Carplay Issues
    Results 1 to 8 of 8
    Thread: Carplay Issues
      Junior Member jre's Avatar
      Mar 2019
      Cincinnati
      Carplay Issues
      Anyone else having issues with CarPlay? Sometimes when I plug my phone in I get a connection error and sometimes I don't get an error right away but when I launch an app, it disconnects. I have to turn the car off and back on for it to "fix" it. I thought maybe at first it was an OS bug or my phone but I've upgraded the OS several times over the past few months as the updates have come out and I got a new iPhone 11 Pro Max and it persists. I think it's an issue with Sensus. It seems to happen mainly when I've disconnected the phone before shutting off the car fully (ignition off, door opened).
      Joe
      '19 XC60 T5 P* AWD R-Design
      Nov 2018
      Mississauga, ON Canada
      Take it in and get the 2.0 upgrade - I believe the May 2019 update resolved a lot of the carplay issues....
      Junior Member p07r0457's Avatar
      Mar 2019
      I'll get the Connection Error maybe once every month or two. It does require turning the ignition off and back on to resolve. Otherwise, CarPlay has been pretty solid, for me.
      Make sure you're using a QUALITY cable and that you're not pinching it when routing it out of the center console. There are two lines above the USB ports showing you the best place to route the cable past the lid.
      I have had good success with Anker Powerline+ cables.
      SwedeSpeed.com
      Mar 2019
      Cincinnati
      Quote Originally Posted by p07r0457 View Post
      That's exactly what I'm using and I even switched to a different one to make sure that wasn't the issue.
      Also, I do have the latest (it was done in July) update on the car.
      Joe
    7. #5
      Junior Member PSamy's Avatar
      Sep 2019
      Southern CT
      Apart from latest software on the car, I am using Anker Powerline II 3-in-1 cable and it works without any issue so far, I had issue with one of the local store brand USB-C cable. My wife uses Apply carplay and I use Android Auto and this cable is really useful when you have different OS phones/ connectors. Apologise for huge image , there is no support to resize the image (or I could not find an option to do so).
      2019 XC60 - T6 - R-Design - Polestar - Air Suspension W/Four-C Chassis - Advance - Crystal White Pearl - 21" R-Design Wheels
    8. #6
      Feb 2008
      Florida
      We get once in a while. Unplug phone, wait a few seconds, plugin back in. We also found that it never works if we plug the phone in before starting the car.
    9. #7
      May 2018
      Bay Area California
      Had the same problems with flaky connections, till I cleaned the charging port on the phone. Never had a problem again.
    10. #8
      Jun 2018
      Quote Originally Posted by jre View Post
      I get this from time to time. The other day my Sensus kept rebooting and the only solution was to unplug my iPhone and disconnect from carplay. That's the only time that has happened, but I semi-frequently (1-2x a month) get the connection error. For me, I've noticed it mainly with podcasts and I haven't figured out the pattern to know if it's related to when I plug my phone in, if I pause podcast before disconnecting cord/turning car off etc. I have the most up to date Sensus FWIW.
    11. Remove Advertisements
    Similar Threads
    1. install Apple CarPlay in a 2010 XC60?
      By SilverXC60 in forum XC60 (2010 - 2017)
      Last Post: 05-11-2018, 08:58 AM
    2. CarPlay Issues
      By Chioti in forum XC90 (SPA: 2016 - )
      Last Post: 06-07-2016, 08:44 AM
    3. Hands On With Apple's CarPlay Integration With Volvo
      By tmpruitt in forum Volvo News Blog
      Last Post: 02-13-2015, 06:37 AM
    4. V50 brake issues, or maybe garage issues, or maybe just issues
      By acezero in forum S40 & V50 (2005-2012)
      Last Post: 09-27-2014, 10:49 PM
    5. Apple carplay
      By Cajunblu in forum General FWD & AWD
      Last Post: 04-16-2014, 02:14 PM
