Rear door latch stopped working. Cold weather related?
    Results 1 to 14 of 14
      Member Papa_Kirlo's Avatar
      Feb 2003
      Boston
      I had an unpleasant surprise this morning. It's balmy 18F and I leaving for work and I cannot close the door? the electric is working as I can hear its clicking but latch doesn't engage at all. Like I have no door lock in the door at all. ftw. Anyone has seen anything like that? I might try to heat it up with hot air but it's not that cold yet...
      06 V70R Sonicap
      surf/skate/snow/smile-mobile
      16 XC90 fam-mobile
      Feb 2003
      Boston
      Update. sun is up and xc is unfrozen. works like nothing happened... any suggestion for what to spray locks with?
      06 V70R Sonicap
      16 XC90 fam-mobile
      Junior Member bunnny's Avatar
      Jun 2017
      Brooklyn, NY
      You’re not alone. Having in mind the Swedish winter conditions which I believe is more brutal than the NYC, I have to manually slam the mentioned door every time the temps drop. I‘m assuming it is Sensus glitch or a manufacturer’s defect that Volvo simply ignore to fix.
      Volvo for Life
      SwedeSpeed.com
      Feb 2003
      Boston
      really. wow
      I've been driving Volvos since 2000 and this is the first time I saw this. I think it some stupid sensor in the lock mechanism malfunctioned.
      06 V70R Sonicap
      16 XC90 fam-mobile
    7. #5
      Jan 2017
      I've had same issue with my 2017 XC90. Today is a cold day (18F with freezing rain yesterday), and it's happened once or twice before in previous years. Gets "solved" when sun thaws everything, but in my case, door wouldn't latch closed so wasn't safe to drive (door would swing open) which meant an unusable car until the sun came up
      Dealer had greased the latch last year, but not sure if it helped.
    8. #6
      Feb 2003
      Boston
      Quote Originally Posted by pwm View Post
      you described exactly what happened to me this morning. even the same weather. are we neighbors, lol? luckily I can WFH.
      I just ordered silicon sprays (dry and wet) and lock de-icer spray and will go over all locks and seals when it gets here.
      06 V70R Sonicap
      16 XC90 fam-mobile
    9. #7
      Feb 2016
      I had the same issue last year and replaced the door lock under warranty. Here's the thread:
      https://forums.swedespeed.com/showth...ight=rear+door
    10. #8
      Junior Member Volvolic's Avatar
      Jun 2018
      Michigan
      I ordered this for all the rubber seals on my V90CC https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1.
      You can use WD40 spray on all locks. Clean the area, spray generously, wipe off excess fluid!
      2018 Volvo V90 CC T6 Polestar'd
      What It's Like To Own A Volvo V90 Cross Country?? https://www.youtube.com/watch?v=yYbC8bg-N8c
    11. #9
      Feb 2003
      Boston
      Well. same story this morning. Same rear door too. I was smart enough to test it only after I came to work. Made a video for a service dept to show.
      06 V70R Sonicap
      16 XC90 fam-mobile
    12. #10
      Sep 2019
      Quote Originally Posted by Papa_Kirlo View Post
      Besides water strips fix (TJ 31542.7.0), Volvo has released plastic caps for rear doors locks.
      Its mounted on locks and protect it from water that can freeze, and as a results - doors cannot be locked, or unlocked until car placed to warm place. Especially during winter time...
      Parts numbers are:
      32131416 - cover for left rear door lock
      32131417 - cover for right rear door lock
      I did it for my ex-XC90 MY16 for both doors, ordered it and asked dealer to mount.
    13. #11
      Feb 2003
      Boston
      Quote Originally Posted by KentXRS View Post
      Parts numbers are:
      Ha, I googled the part number, saw the post on drive2ru and was thinking to register there to ask a couple of questions.. Then I realized it was your post. Gonna send you a message as it's not related to this post
      06 V70R Sonicap
      16 XC90 fam-mobile
    14. #12
      Sep 2019
      yep, that's me.
      Covers parts number I got from dealer, as there was lots of claims on lock.
      Although there is no information elsewhere, even in google...
    15. #13
      Apr 2017
      I had a 2016 XC90 D5 and a 2017 XC90 T8. Everything on those cars tends to freeze in even mild weather. Doors - especially back doors - fuel door, even the little door for the charger on the T8.
    16. #14
      Nov 2016
      Angry frozen door lock repair refused
      I am super upset with Volvo and/or my local dealer. I had this problem with both rear doors being unable to latch in very cold weather in December. I called to report the problem and said that I suspected the problem was this issue with the water getting in and freezing the mechanism and I convinced the service advisor to order the cover parts listed in this message. It took weeks for them to arrive from Sweden and when they did, I made the appointment for yesterday. The service advisor I'd made the appointment with was out yesterday so a different service advisor handled my service yesterday. The car was in for the day and at the end of the day, they told me they refused to do the service. They said there were no error codes stored and that the door latches are working fine. Well, no [bleep], this is a problem related to freezing water, it's 45F degrees out, and the problem happened when it was 5F. And how would the car have known there was an error - it just thought the handle was being held open. They said I need to bring the car to them while the problem is happening which is challenging because the sheer act of driving the car to them would warm it up - that is if I could drive the car with the rear doors flinging themselves open. So the only way to truly get this resolved is to monitor the weather forecast, leave my car overnight at the dealer on the right night, and hope that the intermittent problem happens the next morning? And this is not a minor annoyance with a interior feature - this is the safety of kids sitting in the back seat having their doors fling open after they thought they were closed.
      Besides venting (and thanks for reading), I am really interested to know how anyone else has gotten this repair done? And is it Volvo's policy to not try to proactively fix things even when a customer describes a problem? The service advisors said they believed me that it happened. They just said Volvo wouldn't let them do the repair if they didn't see evidence of the problem - is that for real? Even in a case when it is a safety issue (and seemingly due to a design flaw)? Should I try a different dealer even though the next one is much further away or would they say the same thing? Any tricks to getting Volvo to do the repair? Is there any customer contact point that I could make the case that Volvo needs to do the repair and get the dealer that refused to do it in trouble?
    17. Remove Advertisements
    Similar Threads
    1. Replies: 1
      Last Post: 01-23-2018, 09:41 AM
    2. Cold weather boost vs. warm weather boost
      By blazen244 in forum 850 (1993-1997)
      Last Post: 12-30-2013, 08:51 PM
    3. Replies: 0
      Last Post: 12-11-2011, 11:19 PM
    4. Weird Cold Weather Starting Issue - Fuel Related. Thoughts?
      By dieselcruiserhead in forum S70, V70 & V70XC (1998-2000)
      Last Post: 01-12-2011, 12:12 AM
    5. Hard Starting In Morning -- Cold Weather Related? -- 2004 V70
      By smith401 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 10-04-2010, 03:32 PM
