XC70 lower door cladding removal
    Results 1 to 9 of 9
      Oct 2010
      Anyone done this? Is it the same as on a V70, e.g. three Torx 25 bolts and a couple of snap in plastic holders along the bottom edge, or are they glued or otherwise fastened up higher on an XC70?
      Thanks
      Apr 2018
      They are glued and have 2-3 t25s under the panel I believe. I’ve done it on an xc70. Just be careful not to bend or flex the plastic too much as it’s easy to do if you miss a t25.
      Oct 2010
      Sounds like XC70 and V70 doors won't interchange then
      Feb 2016
      Quote Originally Posted by zak View Post
      Doors are the same. Front doors will also interchange with a P2 S60 (NOT rear doors though)
      Oct 2010
      If the lower door moulding is glued along its upper edge, along with internal T35 bolts as Boosted suggests, then yes it may physically swap but won't look right, won't match the rocker moulding.
      Feb 2016
      The lower mounting points on the door are the same for the mouldings (V or XC), top of the XC moulding is held with double sided mounting tape. XC moulding goes right on a V door with no problems. If you remove it carefully you won't even need to replace the mounting tape. Did this on my sister's XC, zero issues
      Oct 2010
      Thanks. Am trying to go the other direction, mount XC70 rear doors on a V70, with V70 lower door cladding.
      Suppose the double sided adhesive can be removed, though adhesive remover is hard on paint. Is it fairly narrow area?
      Feb 2016
      The adhesive tape is narrow. Every XC moulding I've removed, the tape has stayed attached to the moulding, none left on the door. If some stays on the door you'll likely be able to roll it off with your fingers. You may end up with a slightly visible line where the tape was because the paint under it has never been exposed to sun/elements
      Oct 2010
      Thanks, this opens several options locally, appreciate the info
    12. Remove Advertisements
    1. P4 xc70 p4 xc70 p4 xc70 p4 xc70 p4 xc70
      By CrossingCountries in forum V70 & XC70 (2008 - 2016)
      Last Post: 10-09-2015, 11:21 AM
    2. Bent Lower Cladding
      By djeremya in forum V70 & XC70 (2008 - 2016)
      Last Post: 11-26-2012, 01:26 PM
    3. Painting the lower cladding/skirts/moldings on the S40's - Price???
      By smartbabo in forum S40 & V50 (2005-2012)
      Last Post: 12-04-2005, 05:31 AM
    4. XC cladding
      By COMark in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 04-12-2003, 11:03 PM
    5. What to use on body side cladding on XC?
      By FrankG in forum The Detailing Forum
      Last Post: 10-16-2002, 12:13 PM
