Transmission drain/fill - Page 2
    Page 2 of 2 FirstFirst 1 2
    Results 36 to 39 of 39
    1. #36
      Junior Member Azlkk's Avatar
      Jan 2013
      Phoenix, AZ
      Quote Originally Posted by mdmd View Post
      Can you tell us which is the corresponding PID for that?
      I've been unable to find a PID that reflects ATF temperature, only engine coolant.
      The iPhone is Car Scanner Pro and I use a Veepeak BT dongle. The app has all sorts of parameters including 0-60 times.
      Volvo: 2015.5 XC60 RD Plat. arrest-me red w/ Climate, BLIS & OEM trailer hitch. Koni Special Active struts/shocks, IPD skid plate & rear sway bar
      Others: 2019 Merc AMG E53 Cpe, 1988 Merc 560SL, 1969 MGB GT, 1957 MG ZB Magnette, 1953 MG TD & 1935 Ford 5W Dlx Cpe
      Dec 2019
      Quote Originally Posted by Iamhives View Post
      Good info. I'm interested in this also and haven't yet heard of anyone doing it - so you may be the trailblazer here!
      When you do do it, it would be great if you were good enough to take the time and document via photos/video in order to help the people and community here. As the SPA platform ages and cars go out of warranty, we need as a group to start expanding the library of DIY instructions similar to what exists for older models of Volvo (probably not as extensjve perhaps due to over reliance on software/VIDA but hopefully useful nonetheless)
      Sent from my LG-H932 using Tapatalk
      I'm happy to do a write up if I get time to do it.
      My only concern now is the o-rings. Should they technically be replaced as you would when replacing the oil filter when doing an oil change on the engine?
      I can find the o ring for the small T40 screw but nothing for the main drain plug.
      Any advise would be appreciated.
    4. #38
      Jan 2016
      NoVA
      What is the diameter of the drain plug?
      2018 V90 T5 R Design FWD | Bursting Blue / Charcoal, Full Napa Leather | 20" R Design Diamond Cut wheels | Convenience Package | Laminated Glass | Heated Seats/Steering Wheel | HUD | Powered Load Cover | Mud Flaps | Rubber Floor Mats | Polestar Optimization
      Dec 2019
      Not sure on the diameter, I obviously don't want to unscrew it Looks like it's the same as the previous XC90 drain plug but the main difference is that they have moved from the crush washer to o-ring.
      I'm just a little concerned if I do change the oil and then get a leak because I didn't replace the o-ring
    7. Remove Advertisements
    1. HELP! - Coolant drain/fill - WHERE IS THE RADIATOR DRAIN VALVE???
      By soundquest in forum XC90 (SPA: 2016 - )
      Last Post: 07-27-2019, 04:14 PM
    2. M66 Transmission Fill/Drain Bolt Tool
      By briancpearce in forum Miscellaneous Classifieds
      Last Post: 02-10-2012, 07:16 AM
    3. T6 trans fluid drain & fill - from where to drain?
      By 04xc7090 in forum XC90 (2003 - 2014)
      Last Post: 05-06-2007, 10:07 PM
    4. Drain & Fill vs. Flush for transmission?
      By ncS60 in forum S60 (2001-2010)
      Last Post: 03-28-2007, 05:21 PM
