Polestar best 19 inch tire size? Tirerack says 245/40 R19. Polestar Rep says (for winter tires) 235/40-R19
    Results 1 to 25 of 25
      Dec 2010
      Question Polestar best 19 inch tire size? Tirerack says 245/40 R19. Polestar Rep says (for winter tires) 235/40-R19
      If I decided to get 19 inch (OEM Polestar) wheels for my 2018 S60 Polestar and want the closest 19" tire size to the OEM 20 inch setup:
      I see the tirerack size 245/40-R19 is closer (negligeable 0.13% speedo error) than the Polestar rep size (235/40-R19) which has 1.33% speed error. Neither has any poke or inset issues.
      I assume the Polestar rep was responding based on available sizes for 'winter performance' tires for the 19 inch (winter) rims and hence did not suggest the closer 245/40/R19?
      Any reason to get Polestar rep's (winter) size 235/40-R19 instead of Tirerack recommended 245/40-R19 size given OEM 245/35-20 size, assuming I am getting UHP all season tires (and not winter tires) for argument's sake. (edited message due to size typo - I flipped the two sizes in this particular sentence by mistake).
      Tirerack 19 inch tire size
      https://www.willtheyfit.com/index.ph...h=8&offset2=53
      Polestar Rep 19 inch tire size when asked for 19" winter tires (for 19 inch OEM rims):
      Used ET53 offset and 8 inch rim width.
      2018 S60 Polestar, Rebel Blue / now known as Cyan Racing Blue
      Jan 2019
      Just put 235 on mine. Your speedo calculation means 235 would be 0.9MPH out at 60MPH not exactly massive. Standard Volvo 19" wheels are ET51 not 53
      Dec 2010
      Quote Originally Posted by The Flute View Post
      Thanks. Right the speedo error is not a huge deal. The bigger question I have is whether there is any reason to get 19 inch tires in 235 vs 245, if the 245 size is available?
      I thought I recalled it being ET51 as well, but the following pages both say ET53? Maybe an error...
      One is for the 2015-2016 19 inch Polestar winter wheels and the other is for the 2018 20 inch Polestar wheels.
      https://www.vivaperformance.com/genu...15-2016-years/
      https://www.vivaperformance.com/genu...eel-2018-year/
      SwedeSpeed.com
      Jan 2019
      Quote Originally Posted by njdriver View Post
      Yeah but have a look here and blow up the picture of the Volvo box. https://www.vivaperformance.com/genu...15-2016-years/
    7. #5
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      You'd probably be fine with either 235 or 245 if you are getting Polestar wheels, which have a higher offset than most of the aftermarket wheels. I don't know why Tirerack is now recommending the 245 and lists 235 as the alternate size - that's new. When I bought my winter set from them almost 4 years ago 235 was the only size they recommended for the car, and with +45 offset wheels I get slight rub. I kid you not, 235 width tires vary from manufacturer to manufacturer, tire to tire.
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15 XC70 T6, '15.5 XC60 T6, '16 V60 P*
    8. #6
      Dec 2010
      Quote Originally Posted by Wayne T5 View Post
      Thanks, that helps regarding rubbing with +45 offset wheels!
      Tirerack lists 245/35-20 Load Class: XL on the 'Factory Tire Size' (main tab).
      On the second tab, labeled 'Optional Tire Sizes', Tirerrack lists 19" 245/40-19. Tirerack does not list 235 as "alternate size" for 19".
      Polestar rep suggests 235 for 19" though.
    9. #7
      Nov 2002
      Russell Twp, OH
      It does when you look specifically at winter tires.
      https://www.tirerack.com/snow/Select...al+Valve+Stems
    10. #8
      Dec 2010
      Interesting, thanks! Wonder if the 235 is in case there are no options in 245 in winter tires.
    11. #9
      Senior Member Johann's Avatar
      Nov 2001
      Netherlands
      235/40-19 on the OEM Polestar 19" wheels.
      '17 Volvo S60 Polestar '15 XC60T5 Polestarised
    12. #10
      Member TexasV60P's Avatar
      Jul 2004
      Dallas, TX
      This combination came from Tirerack:
      https://forums.swedespeed.com/showth...UPERTURISMO-LM
      2015.5 #39 BSM V60 Polestar arrived 11-24-2014
      2004 V70R GT: SOLD Silver+Nordkap, Premium Sound+Subwoofer, Motorola BT, iMIV, IPD Stage II - DP - HDTCV, Kelly CAI, BMC, 10MM Spacers, Volvo DEM heat shield, '06 V70R console
    13. #11
      Dec 2010
      Quote Originally Posted by Johann View Post
      Thanks Johan!
      What is the downside of the 245/40-R19 (vs. 235/40-R19) on the stock Polestar winter wheels (19"x8")?
      (I am asking since ideally I had been thinking of a wider tire width - e.g 245 - for [added] rim protection, but maybe that does not apply in this situation given 8 inch width for the OEM 19" winter rim, maybe 235 is also fine).
    14. #12
      Nov 2002
      Russell Twp, OH
      When we were buying these sets several years ago now at this point we just followed the owner's manual which recommends 235's for winter I think, plus a narrower tire provides better bite in slippery conditions.
      I may be going to 225/45 when I replace the ones I currently have.
    15. #13
      Dec 2010
      Thanks.
      Right, the narrower tires are definitely a bit better in snow. I would like to see if the tire protects the rim when going with 235.
      My old R-Design had the 18 inch Ixion rims and the rim (width section) protruded beyond the tire width; therefore when parallel parking or encountering potholes, it was easier to get curb rash.
    16. #14
      Dec 2010
      Okay, never easy:
      Been reading that the Alpin PA4 (which I had on my last car as well) is better in snow than the Pirelli SottoZero 3. Unfortunately the only PA4 listed on tirerack in 235/40-R19 size, labeled 'Michelin Pilot Alpin PA4 N-Spec', does not seem to have an XL load rating (Size: 235/40R19 92V, N0(Porsche), Style: Blackwall, Eco Focus: Green X, Serv. Desc: 92V).
      Further to the concern regarding lack of XL load for the PA4 in 235/40-R19 size (noted above), I also noticed the brand new and improved Alpin PA5 is available in 245/40-R19 size but not in 235/40-R19...
      Given all of the above, it would be appreciated if anyone can confirm that the wider 245/40-R19 will not cause any rubbing or other fitment issues (vs 235/40-R19) with the Volvo OEM Polestar 19" winter rims.
      If there are no fitment issues, I might go with the brand new PA5 in that size (245/40-R19), but happy to get feedback / suggestions to the contrary from others.
      (Edited to correct typos).
    17. #15
      Junior Member mtnpolestar's Avatar
      Jun 2016
      Colorado Mtns
      The 245 tire will be .3" wider than the 235 tire...if that helps. Here is a great comparison configurator to compare wheel/tire sizes. Guessing that the P* 19" winter wheel has an ET55 (offset).
      https://www.rimsntires.com/specspro.jsp
    18. #16
      Sep 2015
      Iím running the Michelin pilot PA4 in 235/40/19 on stock Rdesign wheels with 15mm spacers all around and I get 0 rubbing if that helps. I also talked to tire rack regarding the load rating of the tires and was told that the rating is fine for our cars even though the tire isnít an XL.
    19. #17
      Nov 2002
      Russell Twp, OH
      Pretty sure the Ohlins suspension lowers the car a bit so not exactly apples to apples.
    20. #18
      Sep 2015
      Lol my car is lower than a polestar. I have the H&R lowering springs on it. Springs are just really dirty
    21. #19
      Nov 2002
      Russell Twp, OH
      Quote Originally Posted by mtnpolestar View Post
      The offset is 51 on those wheels.
    22. #20
      Dec 2010
      Quote Originally Posted by limey View Post
      Thanks everyone!
      Question regarding the quoted post: Did tirerack happen to mention if the sidewall of the Alpin PA4 235/40-R19 (version without XL rating) is reinforced?
      And to confirm, you bought this particular 'N Spec' one? I mean the only PA4 listed on tirerack in 235/40-R19 size is labeled 'Michelin Pilot Alpin PA4 N-Spec' as noted in an earlier post. N0(Porsche) Style: Blackwall, Eco Focus: Green X, Serv. Desc: 92V
    23. #21
      Sep 2015
      Thanks everyone!
      They did not mention that it was reinforced. But to be fair I didnít ask. I only asked if the N spec 92V would work on my V60 and they said yes it will work.
    24. #22
      Jun 2016
      Colorado Mtns
      And to confirm, you bought this particular 'N Spec' one? I mean the only PA4 listed on tirerack in 235/40-R19 size is labeled 'Michelin Pilot Alpin PA4 N-Spec' as noted in an earlier post. N0(Porsche) Style: Blackwall, Eco Focus: Green X, Serv. Desc: 92V[/QUOTE]
      I've been running this exact N-Spec PA4 for 3 seasons without any issues... Glad to hear Tire Rack said the 92 load rating is OK for our cars. I worked out the weight math on it and did not see that it
      should be an issue as long as I did not use them for towing or really heavy weight in the car or super aggressive driving/track (but who'd do that with winter tires....).
    25. #23
      Dec 2010
      Great, thanks, so then the PA4 are definitely in the running. Which rims are you using?
      Too bad tirerack doesn't have rims with a 51 ET offset (think the closest they have is still ET45 which concerns me due to potential rubbing depending on the tire).
      Tirerack chat reply (in italics) about any other options since their rims are not ET51 and their suggested package of 245/40R19 Sottozero 3 tires and 19x8 rims (which states "modifications to rear fender lip may be needed"):
      Yeah it's a tight fit for that car and 19x8 45mm offset is the least aggressive fit. Only way to guarantee you wouldn't have rubbing concerns is to pair the 19x8 45mm offset wheels with a set of 225/45/19 sized winter tires.
      6:50pm
      doing the 225mm width tires instead of 245 would eliminate that concern,
    26. #24
      Nov 2002
      Russell Twp, OH
      Tirerack did have 48 offset wheels for a short time but I didn't get them for some reason, maybe I didn't like the design, I really don't remember.
      Other swedespeeders have gotten creative and found other solutions if you want to page through the winter tire thread. All of our set-ups are on there.
      My issue is that just by dumb luck I bought what is probably the widest of all 235 width tires. It's pretty striking if you care to dig into the individual specs for each tire on the Tirerack website. When I looked later I noticed that some of the other 235 width tires had a tread that was literally an inch or so narrower than the ones I chose - oh well. I don't think I had any instances of rubbing last year on season 3 with them as they've worn a bit (it was that close) so I don't anticipate it either this season.
    27. #25
      Jun 2016
      Colorado Mtns
      Here is my winter setup with the PA4s. Wheels are ET45 Advanti DST Hybris 19" x 8.5" wheels. 235/40 tires and I used a Dremmel to grind off 1-2 mm of the inside lip, no rubbing.
    28. Remove Advertisements
    Similar Threads
    1. 2016 momentum 255-50 19 inch vs 235-55-19 inch
      By Highpowerdad in forum XC90 (SPA: 2016 - )
      Last Post: 08-17-2018, 11:27 AM
    2. FS 19" Bor Diamond Cut alloy wheels with 235 40 R19 pirelli C7
      By MRCW in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 05-28-2018, 02:42 PM
    3. 245/40/19 or 235/40/19 on lowered v60
      By munkeeboi in forum The Wheel and Tire Forum
      Last Post: 03-25-2017, 11:08 AM
    4. Tire size for 19" rim--235/40 vs 245/35?
      By teefive in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 09-05-2013, 02:39 PM
    5. WTT-245/40 18's or 235/40 18's for 225/40 18's
      By e-rock in forum Wheels & Tires Classifieds
      Last Post: 04-04-2010, 01:06 PM
