2012 c30 audio upgrade help needed.
    Results 1 to 11 of 11
      Aug 2019
      Ive got a 2012 r design with the “high performance” audio. The sound, for lack of better terms, just sucks. Has anyone successfully added something like a mini dsp or amp/dsp combo to a P1? I was looking at a few different units, but haven’t been able to find anything install related on a P1 other than jus the upgrading the speakers or installing a bluepower kit.
      Member AutoGeek's Avatar
      Jan 2008
      MD, Howard Co.
      If you want more power you can swap the amp for one from a Premium Sound (or DynAudio) P1. They are plug and play. VIDA will give an error for the center speaker open but no other issue.
      2005 V50 T5 FWD M66 Passion Red (Radio Flyer) Bilstein HD, ECU spacer, Snabb Turbo Pipe
      1998 V70 NA - Sold, 2002 S40 1.9T - R.I.P., 2005 V50 T5 - RIP
      Remember kids, Speed doesn't kill ... impact does!
      Jun 2018
      try turning the fader to the full front
      it is the rear speakers that make the whole system sound muddy
      2008 Volvo C30 R-design red manual
      SwedeSpeed.com
      Member Body Massage's Avatar
      Aug 2008
      Bellingham, MA
      Quote Originally Posted by potatochobit View Post
      Yeah, I sent my balance forward. The rear speakers, at neutral setting, overpower the fronts. And they don't quite have the same high capability.
      2005 V70R
      2010 C30 R-Design
    7. #5
      Mar 2016
      Washington, DC
      I am running a JL Audio Fix86 from the OEM headunit, the Fix86 signal feeds a JL Audio RD900/5. My speakers are all Focal Flax Components (front and rear). The sound quality is amazing, could not have predicted how much of an improvement it actually made. For bass I run a JL 10” sub.
    8. #6
      Jan 2008
      MD, Howard Co.
      I bet that does sound nice. I'm curious how you mounted the front tweeters?
    9. #7
      Mar 2016
      Washington, DC
      Quote Originally Posted by AutoGeek View Post
      I bet that does sound nice. I am curious how you mounted the front tweeters?
      The shop mounted the tweeters in the OEM location. I believe they hollowed out the existing tweeters and then molded in the new ones. Everything is completely hidden, so it is near impossible to tell that anything has been done to my C30.
    10. #8
      Mar 2016
      Washington, DC
      Just noticed that you are in the DMV. The shop that did my C30 was Unique Audio in Lorton, VA. Great group of guys whom I would definitely recommend.
    11. #9
      Member
      Mar 2011
      Miami, FL.
      Curious did you have the sub mounted in spare tire or kust a box?
    12. #10
      Mar 2016
      Washington, DC
      Quote Originally Posted by psy View Post
      It is actually a JL Box ... as I am still deciding if I want to remove my rear seats. If I do remove the rear seats, then I will go for a custom floor which will hold the sub (I might even add a second sub).
    13. #11
      Junior Member nuge's Avatar
      May 2015
      DTLA
      Do you have the model number for that JL box?
      Sent from my SM-N950U using Tapatalk
      2018 Volvo V60 Polestar
      2015 Audi Allroad
    14. Remove Advertisements
    Similar Threads
    1. Replies: 9
      Last Post: 07-04-2016, 05:05 PM
    2. 2012 C70 t5 Audio Upgrade
      By brumledb in forum Car Audio, Video & Mobile Electronics Forum
      Last Post: 05-15-2015, 10:59 PM
    3. Replies: 2
      Last Post: 11-15-2011, 06:45 AM
    4. audio system install..HELP NEEDED PLEASE!!!
      By HaZed in forum S40 & V50 (2005-2012)
      Last Post: 05-30-2011, 10:54 PM
    5. 1999 S80 Audio Upgrade Help
      By zorz in forum S80 (1998-2006)
      Last Post: 12-31-2008, 07:10 AM
