Transmission drain/fill
    Page 1 of 2 1 2 LastLast
    Results 1 to 35 of 48
      Jan 2016
      NoVA
      Anyone done a drain and fill of the transmission yet?
      (Lets not get into the discussion of lifetime fluid/fluid doesn't need to be changed or the confusion of flush vs drain/fill)
      If yes, more questions!
      What fluid?
      What volume drains out?
      Where is the drain plug?
      Where is the fill plug?
      Is there a transmission level dipstick/level?
      Is there a serviceable filter? (doubtful)
      I've had some car with transmission problems due to self serving manufacturers selling the 'lifetime fluid" BS and have had others where I wised up and changed the fluid (drain fill) every 30-50k and then had not problems - so I will be doing regular drain/fills on my SPA cars.
      2018 V90 T5 R Design FWD | Bursting Blue / Charcoal, Full Napa Leather | 20" R Design Diamond Cut wheels | Convenience Package | Laminated Glass | Heated Seats/Steering Wheel | HUD | Powered Load Cover | Mud Flaps | Rubber Floor Mats | Polestar Optimization
      subscribed for additional info. Curious as well.
      Dec 2018
      Vancouver BC
      One source of info
      Quote Originally Posted by Iamhives View Post
      What fluid?
      Go to Youtube and search XC90 transmission . There are a couple of videos that walk you thru the whole process . The drain plug is under car which also has imbedded in it the tube which sets the correct amount of fluid .Volvo in it's infinite wisdom does not provide us with a dipstick . [ another life annuity for the dealer ] Fill plug is under the air filter plumbing . You will need correct Torx socket and a extension. No filter required.. Valvoline Synthetic ATF withstands higher temps than Mobil 3309
      Jan 2016
      NoVA
      I don't seem anything on Youtube for SPA platform cars - all the videos I see are for much older XC90's which are a whole different platform. If I'm wrong please post the specific link to the transmission videos for the newer SPA platform cars.
      Quote Originally Posted by sventhexc90 View Post
      Apr 2018
      I am also looking for a video on YouTube for my 2016 XC90. As you said there’s no video for the second generation of xc90. But I saw at least one old video which is similar to the current transmission. As long as transmission make/ model is the same, it should be good enough to be used for new xc90. But I can’t find the filler bolt on the top of transmission.
      Jan 2016
      NoVA
      Since there arent any SPA specific videos that any of us can find, what other cars use the same transmission - there may be information we can leverage from them. What transmission model/number do our cars use?
      Sent from my LG-H932 using Tapatalk
      Dec 2018
      Earth
      Jan 2016
      NoVA
      Looks like this is the transmission our cars us:
      https://en.m.wikipedia.org/wiki/AWF8F35
      We can probably learn from other cars that use the same transmission...
      Oct 2017
      I think you'd want to either do a power flush or at least 3 rounds of drain/fill with some driving in-between each round to properly change the tranny fluid.
      Doubt you are going to find any tranny how-to's specific for SPA XC90 for at least another year or three, the car is just too new for people to bother with this fluid, and especially to go DIY and document this with pics or videos.
      Apr 2018
      This link tells us the details about the transmission used for XC90.
      https://youtu.be/Ehgwf_C5zgY
      Apr 2018
      Just wondering if the transmission fluid has to be replaced or not when replacing the engine? My engine has been replaced. I don’t know if the transmission fluid was replaced or not.
      Jan 2016
      NoVA
      Quote Originally Posted by Vetallist View Post
      I plan on doing 3x drain and fills every 30/50k miles or so. Power flush is typically not recommended by most people (although this tends to be a debated topic) but this probably applies to high mileage/dirty fluid since its stirs up the crud and may block passages. May not be so much of a worry if the fluid is kept pretty clean but I still plan on drain/fill vs power flush.
      Anyone know where the transmission fill is? Is there a dipstick (doubtfull)?
      Member drmanny3's Avatar
      Santa Barbara, CA, USA
      Quote Originally Posted by goooglemen View Post
      That is one complex transmission. It is amazing to me how complex these transmission are today. I imagine the tolerances are something else given all the machined parts and gears that go into the unit.
      2017 Acura NSX Nouvelle Blue Pearl, Ceramic Brakes
      2017 XC90 T8 Inscription Onyx Black, BW, Leather Dash, Convenience, Vision, Luxury, Air Suspension, Climate, 21" Wheels
      2017 Bolt Premium Red
      2015 Kia Soul EV+
      2015 Toyota Highlander Hybrid
      2014 Toyota Rav4EV (one of 2600 compliance California only cars)
      2011 Nissan Leaf
      2005, 2006 Prius
      5 Corvettes, Porsche 911, Fairlady, 3 Z Cars, Countless VWs from Bugs to Vans, to Fastbacks, and Squareback
      Buicks, Chevys, Fords,
      Jan 2016
      NoVA
      Yes, lots of tight tolerances that require clean fluid and not the black, worn out fluid to function properly which is what we'll all have after 50k miles.
      Looks like there are a couple of potential fill plugs on the top (are they accessible in the Volvo version TG-81SC/installation?) and the video notes that the factory fill plugs need to be replaced and an o-ring added if they are removed. Also looks like the drain plug can act as the fill plug (thru the smaller center 'straw') - see 4:16 in the video. Also, a close-up and discussion of the drain plug is mentioned in the link here..
      So looks like we could use the 'straw' in the drain plug to add fluid if necessary and it's self leveling if the transmission/fluid is at the correct temperature (it overflows thru the central hole). Question is how does one monitor the temperature without VIDA. I have a BMW where people have have developed a 'procedure' (x minutes idle at y degrees ambient temp. with various shifts thru the gears to approximate the correct temperature) but obviously not as accurate as using the diagnostic software. The easiest thing would be to collect and measure exactly what comes out when drained and refill with exactly the same amount which is what I do on my old Volvo's (V70 etc). As you can tell I'm a DIYer..
      Quote Originally Posted by drmanny3 View Post
      Dec 2019
      Has anyone tried doing a drain and fill yet? Our XC90 is at 42,000 miles and think it's a good time to do it as we are planning on keeping this car for a long time...plus we are towing with it.
      I was planning on draining the transmission when it's cold, measuring the amount that came out and then fill the with exactly what I drained.
      I was also looking to fill it with Toyota WS ATF as this is what was mentioned on the Youtube video mentioned above.
      Volvo won't supply me any because it's "sealed for life" which is utter rubbish.
      Does anyone think this procedure will cause any problems?
      Nov 2019
      Prosper, TX
      Quote Originally Posted by tomyoud View Post
      Ours is around the same mileage. I really want to do this on ours. I need to pull the air filter and see if I can find any of those fill plugs that he shows in the video. If so, I don't see any issues opening a fill plug, pulling the drain plug and measuring what comes out and replacing it with new fluid. I would LOVE to hear from someone who has done it already though!
      2017 XC90 T6 AWD Inscription with Polestar optimization
      Jan 2016
      NoVA
      I don't think there is any danger (an lots of upside) in doing this as long as you're careful to collect and measure what comes out. I plan on filling through the (center of) the drain plug (as strange as that sounds) with a hand pump and narrow tube. This is a nice design in that its self leveling if you have access to the fluid temperature but refilling what comes out is the simpler method.
      Regarding alternative ATF fluids there's a long list at the following link:
      https://www.tacomaworld.com/threads/...-fluid.373083/
      I can't verify whether this is a valid list or not. Toyota WS seems more mainstream and probably easier to get. It looks like Toyota WS is $9.50 /quart on Amazon.
      Dec 2019
      Quote Originally Posted by BriDroid View Post
      I've already taken out the Air box to investigate where the fill plug is. It's a T55 torx pretty much directly under the air box...next to the control module, you do need to unplug the MAF sensor too.
      What are peoples thought about not replacing the o-rings? I'm just concious it could potentially leak?
      I'd also like to hear from anyone who has done it...but I'm planning on doing it after the Christmas period.
      Jan 2016
      NoVA
      Good info. I'm interested in this also and haven't yet heard of anyone doing it - so you may be the trailblazer here!
      When you do do it, it would be great if you were good enough to take the time and document via photos/video in order to help the people and community here. As the SPA platform ages and cars go out of warranty, we need as a group to start expanding the library of DIY instructions similar to what exists for older models of Volvo (probably not as extensjve perhaps due to over reliance on software/VIDA but hopefully useful nonetheless)
      Dec 2017
      PNW
      So if the drain plug is hollow like described, filling up is really easy, just fill till it overflows out from the hollow drain plug hole.
      No need to measure how much is drained.
      Running to retire, 2000 V70XC 237240 miles [2020-07]
      Jan 2016
      NoVA
      Agree in general regarding the combined drain/level plug but I believe the challenge is the level/overflow needs to be at a specific fluid temperature as determined by VIDA. Since we DIYers don't easily have access to VIDA I think it's still safer to replace the volume that comes out with the same amount of clean fluid which depending on the temperature may/may not be the same as the overflow point. I would think filling to overflowing of the drain plug at room temperature would be overfilled at operating temperature due to expansion of the fluid.
      Dec 2018
      "sealed for like" aka after warranty expires
      2019 XC90 T6 Inscription, Denim Blue/Brown Leather, Advanced Package, Charcoal Headliner, 20" OEM Wheels, Wife's ride
      Jeep WK2 owner x 3 (2011, 2014, 2016) Great vehicles, underrated IMO
      Dodge Durango 2016 Family hauler
      First car 1987 Volvo 740 GLE 5 spd RWD, acquired at 130K
      Dec 2017
      PNW
      I hope they have some tolerance of fluid level...
      If this is a concern, just go for a short trip (depends on how hot you want it to go) and open the center drain plug to drain the overflow out.
      Jan 2016
      NoVA
      Based on my experience with other cars, modern transmissions are built to tight tolerances and are more sensitive to precise fluid levels that ever before. Most modern cars have very precise procedures to measure the fluid level at exactly the right temperature, a specified time after specified transmission gear changes. So when my time comes, since I don't have free/easy access to Vida to do the transmission drain/fill ( I assume Vida has facility to measure transmission fluid temp) I will be measuring precisely what comes out. I have/use Vida 2014 on a virtual machine on my laptop and use it on my older generation Volvo's but Volvos attempt to limit its use to dealers thru its more locked down subscription Vida for newer cars forces more people to the dealer even for basic maintenance.
      D.C. Metro Region
      Nope. They are independent mechanical systems with their own fluid replacement intervals.
      2009 XC90 3.2 AWD l Oyster Grey / Bi-Xenon / Dynaudio / BLIS / VNS / RSE / THULE Aeroblade
      D.C. Metro Region
      And sadly the decades of transmission development and complexity are about to become a dinosaur for 85% of passenger vehicles with the onset and continued propagation of electric vehicles.
      A 3 speed transmission is - hi/lo forward and reverse is all they need.
      D.C. Metro Region
      Better to change your fluid when it is at normal operating temperature.
      Warm fluid will have expanded, so you get more out. And it will generally have more contaminants in suspension that haven't settled out as the fluid cooled and stayed stationary.
      Jul 2019
      Quote Originally Posted by specepic View Post
      Just depends. My mother’s 2009 Chrysler SUV with the less-than-stellar NAG 5 speed has never had its fluid changed, and it’s driving just fine after 10 years and 250K miles. That said, it’s probably now at the point where if she did change the fluid, she’d run into transmission problems.
      Jan 2016
      NoVA
      If car manufacturers were willing to give a lifetime warranty on the transmission then I'd believed in their lifetime fluid marketing hype. The reality is the fluid and the transmission will last thru the power train warranty period and then problems caused by dirty fluid are in the hands of the owner. At that point Volvo would be happy to replace your transmission at your cost. I will be changing my transmission fluid on a regular basis. I've done this on several other Volvos and have never got less that 250k miles from a car/transmission. Unfortunately I suspect the electronics in SPA platform cars won't last that long but I'll still treat the transmission well.
      Junior Member Azlkk's Avatar
      Jan 2013
      Phoenix, AZ/Morro Bay, CA
      Quote Originally Posted by ShadowDancer View Post
      My BT OBD2 dongle and iPhone app gives me transmission temperature.
      As for when it gets up to "normal operating temperature", it takes a lot longer to reach normal temperature than engine coolant. The wife's car lets me watch transmission temperatures and it takes something like 15 miles of driving when it's in the 70s.
      Volvo: 2015.5 XC60 RD Plat. arrest-me red w/ Climate, BLIS & OEM trailer hitch. Koni Special Active struts/shocks, IPD skid plate & rear sway bar
      Others: 2019 Merc AMG E53 Cpe, 1988 Merc 560SL, 1969 MGB GT, 1957 MG ZB Magnette, 1953 MG TD & 1935 Ford 5W Dlx Cpe
      Jan 2016
      NoVA
      Do any of the Volvo techs who frequent this forum have the procedure for transmission fluid change for the SPA platform?
      Dec 2017
      PNW
      They don't do drain and fill. They always disconnect the cooling hose, turn on the car and pump and fill. I think this method should be fine if done every 60k miles.
      Madrid, Spain
      Quote Originally Posted by Azlkk View Post
      Can you tell us which is the corresponding PID for that?
      I've been unable to find a PID that reflects ATF temperature, only engine coolant.
    37. #35
      D.C. Metro Region
      Wife's car? Drive it like you stole it and those tranny temps will come in no time. Problem solved.
      15 miles isn't that long if you plan a weekend day around the trans fluid change. i.e. - get up early in the morning. Grab breakfast and run a few weekend errands. By the time you get home, the fluid will be fully warmed up and ideal for replacement.
    1. HELP! - Coolant drain/fill - WHERE IS THE RADIATOR DRAIN VALVE???
      By soundquest in forum XC90 (SPA: 2016 - )
      Last Post: 07-27-2019, 04:14 PM
    2. M66 Transmission Fill/Drain Bolt Tool
      By briancpearce in forum Miscellaneous Classifieds
      Last Post: 02-10-2012, 07:16 AM
    3. T6 trans fluid drain & fill - from where to drain?
      By 04xc7090 in forum XC90 (2003 - 2014)
      Last Post: 05-06-2007, 10:07 PM
    4. Drain & Fill vs. Flush for transmission?
      By ncS60 in forum S60 (2001-2010)
      Last Post: 03-28-2007, 05:21 PM
