *magnetic oil drain plug
      *bosch distributor rotor/cap
      *bougicord spark plug wires
      *genuine volvo spark plugs
      *fuel filter
      *genuine volvo thermostat
      *aisin water pump w/new bolts
      *bosch parking brake shoes & new hardware
      *ecu air duct cooling hose
      *coolant expansion tank w/new hoses
      *contitech serpentine belt
      *contitech timing belt
      *timing belt tensioner/pulley
      *ATE brake hardware (rear)
      *steel brake lines (front)
      *oil line gaskets
      *turbo inlet/outlet hoses
      *throttle cable
      *volvo coolant
      *redline rear diff oil
      *ATE typ 200 brake fluid
      *tcv silicone hoses
      *sylvania ultrastar h7 headlight bulbs
      *fuel injector rebuild kit
      work done to this point:
      *replaced pcv system
      *replaced spark plugs/wires
      *removed all brake calipers/rotors (had to cut a couple of the lines)
      *painted calipers gloss black
      *removed fuel injectors for cleaning
      *replaced upper/lower radiator hoses
      *removed throttle cable
      wow, when i type it out it doesn't seem like i have done very much yet! this weekend i will be refreshing the fuel injectors, installing the k&n intake, replacing serp belt, installing coolant tank, replacing water pump, installing thermostat, installing headlight bulbs, replacing the and finishing up the brakes and adding fresh fluid.
      will try to take more pictures!
    36. #69
      Jan 2014
      Boston, MA
      Looks pretty good. What brand coolant tank and timing belt tensioner/idler? Conti belts not recommended....Continental has admitted that there are counterfeit belts out there. Only Genuine Volvo or Gates belts for me.
      I'd look at the LED headlight bulbs. And grab some ECE lenses while you're at it.
      What's the rear diff oil for
    37. #70
      Oct 2019
      phoenix, az
      Just making sure people are actually reading this! Haha jk the rear diff oil is for the wife's Expedition. Was just listing items from my order sheet without paying attention.
      You think FCP could be selling counterfeit belts?? I would think they got their products directly from the manufacturers.
      And as much as I would love to put genuine volvo parts on everything - my skill level and budget for this project don't really justify it (yet). I know the purists will disagree, but hopefully this all goes smoothly and i can step it up with a V70R next.
    1. Replies: 17
      Last Post: 10-04-2013, 12:14 AM
    2. 1998 V70 T5 auto. White with charcoal interior Powhatan, VA
      By slo2gdsm in forum FWD & AWD Cars For Sale
      Last Post: 07-15-2012, 01:36 PM
    3. Converting a 1998 V70 awd GL (automatic) to a 1998 V70 T5 (manual)
      By 300zx in forum S70, V70 & V70XC (1998-2000)
      Last Post: 02-27-2009, 10:47 AM
    4. 1998 V70 T5 5 speed White/Tan
      By JRL in forum FWD & AWD Cars For Sale
      Last Post: 02-28-2008, 06:02 PM
    5. 1998 VW Conv. white/white edition, 5 speed
      By JRL in forum Non-Volvo Cars For Sale
      Last Post: 04-10-2007, 04:30 PM
