What oil should I use for a 130k motor ?
    Results 1 to 18 of 18
      Junior Member blacksaphireS60r's Avatar
      Sep 2018
      Wilmington NC
      I have almost finished hitting up the car after it’s been down for a long enough time. Anyways the engine that I have ready to drop in has 135k on it and I don’t know if I should use a thicker oil ? I don’t want to potentially mess up the turbo. Any help would be greatly appreciated.
      Oct 2015
      Auckland, New Zealand
      I wouldn't change the oil you use based on that sort of mileage.
      Go with fully synth with the viscosity suitable for the average temperature you will be driving in
      2006 Sonic Blue / Nordkapp V70R GT, custom made exhaust and 3" Downpipe, IPD sways, Powerflex bushings all around, Delrin front subframe bushings, BC Racing Coilovers
      Mar 2013
      Arizona
      Quote Originally Posted by Gonadz View Post
      Agreed. I have 126k on mine and use Mobil 1 10W30 year round, but then again I live in Phoenix where the winter lows are nearly the same as the summer highs in some of the parts of the frigid North.
      2006 V70R MT
      Sonic Blue / Gobi
      Original owner
      SwedeSpeed.com
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      https://volvornt.harte-hanks.com/man...0_09.htm#pg174
      "When temperatures exceed 86° F (30° C) in your area, Volvo recommends, for the protection of your engine, that you use a heavier weight oil, such as such as SAE 5W- 40 or 0W-40. See the viscosity chart."
      Use full synthetic that meets your use needs according to this table.
      2004 V70R MT TiGray/Nordkap - Replica 18" Pegs - Handbrake Mod
      2007 XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement - Y-Pipe Replacement
      1990 745 Turbo Intercooler White/Beige
      2007 XC70
      VIDA/DICE Owner - SS Lurker Since 2009 - '06-'07 Transmission Valve Body Info - SR/VR Failing Throttle Body
      Current Non-Volvo: 2007 VTX 1800 F3, 2002 VT750DC
      Previous: 2006 S60R
    7. #5
      Sep 2018
      Wilmington NC
      Thank you
    8. #6
      Sep 2018
      Wilmington NC
      Quote Originally Posted by Phoenix R View Post
      That makes sense. I live in NC where the weather is up and down constantly.
    9. #7
      Member Red_Devil's Avatar
      Jun 2010
      Mass
      I use 5W40 and have never had any issues.
      2018 Leadfoot Ford Raptor semi built 600hp, 2020 Audi RS3.
      05 S60R MT, Stock block 578AWHP, 12.2 1/4 mile at 124 mph. Built 804 AWHP. Built engine, Cnc ported head, Front & Rear LSD, Ported Gen 2 T4 GTX3584RS hybrid, Turbosmart 45mm WG, Tial QR Bov, Enem Y21 Cams, Radium Surge tank, 1700cc Id's, Triple Walbro 485's, PM3, Devils Own meth injection, speed density converted mafless setup, Bell FMIC, Snabb air box, Poly, Milletech intake manifold, IP plasma coils, IP Plasma lift. Snabb shifter. TTV Twin Clutch. GB Forgestar F-14's, Enkei RSF5, KW V2'S, Ur Braces, Vr sways, IPD toe bars. Built to the hill.
    10. #8
      Apr 2015
      Pittsburgh, PA
      I just use this:
      https://www.walmart.com/ip/Mobil-1-A...-5-qt/23636902
      Mobil 1 Advanced Full Synthetic Motor Oil 0W-40 European Car Formula
      2007 XC70
      Previous: 2006 S60R
    11. #9
      Junior Member Rodtheviking's Avatar
      Jun 2019
      Vancouver, WA
    12. #10
      Member CapeMayXC70's Avatar
      Sep 2015
      South Jersey
      I wait till Mobil One goes on sale then stock up. Just got a check back from them the other day. Works out to around $12 per 5 quart jug I bought 10 of them.
      05 XC70R Ice White
      06 V70R GT TiGrey/Gobi
      Sold & missed: 05 V70R M66 Saffhire Black/Nordkap
    13. #11
      Moderator The Driver's Avatar
      Sep 2009
      Huntington, NY
      Motul 300V 0W40
      06R Custom Electric Blue Silver
      07R Magic Blue - Sold
      04 Bonatti Gray Rover Disco HSE
      09 Iridium Silver SLK55 AMG P30 Edition
    14. #12
      Junior Member 850 GLT's Avatar
      Jan 2004
      Barrie/Ottawa, Ontario
      Castrol 0W40, European Car Formula.
      1998 Saffron/Charcoal C70 GT, 1998 Saffron/Charcoal V70R AWD, & 1998 Black/Charcoal V70R AWD
    15. #13
      Member
      Jun 2011
      Congo
      for best results make sure it's slippery kind.
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
      1997 Avalon - gone - son - space-force
    16. #14
      Member zmarshm1's Avatar
      Mar 2019
      Binghamton NY
      I use 0w 40 on the v70 all year round. Mobil 1
      ||1998 s70 t5m - Stock, future gambler 500 car | 140k? miles
      ||2001 v70 t5 - IPD Sway bars | Delrin subframe bushings | Transmission cooler & mounted inline filter | Rostra long snout transmission solenoids | IPD catback exhaust & Rolling Motors 3" downpipe | Simota Carbon Charge Intake | Bilstein B4 & Eibach prokit lowering springs | 124k mi
      ||2003 v70 2.4t - First volvo | SOLD! Still driving around with 190k+ miles.
      Kanjo!!
    17. #15
      Oct 2015
      I really thought all the car manufacturers had pulled back from advocating 0 W oil, I know they specc'd it when made but I believe I read recently about a Maserati bought 2nd hand that crapped it's motor, and the court case was thrown out because a later bulletin said not to use the zero weight oil now.
    18. #16
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Castrol Euro 0w40. Meets all the specs.
      2003 V70 T5 - Mystic/Graphite - M56LK - 206k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 299k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 243k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    19. #17
      May 2008
      I've been using mostly Mobil 1 0W40 (black top European Car Formula) for quite a long time now, but I have used M1 10W30, Castrol 5W30 (GC), Pennzoil Platinum 10W30, etc. Synthetic oil since new. I've been using the M1 0W40 because my Benz requires that oil, so it's easier to have just one oil to stock. BTW, all 0 weight oils are not created the same. I do get some oil consumption with 0W40 (1 quart in 5k miles), noticeably less with some other oils. 161k miles from new.
    20. #18
      Feb 2010
      Dallas, TX.
      Quote Originally Posted by 850 GLT View Post
      Here, here.
      2007 SapphiCama V70R 400K+/Km
      R-Kelly Intake/CFE/H&R 5/15 spacers
    21. Remove Advertisements
    Similar Threads
    1. SIRI, how to use it, and why you should use it if you have CarPlay:
      By Skitruckmaskin in forum XC90 (SPA: 2016 - )
      Last Post: 11-25-2016, 08:42 AM
    2. 1999 V70R Complete Motor with wiring and ECU 130K in NY
      By Cleary Coachworks in forum FWD & AWD Parts For Sale
      Last Post: 03-03-2014, 06:36 AM
    3. What grade of gas do you use, what should I use?
      By USAF 2010 T5 in forum S40 & V50 (2005-2012)
      Last Post: 08-08-2009, 02:42 PM
    4. type of motor oil use on an used 850 turbo
      By bus stop in forum 850 (1993-1997)
      Last Post: 10-27-2005, 01:20 PM
