Key won't release after door locked on the P1800
    Results 1 to 5 of 5
      Awaiting Approval
      Nov 2019
      Hi,
      This is rather embarrassing, but I just got a P1800 and I don't know how to lock my "new" car door
      I turn the key 90 degree and the key won't release, I tried on both door, same thing happens.
      I did the same with the trunk and that worked fine, I don't know what I am doing wrong and really don't want to break it.
      Thanks for any helps or tips.
      Member
      May 2013
      Saskatchewan, Canada
      I can't answer your question directly; but, if you go here:
      http://volvo1800pictures.com/sweden/...in_page_en.php
      you can find copies of the original owners manuals which should clarify if there is something unusual about the 1800 door locks. There are also copies of the service manuals which is useful for a new owner.
      A 142 of course. What do you expect? I'm the 142 guy. / 1971 142 E 102 color
      Apr 2016
      Conundrum;
      I'm not sure if this answers your question, but if you insert Key, and turn it 90 Deg to lock (or unlock), you must turn it back to be able to withdraw Key again...is it possible to have previous owner show you how, or give advice if there is "a trick" to it?...and when you do get it open, lubing the ancient lock mechanics (I believe there is a hole in top of lockworks for this, otherwise a light oil with high film-strength [I like Tri-Flow for all Lock Cylinders, external and Ign Sw also!])...if things are really sluggish, removing Door Panel to get access to internals and pivots will give a big improvement also...
      Good Hunting!
      SwedeSpeed.com
      Nov 2017
      Atlanta
      Don't feel bad. I bought my car from a classic car consignment with hundreds of classics. They were stumped as well.
      Just remember - The key comes out at the same degree as when you put it in. You put it in, turn clockwise (or counterclockwise) from that position to lock or unlock - then back to the original position to remove the key.
    7. #5
      Member
      May 2013
      Its been 5 days - I am thinking that the OP may have figured this out on his own.
    8. Remove Advertisements
    Similar Threads
    1. V70R Design key & smart key locked inside (by dummy)
      By Moosallino in forum V70 & XC70 (2008 - 2016)
      Last Post: 06-26-2018, 05:29 PM
    2. Rear door ha door handle won’t open door
      By walther_atty in forum S60 (2001-2010)
      Last Post: 09-24-2017, 11:29 PM
    3. p1800: Maserati biturbo drivetrain and suspension (etc) in a p1800
      By evo_k in forum P1800, 1800 & 1800ES (1959-1973)
      Last Post: 10-19-2013, 12:51 AM
    4. Ignition Key Won't Release
      By netasp in forum XC90 (2003 - 2014)
      Last Post: 12-08-2012, 07:34 PM
    5. Gas filler door won't release!
      By stevesit in forum 850 (1993-1997)
      Last Post: 11-23-2005, 09:52 AM
