SIM Cards, LTE and Compatibility (And Google Fi!?)
    Results 1 to 24 of 24
      Junior Member mattlach's Avatar
      Jun 2013
      Boston, MA
      Hey all,
      Who on here has replaced the included Volvo AT&T sim card with one for their own carrier?
      The AT&T card I got with the car always gave me pretty low signal strength and slow speeds, no matter where I was. That, and because my wireless carrier (Google Fi) gives me free data only SIM's for use with my non-primary phone devices, I figured I'd give that a try rather than pay for yet another service.
      First issue:
      1.) SIM card from Google is too small. No worries. This is a common issue and they sell adapter trays.
      2.) Even the contact surface on the SIM card seems different. The included AT&T card has a bigger electronic contact surface, with four contact pads across, whereas the Google Sim is smaller with fewer contact pads. Anyone know if this is an issue?
      fig. 1: AT&T Card on Left. Google Fi Card (In black adapter) on right
      Second issue:
      So I looked up sim cards in the Manual, and found that the SIM card holder is in the trunk just behind the seats. In the manual it's pictured with some sort of door to access the holder, but my car does not have this door. I have to take the entire cover that covers the spare tire out to reach it.
      fig. 2: Trunk
      fig. 3: Trunk, cover removed
      fig. 4: Sim card holder
      Once I found it, the SIM card holder pulls out to the left, you can pop out the old AT&T card and pop in the new one.
      First several tries this did not work at all.
      That is when I realized that in their wizdom, Volvo installed the sim card holder such that the contact pins face DOWN. Which means, as you try to insert it, these smaller SIM's in the adapters fall out of the holder as you are inserting them.
      A little double sided tape was needed to get them to stick, and in it went, and success, the car detected the SIM card.
      The instructions that came with the SIM card said that Google FI requires you to set your APN to "h2g2". with the "Automatically Detect" checkbox enabled, it seemed to work, but just to dot my I's and cross my T's I manually entered h2g2 as below:
      fig. 5: APN Configuration Screen. Neither I nor the Google Support people know what the Username and Password fields are for
      NOW WITH THE PREAMBLE DONE, ON TO THE REAL PROBLEM:
      The SIM Card worked, at least at first. Signal strength is MUCH better than with the AT&T card that came with the car. I even max out full bars on a regular basis. It is often slow though. For instance, starting the Sensus Spotify app after turning on the car is VERY VERY slow. It can often take 5 minutes or more to even get to the point where it displays "my library" and I can select what to play. 5 minutes may not seem like much, but if you are running errands and stopping in many places, you often arrive at your next stop before the music has even started, which is kind of dumb.
      At first I chucked it up to Sensus just being its slow like molasses self. I don't understand how my $80 tablet can wake up in a fraction of a second, but the screen in my $50k car takes FOREVER to load on startup. But today, things took a turn for the worse, and I suspect it is the network connectivity which is causing these issues, not the slowness of Sensus.
      Driving to brunch this morning, things were working better than usual. I was playing Spotify, it only took a couple of minutes to get started this time which was great. My stepson was in the back seat enjoying the cars WiFi hotspot playing some silly online game on his iPad. He even marveled that the "ping" was pretty good in the car.
      Then on the way home things just got worse. Signal strength (as measured by the number of bars) was still good, but everything crept to a standstill. His wifi access point was not doing what he wanted it to, and Spotify? Well Spotify did this:
      I appreciate any and all suggestions! I contacted Google Fi support, and to their credit they were helpful, but in th eend they said they couldn't solve it, and gave me a list of supported devices (which Volvo (or any car for that matter) was not on. I get that. They can not be the experts on every LTE device that takes a sim card out there.
      So, I turn to you dear forum. Has anyone else used their own SIM card in the car? Anyone used Google Fi?
      Did you do anything differently than I did? Any special configurations that I may have missed?
      Does the difference in contact surface of the SIM cards have any impact?
      Does Spotify work well for you? Does it load fast?
      Does anyone know which LTE bands our cars support? This information does not appear to be in the Volvo user manual.
      --Matt
      Member skywolf's Avatar
      Sep 2012
      Marietta, GA
      Wow, great post.
      Iíve not even thought about swapping out the SIM card.
      So with my current ATT service or when the car is using my phone Spotify always takes a while to load. However it doesnít do what yours is doing there and it doesnít take 5 minutes.
      I think most of your issue is probably sensus itself. I have a 2018 V90 and the sensus is just terrible when itís booting or starting an application. Some of that can be mitigated by not installing a lot of apps.
      I had a 2019 XC90 and the sensus in there booted up extremely fast and Spotify connected quickly. Hence why I think a lot of your issue is likely just sensus.
      I think your 17 S90 and my 18 V90 share the same crapshoot of a processor. Volvo probably realized this and upgraded it in the newer years.
      2006 XC70 75k - Ruby Red/Graphite - "Wichita" | 2011 Tacoma 14k - Green/Sand - "Timber"
      2007 XC70 64k - Black Stone/Graphite - "Springfield" | 2017 Miata RF GT 5k - Grey/Black
      2020 V90 Cross Country 1.5K - Osmium Gray/Maroon Brown
      Previous: 1997 Dodge Intrepid | 2002 Saturn | 2009 Jetta | 2011 Mazda3 | 2011 Outback | 1993 Miata | 2013 XC70 | 2005 XC70 | 2005 V70 | 2007 XC70 | 2010 Odyssey | 2006 V70R | 1990 740 | 2019 XC90 | 2019 BMW 440i | 2018 V90CC
      Jun 2017
      Chicagoland
      I use a Fi sim in my car. It's normally 30-90 seconds after I turn on the car to when Spotify streaming starts.
      Jun 2013
      Boston, MA
      Quote Originally Posted by skywolf View Post
      Yeah, I suspect that was the issue before yesterday that explains the few minute wait to get into Spotify.
      Not sure what was going on yesterday when nothing would load at all.
      Kind of frustrating that I've just bought a car, and this is already bothering me. I plan on holding on to this car for at least 5 years. I picture this being a constant source of frustration over that time.
      I wonder if it is possible to upgrade the Sensus module to the one used in the later model cars... Or better yet, maybe the new Android based one from the new all electric XC40
      I was actually looking at a 2019 model year first, but decided against it because I didn't like the longer wheel base.
      Jun 2013
      Boston, MA
      Quote Originally Posted by mandrsn1 View Post
      Thanks for the input. What year model is yours?
      Jun 2017
      Chicagoland
      Quote Originally Posted by mattlach View Post
      2018
      Jun 2013
      Boston, MA
      So,
      It seems to have been a temporary issue. It's back to working again today. Still slow though.
      I tried removing some apps I don't use. Not sure that sped it up at all.
      Guess I'm just going to have to save the Spotify app for when I do longer drives, because around town it just takes too long to come online for it to make sense
      Jun 2015
      NYC
      sensus seems to still be a slow start. Same as my 2015 S60 was, so's the '18 S90.
      Interesting thought to change out the SIM. But it seems ATT and T-Mo have complimented each others coverage.
      Except in the wilds of far eastern Canada where nothing worked.
      Apr 2019
      St. Paul, MN
      Keeping an eye on this. Currrently waiting for our V90CC to arrive from our OSD trip and plan on putting our Fi Data SIM in the car when it gets here. Will let you know what kind of results I get.
      Built in modem is a 3g . model SIm card will not matter.
      The modem in your car is 3G it does not matter if you put in an LTE SIM you will not get LTE speeds.
      "I don't understand how my $80 tablet can wake up in a fraction of a second, but the screen in my $50k car takes FOREVER to load on startup."
      Because the $80 tablet has a significantly faster processor. Something Volvo has remedied in their new cars and they boot much faster.
      VOC / Connectivity Expert
      Mar 2017
      Quote Originally Posted by Yes!ItsaVolvo! View Post
      All 2017+ SPA cars come with a 4G LTE modem.
      Any comments made are of my own opinion and not that of my employer!
      Apr 2019
      Decatur, GA
      One of these days I'm going to remember to go out there and try my TMO SIM from my phone. If it works as I am kinda thinking it will, i'll add the $20 plan to my existing plan and go that route. I'd rather not pay AT&T another dime if I don't have to.
      Las Vegas / Philadelphia
      Quote Originally Posted by ManBearPig View Post
      I grabbed a TMO SIM for $10/month @ 2GB to test and I through the ATT sim out within 48hr. I actually get signal and data actually works when using the TMO one. ATT one here never worked at all and was constantly a headache for me.
      2005 Toyota 4Runner v8 4x4 Sport | Icon Stage 2 Suspension
      2019 S90 T6 Inscription | Black w/Blond Interior | ALL Packages | Polestar Performance
      Apr 2019
      St. Paul, MN
      Resurrecting an older thread here...
      Finally got around to installing my Google Fi data SIM in our V90CC. Thanks to the tips from mattlach, I used a dab of Elmers glue to hold the Fi SIM in the adapter and it went in easily. I left the network config set to Auto, and it was working within about 30 seconds.
      Data speeds are good, and the signal (mostly) tracks with my phone signal. I'm assuming that when they show different signal strengths, my phone has hopped onto a Sprint tower and the Data SIM is still on TMO.
      Jun 2013
      Boston, MA
      Quote Originally Posted by mcmatt View Post
      I'm glad it helped!
      I have been liking my Fi SIM in my car. The signal and data speeds seem good most of the time. The sensus unit is dreadfully slow at times through, especially at startup.
      I heard they improved things in 2019. I wonder if the unit us upgradeable to the newer model.
      Apr 2019
      St. Paul, MN
      I'm glad it helped!
      I'm not sure if the earlier systems are upgradeable, but I can say that the system in our 2020 is pretty responsive. Once I'm pulled out of the garage, it's snappy and I have no real complaints over using Sensus.
      Oct 2018
      Pittsburgh
      Resurrecting an old thread. Replaced my ATT SIM card with one from T-Mobile. Immediately work! No configuration and seems a little faster.
      I am now free from ATT. T-Mobile cost $10 per every 2 gigs(I am a T-Mobile subscriber). The card is the same size as ATT so no adapter needed.
      My car is a V90CC 2017
      Jan 2016
      NoVA
      I also replaced the AT&T sim with a Tmobile SIM. Its was straight plug and play and works fine. I took advantage of the recent Tmobile offer of a free line which they have periodically. I now have a total of 5 lines for my family. It has unlimited data and 12gb hotspot data/month which I will now rarely use. It has an active phone number which I will also never use since I will use my regular mobile phone number. I used to automatically turn on the hotspot using Tasker and connect the car to that for internet access but now with the Tmobile sim I don't even need to do that. All this at zero additional cost.
      Quote Originally Posted by Dzeldauf View Post
      2018 V90 T5 R Design FWD | Bursting Blue / Charcoal, Full Napa Leather | 20" R Design Diamond Cut wheels | Convenience Package | Laminated Glass | Heated Seats/Steering Wheel | HUD | Powered Load Cover | Mud Flaps | Rubber Floor Mats | Polestar Optimization
      Jan 2014
      Arkansas, USA
      I going to ask a stupid question...and Iím an S90 owner: What is this for? We set up our car to use our phones data (unlimited) through Bluetooth. Is this for something different, or just a dedicated data SIM to accomplish the same thing?
      2014 BMW 335i M-Sport/6MT
      2014 Volvo XC60 R-Design
      2018 Audi S4
      2020 Volvo S90 R-Design/Polestar
      Dec 2017
      PNW
      Quote Originally Posted by AudiA4 View Post
      It is data SIM for apps and can set up a hotspot. The AT&T plan for it is relatively cheap, about $25/month. Useful and convenient if you don't have a data plan on phone.
      Running to retire, 2000 V70XC 237240 miles [2020-07]
      May 2020
      I'm having trouble setting up the Tmobile sim. What steps did you take to get it to work?
      Oct 2018
      Pittsburgh
      Sorry to here that. I didnít have to do anything other the replace the ATT card. I started up immediately. I would try going into network setting and check the automatic box. I hope this helps.
      Jan 2016
      NoVA
      Yes, that's all I had to do also.
      May 2020
      Thanks. the issue was on T-Mobile's end. they didn't have the sim setup for data. all good now.
    27. Remove Advertisements
    1. swap the ATT SIM out and replace with T-mobile SIM?
      By sleon in forum XC60 (SPA: 2018- )
      Last Post: 08-14-2019, 09:09 PM
    2. Google Fi Data Sim
      By regnirpsj in forum XC60 (SPA: 2018- )
      Last Post: 02-18-2019, 06:28 AM
    3. Replies: 23
      Last Post: 05-07-2016, 04:19 PM
    4. Replies: 17
      Last Post: 04-21-2016, 08:47 PM
    5. FI-SI-CO... FI-SI-CO... FI-SI-CO...!!!
      By JoeLvo in forum Motorsport Forum
      Last Post: 09-05-2009, 02:30 AM
