How to stop FM Radio being the default audio when starting car.
    Results 1 to 11 of 11
      Sep 2019
      I typically use my Phone and Android Auto to listen to Spotify in the car. Once I plug my phone to USB and select Android Auto on the Census screen I have no issues playing audio.
      My issue is that when I turn the car on (before I have a chance to plug in my phone) the car starts playing FM radio.
      Please advise how to disable this. I'd like to have it play nothing when I get in.
      Thanks in advance everyone.
      2019 S60 T6 R-Design w/Polestar
      Junior Member Kamil's Avatar
      Nov 2019
      If secondary audio source is not available it will default to radio.
      Not sure if you have a way to disable this. Did you check the operation manual? I still haven’t got the car so did not read it yet
      2020 V60 CC
      IG _kademan_v60cc_
      Sep 2019
      Quote Originally Posted by Kamil View Post
      Gonna take a deep dive into the 625 page (not joking) manual for the car...
      https://volvornt.harte-hanks.com/man...US_TP26449.pdf
      luckily the Audio segment is ONLY 50 pages
      SwedeSpeed.com
      Nov 2019
      I always read my few times and surprised at stuff I learned every time.
      If you find it post up for others .
      Thanks
      2020 V60 CC
      IG _kademan_v60cc_
    7. #5
      Junior Member TomOldi's Avatar
      Sep 2014
      Switzerland
      Unlock Driver Profile
    8. #6
      Junior Member fortierj's Avatar
      Jun 2019
      Western MA
      I know you're Android, so this may be irrelevant, but I set up a shortcut in iOS that solves this. Once my phone connects to Carplay (once I plug it in to the USB) an automation runs which starts playing Apple Music. If I undock the phone, it does not default to the radio--nothing comes in over the speakers the display just tells me to connect a compatible device (for Carplay/Android Auto). Also when I first start my car it plays nothing if I don't plug in my phone and I have to manually select the radio for the radio to play.
      Another thing that might play a role is I have no phone saved in bluetooth, since I use Carplay. Hopefully this helps.
      2019 V60
      T6
      Pole*
    9. #7
      Sep 2019
      Will try these suggestions and report back. Thanks guys.
    10. #8
      Aug 2013
      We have several Volvos with Sensus. I now have a 2020 S60 Inscription/Polestar, and have this same issue:
      If I listen to a source outside of CarPlay, such as Sirius/XM, turn off the car, come back and start it, it defaults to SiriusXM
      However, if I'm listening to music through CarPlay, turn off the car, and return later, it defaults to FM. I've tried locking and unlocking the driver profiles, and it doesn't make a difference. Yet on our two 2018 XC60s (and my prior 2017 S90), this would not happen - it would never default to FM.
      I post on this forum about this same issue and was told about the profiles. I even started a new one and it still happens, whether the profile is locked or unlocked. One poster said to reset Sensus by disconnecting the battery and then reconnecting it - I have not tried that - I need to know if that will wipe all my settings, such as Sensus settings and seat memory settings (something I want to avoid).
      If you figure it out, please post!
    11. #9
      Aug 2013
      Quote Originally Posted by DudeDad View Post
      One more thing - just played around with different profiles, etc. If you switch from CarPlay to SiriusXM before turning the car off, it seems to stay on SiriusXM; if you are listening to music through CarPlay and turn the car off, it will go back to FM when you start the car later. It does NOT do that on our 2018 XCX60s!
    12. #10
      Sep 2019
      I tried everything mentioned and still after playing music using Spotify via Android auto and removing my phone and the audio stopping.....next time I get into the car the radio is playing...so annoying!
    13. #11
      Aug 2013
      The only solution I have found is to go back to the Sensus media before turning the car off and removing my phone. So basically I go back to SiriusXM before removing my iPhone. I need to remember to do this each time. Frustrating since our two 2018 XC60s don’t have this issue.
    14. Remove Advertisements
    Similar Threads
    1. *VDASH* Disable the Auto Start Stop (ASS) function default.
      By macnasien79 in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 03-13-2019, 06:33 PM
    2. Replies: 7
      Last Post: 05-19-2018, 04:50 PM
    3. Radio resetting to default stations
      By Potomac Kayaker in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 10-12-2015, 12:26 PM
    4. 2015 Drive-E XC70: unable to set default Start / Stop mode to OFF
      By poussart in forum V70 & XC70 (2008 - 2016)
      Last Post: 05-26-2014, 09:12 AM
    5. Replies: 4
      Last Post: 06-03-2005, 09:34 AM
