Zoinks' 1998 V70R - An Adventure Tail - Page 3
    Page 3 of 3 FirstFirst 1 2 3
    Results 71 to 98 of 98
    1. #71
      Junior Member Zoinks's Avatar
      Jul 2018
      Milwaukee, WI
      Quote Originally Posted by Richard99 View Post
      Love that saffron-colored wagon in the background.
      Me too! But the owner isn't letting go of that one unless someone would over pay for it lol
      1998 V70R Mystic Silver/Graphite
      1996 RN Swapped 854R Bright Red/Graphite
      Past:
      1998 V70 NA/m Classic Red/Light Gray
      Jul 2018
      Milwaukee, WI
      First iteration looks good, fits kinda tight so Iím gonna widen some holes. Gotta make some improvements then reprint
      Past:
    4. #73
      Jul 2018
      Milwaukee, WI
      The VR is doing really well in the snow this winter, been trying to keep her as clean as possible on the warm days, it'll get another wash on Monday if the snow holds off!
      Cracked 161k miles too
      And I discovered this little guy behind the radio awhile ago, I've done some reading and I don't think it's a Bluetooth device but when the 6 disc changer is on it immediately goes to track 99. Which I've read means that a Bluetooth device is trying to connect. But my phone can't find a device when trying to search for it, does anyone recignize this thing?
      Past:
      SwedeSpeed.com
      Apr 2014
      Quote Originally Posted by Zoinks View Post
      Jealous you get some snow to play in. Have hardly had any this season.
      Looks like it's an old iPod/iPhone integration device.
      Maybe the cord is hidden somewhere else in the car?
      https://www.blitzsafe.com/catalog/vo...link1-v-1.html
    7. #75
      Jul 2018
      Milwaukee, WI
      Quote Originally Posted by cbblunk View Post
      The snow has been lots of fun, the awd makes drifting around in it a Blast! But the tires catch traction faster than I'd like for fun. But that means they're actually worth the investment when there's a situation that I'll need to use the grip in lol
      That link is also what I just found, and I found this write up too https://blog.fcpeuro.com/how-to-inst...-volvo-v70-p80. I'll have to dig around the R to look for an aux plug, but another nagging issue is that the radio only intermittently works. I'm not sure if that's an issue with wiring or the head unit itself. The discs in the 3 disc changer always work, but the radio rarely does
      Past:
    8. #76
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Thats the HU. Im guessing its the original SC900. Just toss it for a SC901 and get ProLogic with radio and better EQ!
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 293k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
    9. #77
      Jul 2018
      Milwaukee, WI
      Quote Originally Posted by ScottishBrick View Post
      [s]The R already received a sc901 from a PO[/s] edit: I was wrong, the HU is I fact a SC900, I'd rather avoid buying another one. So my logic is that if I can get the aux input functional I'll just use that instead of replacing the HU, because with aux I wouldn't ever use the radio.
      Past:
    10. #78
      Junior Member 98v70t5man's Avatar
      Jul 2013
      WA
      Check that both antenna connections are firmly into the back of the HU. It uses a diversity system so if one cable is loose the FM signals are near null.
      -Paul
      1998 OSD V70 T5M | M56H | Signal Red(601)/Tan(3960) | IPD susp | ARD Custom Tune | Delrin subframe bushings | Propus
    11. #79
      Jul 2018
      Milwaukee, WI
      Quote Originally Posted by 98v70t5man View Post
      This is promising, seems like when it does work itís a terrible signal. But I also found the aux cord (well itís an old Apple 30 pin connector) so I might just end up getting an updated cord and running the aux
      Past:
    12. #80
      Jul 2018
      Milwaukee, WI
      Good news! I found the old 30 pin cord that comes from the box behind the head unit (pictured above), and now I want to replace it with a lightning cable, but I canít find the name of the connection I need.
      Can anyone name the cord/connection that adapts to the 30 pin connector in this picture?
      Past:
    13. #81
      Jul 2018
      Milwaukee, WI
      Replaced the axle with a torn outer boot this morning, pretty easy job that didnít take long at all. Not my first rodeo lol
      Also test fitted the new wheels in making the spacers/hub rings for, I absolutely LOVE the way they look and theyíre so much lighter than stock
      Past:
    14. #82
      Member Avboden's Avatar
      Apr 2010
      Michigan
      Honestly dumping the old-school headunit for a modern double-din with proper bluetooth, microphone, etc. is so worth it. It can be done pretty darn cheap too. I know many here disagree with me and swear by the OEM dolby system but honestly after switching and having a proper equalizer and the ability to play higher fidelity audio files *and* having full bluetooth and all that was so worth it. Heck you can get a head unit with apple carplay for like $229 now
      Assuming you have a system with the factory amp, instructions here if you were interested: https://forums.swedespeed.com/showth...in-factory-amp
      2019 S60 T6 Inscription
      1998 V70R. RIP Transmission
      1973 Volvo 1800ES which will someday get a T6 engine
    15. #83
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Or you can get a Grom and a SC-901 which does all of those things.....
      I can play FLAC through my Grom. Sounds fantastic. SC-901 has a proper equalizer too. It's one of the hidden menus. I could have BT and microphone too but I wouldn't use them so I never bothered installing them in my T-5R. PO of my S60 put in BT and mic; I've tried them and they work great but I just like usb streaming better and don't talk on the phone in the car so I never use them. I have HU control over my phone too. So basically you are going to a lot of effort to delete a Dolby surround sound system designed specifically for the car for no significant advantages I can see.
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 296k.
      1997 850R Estate. RN/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 138k.
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 100k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k.
    16. #84
      Jul 2018
      Milwaukee, WI
      Past:
    17. #85
      Jan 2014
      Boston, MA
      such a classic formation
    18. #86
      Jul 2018
      Milwaukee, WI
      Quote Originally Posted by JaredR View Post
      And midterms are approaching so I have negative time to fix anything. But Iím getting errors with both front wheel speed sensors
      And a speedo CEL(?)
      PO told me that the ABS unit was resoldered (by him smh), so Iím thinking that could be the fault? Either that or something wrong with the ABS harness because I cleaned all the hall effect sensors
      Past:
    19. #87
      Jul 2018
      Milwaukee, WI
      Quote Originally Posted by Avboden View Post
      Iíve gone back and forth between aftermarket HU and a 901, Iím not really an audiophile so I donít think I could hear a difference unless it was pointed out to me to be frank. Apple CarPlay would be sick though, but modifying the stock HU mounting rials would not be sick. But I havenít done enough research into it yet so thanks for that link!
      For now Iím just going to get a mini-din to lightning cable for aux functionality. Hopefully my audio quality issues arenít a problem with an aux input
      Past:
    20. #88
      Junior Member CYB3RBYTE's Avatar
      Oct 2016
      Milwaukee, WI
      I work at a store that um starts with the letter A. The lightning to 30 pin adapter is what you're gunning for. The one coming from the box is most likely a proprietary connector.
      In the Garage
      Xena / 2006 XC90 V8 AWD, Onyx + Oak / 170,6xx /
      Viveka / 1996 850 N/A, Polar White + Oak / 128,5xx /
      Blixt / 1996 850 R, Polar White + Charcoal / 219,2xx /
    21. #89
      Junior Member i_like_volvos's Avatar
      Mar 2019
      Concord, NC
      Have you checked this site, https://www.midwest-abs.com/, to help troubleshoot? Shoot him an email, he was very helpful when I was having similar issues.
      Current:
      1998 S70 GLT: T5 ECU || 16T Turbo || White Injectors || Snabb RIP Kit || Snabb Fresh Air Pipe || Bilstein Touring || Eibach Lowering Springs || 17Ē Neptunes
      2007 V70 2.5T: Snabb Fresh Air Pipe || BC Racing Coilovers
      Previous: 2006 V70 2.5T, 2011 C70 T5, 2012 S60 T5, 2000 S70 GLT/SE
    22. #90
      Jan 2014
      Boston, MA
      I would just get a rebuilt module from Midwest. I resoldered the module in my white 850R and was not fully successful and also made a mess of the module. They are a nightmare to disassemble. Not recommended as a DIY.
    23. #91
      Jul 2018
      Milwaukee, WI
      Quote Originally Posted by CYB3RBYTE View Post
      Propriety, that sucks. Iíll have to invest in a solution before my next roadtrip :/
      Past:
    24. #92
      Jan 2014
      Boston, MA
      One of the reasons I got a LG G8 for my current phone was specifically because it has a 3.5mm audio jack. And a SD card slot so I can have a lot of local music for road trips. I don't use the 3.5mm audio in the car anymore (Grom USB streaming FTW!) but I use it a LOT around the house.
    25. #93
      Jul 2018
      Milwaukee, WI
      Quote Originally Posted by i_like_volvos View Post
      I emailed him this evening, $65 additional charge for my lack of core. Gonna try to source a core locally from a junkyard, but if that doesnít pan out I wouldnít mind that total price tag
      Past:
    26. #94
      Jul 2018
      Milwaukee, WI
      Oil change and tire rotation just before 162k miles, was gonna do a transmission drain and fill but Iím glad I didnít. Some guy put the oil filter on wayyyy tight (it was me smh). Tried the janky method of hammering in a screw driver for leverage, failed. Then called a friend for a ride to get a filter wrench, and of course instead of going back to work we got $2 tacos and taps.
      Got back to campus, ripped the old filter off, threw on the new filter, some new oil, moved the tires, and now itís time for mug night!
      Took much longer than I care to admit for an oil change but we had sufficient breaks LOL
      Past:
    27. #95
      Jan 2014
      Boston, MA
      LOL you're supposed to get the food after the work is done
    28. #96
      Jul 2018
      Milwaukee, WI
      It was a weird target of opportunity, we brought it up out of nowhere and decided to call and see what the wait was (usually close to 60 minutes wait on tues/thurs for the deals) but they said they had two open tables! Couldnít pass up that opportunity lol
      Got a couple weird looks before I was told there was oil on my face
      Past:
    29. #97
      Oct 2016
      Milwaukee, WI
      Those pictures remind me of the time we got food, and my um, makeshift exhaust repairs lol.
      In the Garage
    30. #98
      Aug 2009
      The white looks amazing on these cars!
    31. Remove Advertisements
    Similar Threads
    1. Zoinks' 850R - An Underdog Story
      By Zoinks in forum 850 (1993-1997)
      Last Post: 02-24-2020, 07:31 PM
    2. VikingSpeed's V70R Adventure
      By VikingSpeed in forum R Forum (2004-2007)
      Last Post: 02-21-2019, 01:23 PM
    3. Replies: 2
      Last Post: 10-23-2018, 10:50 AM
    4. My adventure in R Lighting...
      By George @ ViVA in forum R Forum (2004-2007)
      Last Post: 04-03-2010, 06:52 PM
