Catalisator gone or just O2 sensors ?
    Results 1 to 13 of 13
      Member Hong Kong's Avatar
      Aug 2006
      sLOVEnia Country EU
      Dear friends, tell me your opinion and experience please. I made 317.000 km and catalisator is old 13 years...used last years very bad petrol that they sell here in Serbia country and last months Shell opened and i fill only VPSR V power super race 98 as they dont have 100 Octanes like in Austria Slovenia ect...
      Last 2 years orange triangle lamp and engine pop out.
      I reset with instrument and after long drive pop again.
      Mechanic check also with Vida and say Catalysator...
      Now tell me is maybe only O2 sensors front or rear to change or to buy new catalysator and sleep well?
      Car on technical check for exhaust gases pass without problem not even near limits ect.
      What you suggest? Thanks in advance for answers.
      Here is photo and when i cancel also
      ECM 400 C
      p.s. dont worry about other as i have tuning software chip changed this work years well from 2013.
      Other dtc i deleted and solved small oxidation on connectors.
      Sent from my SM-G950F using Tapatalk
      XC90 2.5T VOR AWD 2006 320.600 km
      Proudly GUINNESS WORLD RECORDS and VOR XC90 2.5t Nr. 615 from 1574 Volvo's 31.03.2019 UK
      + 5704 km longest distance traveled to #Volvo600 UK meeting.
      Member ggleavitt's Avatar
      Jun 2005
      Seattle
      Fault section from VIDA for this code-
      284: ECM-400C Three-way catalytic converter (TWC) efficiency, bank 1. Signal too high, B5254T2
      Check the components and wiring
      Check the intake system for air leakage.
      Check the exhaust system for air leakage.
      Check fuel and residual pressure.
      Check the compression of the engine.
      Note! Try a new heated oxygen sensor (HO2S) if the above fault-tracing does not remedy the fault.
      I apparently replaced both O2 sensors on the 5 cylinder in 2012 per my maintenance records, cannot recall what code was thrown to prompt this and think I did both since I was doing one. There is a mention for damaged cat in the code definition but for troubleshooting it is not noted.
      ** Alternate Bosch PNs for F/R sensors in this post- https://forums.swedespeed.com/showth...a-2004-XC90-T5
      2005 XC90 B5254T2 019 201k
      2008 XC90 B8444S Sport 452 132k
      Aug 2006
      sLOVEnia Country EU
      Thanks.
      Will check one by one.
      Pcv done all and clean very clearly.
      Than will replace both O2 sensors and report.
      Thanks.
      Maybe i have clue...after engine exhaust there is metal flexible net around exhaust tube...maybe this can be broken or leak...will check. Thanks.
      SwedeSpeed.com
      Aug 2006
      sLOVEnia Country EU
      This code is pop also in Vida and this simple instrument.
    7. #5
      Aug 2006
      sLOVEnia Country EU
      One question again.
      As my vacuum pump burned and Im waiting a new one can this can be reason that this error pop out as i found here on posts that this can cause such a error;
      "Vacuum leaks either intake or exhaust" can be reason.
      As vacuum pump work for brake assist...is also connected to vacuum intake hoses...can this be reason?
    8. #6
      Air leak at the flex pipes would be the more reason. It would be introducing oxygen that shouldn’t be there. At the age and mileage of yours, I would inspect those well.
      2010 XC90 V8 - 140k miles
      2012 S60 T5 - traded with 177k. Lost compression on cyl 5.
      2009 C30 - Totaled. It ate a minivan at 35mph.
      2006 S40 - at 217k it was tired and needed too much.
      2008 XC90 3.2 - traded with 220,780 miles
    9. #7
      Aug 2006
      sLOVEnia Country EU
      Ok you mean first flexible part of exhaust. This one. If this is broken I will
      change complete exhaust pipe with catalisator its time...
    10. #8
      Aug 2006
      sLOVEnia Country EU
      SOLVED !!!
      Not even O2 sensors or Catalysator was fault but bad petrol that i use here in Serbia. Grrrrrr.
      I test now driving to Slovenia and put 95 and even 100 octan high quality controlled petrol and reset few times all sensors error and catalysator Dtc.
      With 2 full tanks first with bad quality crap they sell in Serbia country lamp and Dtc was ON.
      Than i drive to red lamp tank almost empty reset all Dtc fill 95 Octan and drive 700 km stopped few times no problems.
      Repeated with 100 Octanes fuel half tank no problemms.
      Fuel is crap quality. I even used new Shell here obviously they fill from NIS bad petrol. Grrrrrr.
    11. #9
      Aug 2006
      sLOVEnia Country EU
      Im still driving over 600 km with good petrol and no Dtc or orange lamp or engine lamp on. Soon will finished this tank and will prove again with Serbian fuel.
      Anyway both O2 sensors have 318000 km almost 13 1/2 year and in spring time we will put a new one. Catslysator can wait if this prove test confirmed isuee.
    12. #10
      Junior Member generic_volvo_driver's Avatar
      Nov 2017
      British Columbia
      For fun, take a non-contact thermometer and measure the temperature before and after the CAT. That will give you a good baseline how well your cat is running. I'd also set a baseline like start up on 10*C day, drive 3km, return, measure temperatures.
      https://www.youtube.com/watch?v=psIFUZaLLaM
      Me:
      2013 Volvo XC90 AWD Platinum (Caspian Blue Metallic, climate package, walnut inlays + wheel, BLIS, active bi-xenon headlights) 150k km
      2012 Volvo XC60 T6 AWD Platinum (Technology package, climate package) 30k km
      1988 Nissan 300ZX Turbo (2+2, T-top, Aztec Red, collector plates) 80k km
      Family members:
      2015 Volvo XC60 T6 AWD Platinum (Technology package) 96k km
    13. #11
      Nov 2017
      British Columbia
      Outlet of CAT should be much hotter vs the intake.
      https://www.youtube.com/watch?v=9VZ5K8n5jj0
      Me:
      Family members:
    14. #12
      Aug 2006
      sLOVEnia Country EU
      Thanks.
      Will check and report.
    15. #13
      Aug 2006
      sLOVEnia Country EU
      Ok after I consumed all 75 liters of high octane 100 fuel good quality and control filled in Slovenia now i put
      local petrol 98 from Shell in Serbian town Novi Sad...I didn't made 2 km orange light
      and engine light pop out - scanner say: Catalytic converter low bank bla bla.
      Now is 100% prove that this crap petrol is reason. And I wanted to change both O2 sensors with new
      and even catalytic converter new cost around 900 Euro...
      As car will have in June 2020 - 14 years I plan to change catalytic converter and both O2 sensors
      but in spring time.
      Just to show you that bad petrol can produce this DTC error.
      With Slovenian petrol I made over 100 km more than with Serbian Shell. Tested many times
      full tank max was to tap 84 liter enter.
    16. Remove Advertisements
    Similar Threads
    1. O2 sensors the hard way (lesson learned)
      By mmcrrc in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 06-30-2010, 12:31 PM
    2. Seats and O2 sensors
      By 02s60 in forum General Volvo Discussions
      Last Post: 12-11-2006, 07:45 AM
    3. Interesting Basics on Wideband, Narrowband O2 Sensors, & A/F Ratios
      By ArtVandelay0023 in forum R Forum (2004-2007)
      Last Post: 11-29-2006, 11:56 AM
    4. Volvo 850 flywheel adaptation for evap system and O2 sensors
      By haven349 in forum New Member Forum
      Last Post: 11-09-2006, 05:01 PM
    5. Replies: 0
      Last Post: 06-24-2004, 02:28 PM
