Clunk with S60R clutch and P1 SMF
    Results 1 to 16 of 16
      Aug 2012
      I'm aware of the rattle at idle, but has anyone heard of kind of a delayed clunk in the driveline after startup? It's not directly connected to any action, I push in the clutch to start the car, then whether I release it or hold it in, engaging a gear or not, after 5-15 seconds or so, there's a small clunk. No jerk, nothing else feels amiss. Clutch holds great. Only thing I feel is a little off, but it's probably just the aggressive clutch, is the clutch engages way at the top of pedal travel and is a lot grabbier than stock.
      Does anyone have this? Is it normal?
      2009 Hilton Stage 2 C70 M66 Passion Red/Graphite/Aluminum - Quaife LSD installed! Has anyone else noticed gear whir in 3rd and 4th? Or a "clunk" from the SPEC SMF and R clutch (or front LCA poly bushings?) at startup?
      2011 XC60 3.2L Barents Blue/Anthracite/Aluminum - rings/pistons at 35k, new engine at 50k, seems no oil loss yet at 100k.
      Member lookforjoe's Avatar
      Mar 2008
      NY
      Was it a new flywheel? There is no P1 (C30, etc.,) SMF, so what was it from/intended for?
      If you meant P80 (850, V70, etc), that flywheel is the wrong stack height for a DM clutch, and that would explain the really high engagement. Clunk could be related to the throwout binding on the shaft from over extension, then popping back, I guess.
      Could be something entirely unrelated. Would be worth checking your axles for end float & that the retainer bolts are properly torqued....
      Pics of parts, or part numbers & supplier info would probably help determine situation.
      Junior Member Facusan's Avatar
      Nov 2014
      Houston, TX
      Does it make it when the engine is cold or hot?
      My car sometimes makes a clunk while the engine is warming up or cooling down after parked.
      Quote Originally Posted by Facusan View Post
      are you sure that's not the ABS or brakes?
      2008 Volvo C30 R-design red manual
      Aug 2012
      All new parts, including axles. I would doubt axles, because nothing moves but the engine and flywheel (and the suspension from me getting into the car) It's the Viva P1 kit, which the SMF is "specified" for. I think it has some different alignment pins from the S60R.
      Regarding ABS or brake noises, maybe, but it happens without touching the parking brake or brake pedal. Changing front brake pads this weekend, so we'll see if anything changes.
      Cold, but it doesn't wait for any significant warming. And it didn't do it before changing the clutch.
      Nov 2014
      Houston, TX
      Quote Originally Posted by potatochobit View Post
      Yes, 100% sure it is not brakes or ABS.
      For the first time in almost 3 years of owning this car I finally captured it in this video at ~1:03. That was a cold start from 30 mins ago the engine was running before the video starts for the time it took me start it and pop the hood to film it (8 seconds max). 42 deg. F today. Sometimes it makes that sound while parked and engine off. I think it has to be related to thermal expansion.
      And NO, that was not the A/C, it was off.
      To the OP: Is something like this?
      https://streamable.com/fpivi
      Aug 2012
      Nope. I'd call that a click. I'd guess that's an emissions related device. Seems it's about the right time for the CAT to get to temperature. But I'm definitely going to record mine and post it.
      Aug 2012
      ...or not. So I record and no clunk. I hear a couple knocks, maybe, on the recording, but definitely had no clunk. Will try again tomorrow. Would be super weird if something pops up and hits the hood, because that was the only difference today, that I opened the hood to get a better recording. :^D
      Aug 2012
      Well, I know what it isn't. I went to take off the wheels to replace the front brake pads (and found the rotors had been turned once before I bought the car at 25000 miles, which is annoying, as I went 60000 on the next set of pads) and found the left axle bolt floating around in the center cap. I put the rotors back in until I can get new ones and torqued the axle bolt back down, and got a clunk the second time I started the car. So it does it cold and warm.
      Still trying to capture the audio...
      Aug 2012
      I managed to be recording while it made the noise, but you can't hear it. I may have to do some filtering and see if I can isolate it.
      Aug 2012
      Aug 2012
      Okay, 7 seconds in on the recording linked below. Seems you can hear the clunk more than the engine in the cabin. Going to work on using an outside mic.
      https://1drv.ms/u/s!AruMTzMbn2KpiDUy...rURBB?e=kDXefp
      Nov 2014
      Houston, TX
      It is me or that sounds like a exhaust popping??
      Did this started to happen after the clutch and SMF replacement??
      that sounds more like a knock than a clunk
      was the car actually moving when it made that sound or were you still idling?
      Aug 2012
      Yeah, not quite a knock, either. Kind of a cross between a knock and a pop. Definitely not a ping, which is what I'd call an exhaust noise. Or did you mean like a burble pop type of noise, which the car doesn't do, let alone at idle. It does growl loudly though, maybe even roars.
      And yes, right after the clutch and SMF replacement. Car not moving. parking brake on, clutch engaged. But it will do it whether the clutch is engaged or not. Could it be an air bubble in the hydraulics? Doesn't feel like it... Clutch engages high. I'd think a bubble would require more travel.
      Also, for the interested, Hilton stage 2 crushes Polestar. Had to drop back to Polestar for driveability for family in town and I wanted to scream when I went on a familiar freeway connector and pulled out and around to the fast lane. _Definitely_ slower.
      Aug 2012
      So, my alignment shop told me my 6 month old poly bushings in front cause a clunk/pop, so I'm going to try to see if it is really just me sitting in the car and a little vibration after sitting unloaded, rather than a driveline thing.
    19. Remove Advertisements
    1. 05 S60R Viva SMF and Stock clutch install questions..
      By Svens242 in forum R Forum (2004-2007)
      Last Post: 07-27-2016, 02:51 AM
    2. S60R/V70R SMF and stage 3 clutch
      By bewbzout in forum FWD & AWD Parts For Sale
      Last Post: 12-04-2015, 12:03 PM
    3. Viva smf vs 850 smf
      By bewbzout in forum R Forum (2004-2007)
      Last Post: 02-21-2015, 04:29 PM
    4. Left Turn Clunk-Clunk-Clunk
      By mgfletcher145 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 09-21-2011, 04:09 AM
    5. BANG! CLUNK clunk clunck clunk OH [email protected]#$$%
      By Thanatos in forum R Forum (2004-2007)
      Last Post: 11-19-2010, 02:58 PM
