Headlight wiring issues
    Results 1 to 7 of 7
      Nov 2019
      Hello from a new owner of an 08 C30! I'm new to the Volvo world but really like the car so far. The head light (halogen) went out and woah... What a mess, all the insulation on wiring inside the housing is disintegrated. Is there anywhere to get a replacement wiring harness or should I just replace the whole Assembly? If so any recommendations for where to get one? I assume this is a common issue, so I'm not sure getting a used one will be any better.
      Jun 2018
      Can you take some pictures?
      2008 Volvo C30 R-design red manual
      Nov 2019
      Here ya go. the wiring is completely trashed and needs replaced. In the 2nd photo, the insulation that's there just crumbles off the wiring as it's moved. I don't really see a way to save this outside of putting a mile of heat shrink on it. Even then, I'm not sure it's the best plan.
      SwedeSpeed.com
      Nov 2019
      Does this mean I'm the only one with this issue?
    7. #5
      Member beachnut's Avatar
      Jan 2004
      SW Florida
      No, pretty common. Mine were like that and I spent the better part of an hour wrapping every wire in both headlights with old-school cloth friction tape. Cheaper than buying new headlights, give it a go.
      2015.5 XC60 T6 Flamenco Red/Sand, Platinum, Tech, Blis - wifemobile
      2010 S80 T6 Silver/Anthracite, Dynaudio/Nav, Climate, Blis - my dd
      2005 S40 T5 Passion Red/Quartz, Dynamic Package, E46 bixenon retro - garage queen
      2005 S60 2.5T Black/Graphite, Premium, Sport, Climate - son
      2004 S80 2.5T Pearl White/Sand, - daughter
      Previous: 2005 S60 T5, 1998 V70 T5, 1996 854 Platinum
    8. #6
      Jun 2018
      a new used assembly is 200$ but be sure to check if it has the wire harness inside
      go ahead and wrap them with electric tape or like he said friction cloth and see if it works and save some money
      you can shrink tube if you want but might be a pain to disassemble each wire
      we dont want bare wires to touch each other and we dont want water getting in so check the rubber grommets too and you should be fine
    9. #7
      Nov 2019
      See what it would take to fix this, disassembly of the headlight, taping/heat shrinking each wire, cleaning and resealing the headlight assembly coupled with having referbushing the plastic lens I decided to just replace them.
    10. Remove Advertisements
    Similar Threads
    1. Replies: 9
      Last Post: 07-08-2019, 10:32 PM
    2. 🙄 wiring issues smh
      By Exxx9 in forum VCOA General Forum
      Last Post: 04-21-2019, 01:02 AM
    3. Wiring issues...determining headlight woes.
      By kguarnotta in forum P1800, 1800 & 1800ES (1959-1973)
      Last Post: 11-09-2014, 12:50 PM
    4. V50 brake issues, or maybe garage issues, or maybe just issues
      By acezero in forum S40 & V50 (2005-2012)
      Last Post: 09-27-2014, 10:49 PM
    5. Tow Wiring and Mystery Wiring Queries with Photos
      By Chris W-B in forum R Forum (2004-2007)
      Last Post: 11-08-2011, 08:10 PM
