Door doesn't close all the way
    Results 1 to 4 of 4
      Oct 2017
      Hey folks-
      I've got an issue where my door doesn't close all the way. It sticks out a couple of mm. I've tried adjusting the striker plate on the sill inwards, but it's inward as far as it will go. The only thread I found on the topic was this one:
      https://www.volvoforums.org.uk/showthread.php?t=204383
      That thread seems to focus on doors that are off-angle, but does touch on non-closing issues. Seems people point to the windlace as a possible culprit. But it's not clear how I could resolve this other than removing the windlace?
      I know the latch itself is a wheel that can rotate around multiple times, unlike other door locks that move to one position and then move back. Are there any adjustments in the door that could help it stay closed. I can put pressure on the door and hold it flush, it just pops back out when I let go.
      Apr 2005
      This is just an uneducated brainstorm, but from what you said, maybe you have the striker plate adjusted so far in that the latch wheel can't get to its fully latched position?
      Jun 2013
      The trick is to eliminate stuff.
      Can the door close without the latch and seal in place
      Can the door close and latch without the door seal but the latch in place?
      How worn are the hinges?
      My doors fit and latch perfect until I put the door seal in place, then they remain proud by a few mm. Going to give it a year or two before I muck with it any more!
    5. #4
      Oct 2017
      Quote Originally Posted by Weilerbach View Post
      I really thought this was a great idea and had high hopes for it. But I tried tonight and there is actually very little play in either direction. I was able to get it in about 1mm further though. I'll keep trying things. Thanks!
      Quote Originally Posted by NOHOME
      I haven't taken off the seal. It strikes me as one of those parts that once I get it off, it's going to be really hard to get back on, right?
      The hinges seem just fine, then again, they're original and the car has been in use most of it's life. I can't lift the door up and down in place though.
    6. Remove Advertisements
    Similar Threads
    1. Key fob global close will not close sunroof/shade
      By oachkatzlschowaf in forum XC60 (SPA: 2018- )
      Last Post: 05-21-2019, 02:05 PM
    2. Sunroof won't close all the way!
      By StarmanDXE in forum S60 (2001-2010)
      Last Post: 02-02-2010, 05:08 PM
    3. Replies: 41
      Last Post: 01-08-2009, 08:30 PM
    4. Trunk doesn't close w/o slamming it shut
      By Eman in forum S80 (2007-2016)
      Last Post: 06-01-2008, 06:13 PM
    5. Replies: 0
      Last Post: 02-14-2008, 03:21 PM
