Map Update via USB
    Results 1 to 14 of 14
      Sep 2019
      Canada
      Question Map Update via USB
      So I've had a "software update available" message for a bit now, and finally got around to trying to resolve it. I've done the following on two different PCs (one Windows 7 and another running Windows 10):
      • new flash drive (32GB - the update is 1.5GB)
      • full (not quick) format with FAT32
      • launch the Volvo update app from browser and from Windows Explorer after downloading the EXE
      • download the update directly to USB
      • verify the update using the updater tool
      • insert the USB into the CarPlay/AndoidAuto port both with the car off and running
      And the Sensus display has not responded to the update. I know it sees the stick (the USB app for media is enabled). I just can't seem to trigger the update.
      Any Sensus veterans (I've only had my S90 since the end of August) have some tips they can share? Special chant that needs to be uttered, animal sacrifice, etc. that I may not be doing?
      May 2013
      Los Angeles, CA
      Try opening navigation and see if it then says it's not available. Try going for a drive with the drive plugged into the white USB port in the console.
      Sent from my GM1917 using Tapatalk
      Current:
      2018 V90CC ,Osmium Grey / Blond, Luxury Package, Heads Up Display, B&W Sound, Trailer Hitch, Convenience Package, Polestar - "Julia" ,August 2017 OSD
      1987 Ferrari Testarossa - "Scarlett"
      2003 Porsche 911 - "Sally"
      Sold:
      1987 Mercedes 300TD - "Veggie" ran off vegetable oil.
      2002 V70XC - "Lisbeth" - Sold 4/14/2018 with 130,202 miles.
      Texas
      Quote Originally Posted by HR613 View Post
      That message has been around for a while now and never once have been able to figure out what it means. You can look through all the screens and see no updates available.
      Junior Member Volvolic's Avatar
      Michigan
      If Software Update Available message shows up, it's either the in-built Sensus apps or one of the region maps. If you have maps for the whole continent (ex: North America) installed, it will still give you a notification even if one of the states' map has an available update. I have never seen the Update available show up without reason. It's either the local region map or an application.
      You need to click individually on each available option to see what updates are available.
      2018 Volvo V90 CC T6 Polestar'd
      What It's Like To Own A Volvo V90 Cross Country?? https://www.youtube.com/watch?v=yYbC8bg-N8c
      Sep 2019
      Canada
      Quote Originally Posted by kartboy1234 View Post
      Thanks for the suggestion. Tried that and still no joy.
      Member matt1122's Avatar
      Feb 2012
      New Jersey
      Mine's been finicky like this every time I've updated the maps. I just plug and unplug things until it works. Sometimes I end up going wherever I'm going and just try it at every stoplight.
      2017 V90 Cross Country T6 AWD | Osmium Grey / Charcoal | Convenience Package, Bowers & Wilkins, HUD, Rear Air Suspension, Polestar Optimization
      Past: 1995 Volvo 854 T-5R | 2001 Volvo V70 XC 2.4T AWD | 2007 Volvo XC70 2.5T AWD | 2015 V60 T6 AWD R-Design
      Family History: 1983 Volvo 245 | 1987 Volvo 744 Turbo | 1993 Volvo 854 | 2001 Volvo S80 T6 | 2005 Volvo S60 2.5T AWD | 2013 Volvo XC60 T6 AWD | 2015.5 Volvo S60 Cross Country
      Jan 2016
      NoVA
      Its been a while since I first formatted my USB flash drive but I seem to remember trying a couple of different formatting options before it worked. I'd don't recall but maybe try exFAT, NTFS instead of FAT32 . May also differ based on the size of flash drive?? Also, make sure you unzip the files into the root of the flash drive not a sub-folder.
      Quote Originally Posted by matt1122 View Post
      2018 V90 T5 R Design FWD | Bursting Blue / Charcoal, Full Napa Leather | 20" R Design Diamond Cut wheels | Convenience Package | Laminated Glass | Heated Seats/Steering Wheel | HUD | Powered Load Cover | Mud Flaps | Rubber Floor Mats | Polestar Optimization
      Sep 2019
      Canada
      I tried again last night while driving home. One time when I removed it, I got a pop-down notification that the map update had paused and asking me to re-insert the USB. Unfortunately, no matter how many times I re-inserted it, I never got anywhere.
      Nov 2015
      Croatia
      Make sure there is no other flash drive connected to the other usb port except the white one for the update purpose...
      Sent from my SM-N960F using Tapatalk
      Member volvobuff's Avatar
      Mar 2007
      SE MA
      The USB socket fit gets looser with time and use, just as in the previous generation of Volvos. Try putting a piece of electrical tape on one side of the USB stick to tighten up the fit. Works like a charm!
      Current: 2018 V90 T5 FWD, Mussel Blue/Charcoal, Inscription, Dark Flame Birch, Convenience, no B&W, HUD, Leather Dash, Black Headliner, Heated Steering Wheel
      Current: 2017 S90 T5 FWD, Mussel Blue/Blonde, Inscription, Vision, Climate, Convenience, B&W, HUD, Leather Dash, Spoiler, 20" Rims
      Past: 2 x 2015.5 V60 Drive-E T5 FWD; 2012 XC70 T6 AWD; 2012 S60 T5; 2010 V70 3.2; 2008 S40 T5; 2007 V50 T5; 1981 245 DL
      Feb 2012
      New Jersey
      Socket is nice and tight in my car, and it detects anything else inserted fine.
      It just seems to have issues "noticing" that I put a map update USB drive in the socket.
      Apr 2018
      Maybe it means a dealer software update is available.
      Sent from my SM-N975U1 using Tapatalk
      Try updating the Voice Command files first.
      Quote Originally Posted by gregwlsn View Post
      No it doesn't.
      Jan 2018
      Cornwall, NY
      Buy a three-inch-long USB-to-USB dongle, plug it into the Volvo receptacle and never unplug it. Use the other end to plug in whatever you wish and the Volvo socket will stay tight forever.
    17. Remove Advertisements
    1. Sensus Update for USB Map Uploads -2 Different Dealer Quotes
      By LittleMushi in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 03-19-2018, 10:52 PM
    2. Navigation: Time needed for map upload via USB ?
      By Pall_Gudjonsson in forum XC90 (SPA: 2016 - )
      Last Post: 01-18-2018, 11:19 AM
    3. Software update to allow USB map updates bricked my car!
      By marvinmartian in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 08-14-2017, 02:47 PM
    4. Software update to allow USB map updates not "going through?"
      Last Post: 07-20-2017, 07:41 PM
    5. You can even update a FIAT via a usb stick but...
      By Omr284 in forum XC90 (SPA: 2016 - )
      Last Post: 05-14-2016, 05:19 AM
