Any T8’s having issues with Parking Climate now that winter is here?
    Page 1 of 2 1 2 LastLast
    Results 1 to 35 of 56
      Member partridge's Avatar
      Mar 2005
      Maryland
      Mine has stopped working completely.
      Service says they can’t find anything wrong and are fobbing it off on VOC.
      I’m nearly 100% sure this is not a VOC issue.
      Current:
      Linnéa: 2017 Osmium Grey XC90 T8 R-Design Vision/Climate/Conv/Air/B&W/Booster
      Deceased:
      Inga: 2004 Titanium Gray/Gobi S60R - Navigation, ipd tune, hood vent, rear window spoiler
      Astrid: 2015.5 Sapphire Black/Nubuck XC60 T6 AWD R-Design Platinum BLIS Climate Polestar
      Feb 2018
      USA
      Nope, mine's working fine this 2nd winter via manual turn-on in VOC app and plugged into Level2 work charger and 220V home Turbocord (what came with the Volvo) charger.
      2019 XC90 T8i (OSD 2018 July)
      “Scientists study the world as it is; engineers create the world that has never been.” - Theodore von Karman
      Member
      Dec 2017
      PNW
      You can set up a timer to start parking climate and show them it fails too. I don't think it is VoC related.
      Have to push them to get Volvo engineer to help. Mine has random failures this winter and maybe it will always fail next winter.
      If we can get to know how it detects conditions for failure, we can try some tests to help diagnosis. But maybe technicians here don't have details either.
      From users' point of view, the factors here are just temperature readings, air heater, fan, seat and steering heater. I can't think of anything very difficult to inspect by dealer. I read about report here that high voltage heater could fail, but this should be able to see by VIDA scan.
      Fusion · Red · T8 · XC60
      Rolling, Fusion Red - 2018 XC60 - T8
      Running to retire, 2000 V70XC 237240 miles [2020-07]
      SwedeSpeed.com
      Junior Member bunnny's Avatar
      Jun 2017
      Brooklyn, NY
      Mine worked just once upon purchasing and then...never again.
      Volvo for Life
    7. #5
      Member Gary-16-Xc90's Avatar
      May 2015
      Twin Cities, MN
      Preconditioning via Parking Climate on my MY16 XC90 has been working fine, particularly if the timer was preset or was started manually.
      I experienced a brief intermittent glitch with the timer being set on VOC last year but it resolved itself.
      I ended up deleting the timers on VOC and set them via Sensus.
      I recall there was a TJ on this a year ago or so.
      Anyway, mine works fine and has been 100% in 2019.
      2016 XC90 T8 Inscription | US 10/2015 Build| Crystal White | Blonde | Blonde | B&W | Air | HUD | Convenience Vision Climate | PAII + Mitigation Upgrades | Xpel + Gtechniq Ceramic | 3M Crystalline 50% Tint, 97% UV Rejection, 60% Solar Heat Rejection | 20" A/S & 22" Summer | Tow | Last TSU installed 10 Sept. 2020 | 47K miles | MPG 31.8 Lifetime including transcontinental trips, regional trips and towing
    8. #6
      VOC / Connectivity Expert
      Mar 2017
      If you use timers... Delete everything and only set them from the car.
      Precondition only reliably works on a 220v plug, despite intermittent success with the 110.
      If you are unplugged, use engine remote start, NOT precondition.
      Any comments made are of my own opinion and not that of my employer!
    9. #7
      Member
      Dec 2017
      PNW
      Quote Originally Posted by WhoaVolvo View Post
      I doubt it matters how the timers are set, from VoC or in car. Any normal software won't be designed with any difference between these two cases.
      The timer set from VoC works as it tries to to start parking climate at the preset time.
      Well anyhow I can try delete times and add them back in car to see what happens.
      Mine worked fine in past two winters. Shows problem this winter. Plugged in on 240V overnight. Charging is all good.
      So it is possible it is not robust somewhere inside, being it temperature sensor, high voltage heater, or whatever.
    10. #8
      May 2015
      Twin Cities, MN
      Quote Originally Posted by FusionRedXC60 View Post
      The original issue was, in fact per the TJ, with the prescheduled timer on VOC. I recall that the TJ made referenced to a subsequent update for SPA XC60s. You may want to get a 3-day subscription and read the TJ. I do not have it handy but there is a thread at on MY16+ XC90 subforum.
      I will post if I find it.
    11. #9
      Mar 2005
      Maryland
      The issue with the timer specifically says that the timers don’t work but Parking climate works when manually started by VOC or in car, and basically said that the service centers should wait for an upcoming software update to address it.
      Mine is a different issue. Parking climate is completely inoperative. It starts up enough that VOC says it’s running then it errors out and shuts down. Doesn’t matter how it start it. Timer, manual, in car or out. It doesn’t work.
      Additionally I don’t seem to have heat when running on battery power.
      I think I may have to try another dealership. This one claimed they were having trouble troubleshooting because they had nowhere to charge the car.
      Current:
      Deceased:
    12. #10
      May 2015
      Twin Cities, MN
      Thanks for clarification.
      Do you have the “Additional Heater” option turned on in Settings -> Climate (or My Car / Volvo)?
      If so, then I recall an issue with the Electric Heater which I wonder could be an issue. I wonder if the HVSC and/or IGM needs to be checked out. (Those fixed my issue in 2018).
      Definitely, a trip to a competent hybrid service center would be in order. Not having access to an EV charger would raise a red flag (to me).
    13. #11
      Member
      Dec 2017
      PNW
      Quote Originally Posted by partridge View Post
      When start in VOC I think it always shows running first and the error shows up a minute later.
    14. #12
      Mar 2005
      Maryland
      Quote Originally Posted by Gary-16-Xc90 View Post
      If so, then I recall an issue with the Electric Heater which I wonder could be an issue. There is an acronym for it but my memory needs to be refreshed.
      I had the HVEH replaced this spring.
      Made an appointment at a different dealer. He seemed kind of surprised that they didn’t have a T8 charger at the other shop.
      Current:
      Deceased:
    15. #13
      Member
      Dec 2017
      PNW
      Tried several times this morning from VoC while standing next to the car. There are two failure results:
      Usually VoC shows it is running, I can hear a little sound of electronics running buzz, and fluid hissing. After several seconds all stopped and it reports temporarily unavailable.
      The other kind of failure in VoC is: failed to start parking climate, which seems more like communication failure with the car.
      The failure when starting by timer is always the first kind: unavailable temporarily.
      I also manually deleted all timers on Sensus screen and re-added them slightly differently. VoC app doesn't show the updated timers to me.
      Just tried the timer and see same failure. 50F today. Will see again tomorrow. I feel the colder the better chance to see it working.
    16. #14
      Ours works perfectly. When it doesn't, I’ve realized it’s specifically due to certain EVSE that don’t “wake back up” after it had finished charging. It seems some don't wake back upon demand/request from the EV. So now I go to specific EVSE in the parking garage that I know will delivery the juice when I need them to start up again to condition the car interior and battery after they've detected a full charge earlier in the morning. It also works consistently at home with our Home ChargePoint.
      You may want to see if it's EVSE related. It's especially obvious to me when the VOC app says "Running" for Parking Climate and then after a little bit it comes back saying something like paused/interrupted (forget the message)..
      2005 Boxster - EuroDelivery Atlas Grey (Street: Boxster S 18"/Track: Cayman S 18")
      2010 XC90 3.2 R-Design AWD - OSD Ice White (Winter: Vulcanis 19"/Summer & Off-Road: Panacea 18")
      2017 XC90 T8 R-Design eAWD - OSD (Pole✦ envy) Passion Red (Vision|Convenience|B&W|Climate|HUD|Air 4C|Lighted Running Boards|Tow|Center Booster|iPad|Protective Plate...) w/ChargePoint Home
      Sold in 2018: 2001 V40 1.9T - OSD Atlantic Blue (Summer: Galactica 16"/Winter: Spectra 15")
    17. #15
      Dec 2018
      My Parking Climate has always worked perfectly for the last two years until,very recently when it fails all of the time after about 2 minutes where it states ‘Running’.
      Strongly suspect this is some type of new OTA software glitch.
      Bish
    18. #16
      Dec 2018
      So, right after I posted the above I decided to delete the app from my iPhone after I had logged out of the app. I then downloaded and reinstalled the current app from the App Store, and ‘Parking Climate’ is now working again. I’ll check again in the morning when it’ll be much cooler in the garage.
      Bish
    19. #17
      Member
      Dec 2017
      PNW
      Quote Originally Posted by thebishman View Post
      Bish
      Interesting, I would try this too but my parking climate timer still fails and seems unrelated to VoC app.
    20. #18
      Sep 2019
      So Cal, USA
      @thebishman, are you running iOS 13.2.2? I ask because the latest dot update from IIRC last week had major fixes for background apps — I was having numerous unexplainable problems with (non Volvo) apps that didn’t consistently update and seemed to get out-of-sync with their counterpart via the WWW if I let them go to the background or I stopped using my device, until I brought them to the foreground again — still not sure all that is resolved, but my situation is much improved. I too was fixing problems with the “delete & reinstall trick”, but my issues were returning after a short while until .2 came out.
      ...and is everyone with problems running on iOS, or do we have some Android folks with problems too? So many possible places where problems like these come from. While I don’t know anything about Volvo in this regard (yet), I am certain with my trials & tribulations with Lexus and Tesla, parts of the equation when we ran into problems were sometimes on the device (OS level, HW, and Android vs iOS) or app itself, part in the vehicle, and other times related to communications and in more than one case, the mfgr code that interfaced between the app and vehicles... we could eventually surmise what the culprit had been if we got a new app version and things resolved, or new firmware on car (Tesla) and problems went away, or magically everyone starting working again when it was likely the mfgr fixed something “in the cloud” under their control. Lexus US at one point years ago literally had a PC under someone’s desk back east where all their VoC-equivalent app requests were received and sent to vehicles — not super robust IMO, but that’s what it was for some period of time... Yikes, huh?
      Bert
      Present: ‘20 XC60 T8 Inscription
      Past: ‘15 Tesla S90D; ‘14 SLK250; '13 RX450h; ‘09 335i; ‘06 RX400h; ‘02 SC430; ‘99 RX300; ‘95 SC300; ‘91 Legend...
    21. #19
      Mar 2005
      Maryland
      The thing is, you can’t blame it on VOC when the internal car timer fails and when a manual precondition request via the in car settings in Sensus also fails.
      Current:
      Deceased:
    22. #20
      Member
      Dec 2017
      PNW
      Today I just found something new. Reinstalled VoC app on my Android phone and it doesn't help of course. I started in VoC a few times and all failed. Then I drove the short dropoff trip and came back, parked and plugged in. Then I tried start in VoC again and it worked. If this is a pattern then looks like something didn't wake up fully after parking/charging overnight.
    23. #21
      Junior Member taofen_wang's Avatar
      Dec 2015
      Canada
      Mine has worked for few years after the HVCH (high voltage coolant heater) replacing. The software issue (Many failed attempts till it returns positive message) has been fixed as well.
    24. #22
      Jun 2017
      Brooklyn, NY
      This place is and can be even more incredible platform, if someone from Volvo really actually read the outcry.
      Volvo for Life
    25. #23
      Sep 2019
      So Cal, USA
      FYI, Apple just released iOS 13.2.3 with more fixes for background app issues as I was attempting to describe upthread... Downloading now.
      Bert
    26. #24
      Dec 2018
      I am running 13.2.2 (but will upgrade to 13.2.3 tonight), and at the first attempt this morning the Parking Climate stated it was ‘Running’, then ‘Temporarily Unavailable’. I then tried Parking Climate again and it actually worked the second time. Car nice and warm when I got into it after about 20 minutes.
      I do wonder if somehow this might be related to ambient temp? As my failures all seem to happen when it’s really cold.
      Bish
    27. #25
      Member
      Dec 2017
      PNW
      Bish
      My failures are often above 50F. If at 40F I see more successful cases.
    28. #26
      Mar 2005
      Maryland
      Bish
      I actually got it to work today using this method.
      I reset my timers and I'll see if it continues to work.
      I'm scheduled to go into the shop on Thursday for this, but even if it's sorted out it's not a loss as in the interim I've gotten a Suspension Service Required message. Again.
      Current:
      Deceased:
    29. #27
      Dec 2018
      So I’m now on the current iOS and most up-to-date Volvo app and it failed the first time this morning. However it did work when I started Parking Climate a second time. Strange.
    30. #28
      Apr 2019
      Decatur, GA
      This is my first winter with my 2019 S90T8. The scheduler in the android app definitely doesn't work (for me). I set a 6am timer, save it, close the app, go back in, and it's not set. Cannot get it to save, i'll try in the car. I only have 120v/20amp charger. The one time I started the PreCon when I let the dog out it worked, took 1/4 of the charge, but car was toasty.
      I had really thought that it would be able to get heat from the electric coolant while driving (with Addl Heater turned off), but it seems they didn't put a heat exchanger in that coolant loop. Too bad.
      So I don't pre-con now. I just get in, turn the seats on, have the Addl Heater option checked and go to work on B-drive and Pure mode. I'm 9 miles to work and it takes between 1/2 and 3/4 of the charge to get there, and it's only in the 30's and 40's here right now.
      Such is life. I still like the car. I don't feel like the effort of putting in a 220v line to the carport so i'll deal with the 120v/16a charger I got to just charge it every night. I charge it free once I get to work and it gets me home ok.
      I have no chance of getting any software updates done at my dealership, i asked at several visits and while they told me they would, the car came back with "we didn't put any software on it". So I guess I won't get it till 10,000 miles which at this rate is going to be next summer. I never even got May update. I might call them and ask if I can pay for the dang 2019 updates.
    31. #29
      May 2015
      Twin Cities, MN
      ^ Does VOC otherwise work (e.g., lock, unlock)?
      As others might have suggested, you might want to delete and re-install the VOC app and then retry it.
      If that does not work, then give Volvo Customer Care to make sure that your Volvo ID, et al registered correctly. They may have you delete your Volvo ID on Sensus, re-install and try again.
    32. #30
      Mar 2017
      My XC90 T8 is in the shop right now for parking climate issues. They said the electric heater has completely failed. It is also backordered as well...lots of folks having same issues. When driving in EV mode I don’t get any heat. Only after turning on ICE do I get heat out of the vents. If you see “parking climate service required” messages, def take it to the dealer to have them fix it.
    33. #31
      Member
      Dec 2017
      PNW
      Quote Originally Posted by m0digital View Post
      Yeh, mine is replaced too. Parts came overnight. Only see "parking climate temporarily unavailable" message.
      The heater is basically an electric oven with on/off control. Don't know how it could fail in just a few years. It seems over-engineered somehow.
    34. #32
      Mar 2005
      Maryland
      Mine is in the shop right now. Heater is on backorder….
      Current:
      Deceased:
    35. #33
      Member
      Dec 2017
      PNW
      And they don't try to diagnose it in the first visit. It takes two visits for them to confirm the issue and fix it. Waste of time for both dealer and us.
    36. #34
      Mar 2005
      Maryland
      Seriously.
      First visit:
      Me: Here’s what’s wrong, how to reproduce it, what fixed it last time.
      About a week later…
      Volvo: System working as designed. Try having VOC reset your account.
      Second visit:
      Me: The other shop said it’s working. It isn’t. Here’s proof it isn’t and video of it not working and the weird sounds it makes.
      About a week later…
      Volvo: we reloaded the software. Maybe it will work now? Give it a try. It works for us sometimes.
      Third visit:
      Me: That didn’t do it. Here’s printed out posts from people who had it fixed telling you what Volvo Sweden said needs to be done to diagnose this issue. This is what you need to do. The codes don’t show up in the main computer. Please check the HVCH system directly.
      Couple of days later...
      Volvo: oh. That’s it. Yep. Definitely that. Yep. Parts are on backorder.
      Current:
      Deceased:
    37. #35
      Dec 2018
      Parking Climate has now started working almost 100% of the time for me now, so I’m assuming that it was an App/Software issue.
    38. Remove Advertisements
    Similar Threads
    1. Preconditioning for winter, T8 got message parking climate unavailable
      By FusionRedXC60 in forum XC60 (SPA: 2018- )
      Last Post: 03-05-2020, 02:47 AM
    2. T8 parking climate /on fuel?
      By Viking42 in forum XC90 (SPA: 2016 - )
      Last Post: 08-18-2019, 05:39 PM
    3. Replies: 4
      Last Post: 12-01-2018, 12:11 PM
    4. 2016 XC90 T8 no heat / no parking climate
      By rpmccormick in forum XC90 (SPA: 2016 - )
      Last Post: 12-17-2017, 08:52 PM
    5. Replies: 21
      Last Post: 09-26-2017, 09:06 PM
