Rear Sway Bar Upgrade to “R”
    Results 1 to 6 of 6
      Apr 2013
      Toronto, Canada
      I finished the sway bar upgrade work last weekend along with a bunch of other stuff.
      Wow, the rear sway bar upgrade makes a big difference to handling. Rear ends stays low and stable around corners. Quite impressive.
      As for the front, is it possible that factory size for XC is same as “R”? I took my old one out and eyeballed size next to the one I was putting in and if it wasn’t the same it was pretty damned close. Either way, I have not noticed any handling difference at front even with new bushings in control arms. My big beef right now is that front floats around like a boat especially at take off. May have to look at replacing shocks next year as everything else has been refreshed.
      2010 V70 3.2 125,000miles
      2002 V70XC, 175,000 miles
      2004 S60 2.5T, 160,000 miles
      Oct 2016
      Guilford, CT
      Front XC70 bar is marginally smaller than a S60R bar, we're talking 1mm difference. I have a S60R bar sitting in my garage that I have little current interest in installing due to the little, if any difference it will make.
      Agreed on the rear though, made a big difference in the rear end not wandering all over the place.
      2013 XC60 T6: her's
      2008 C30: her first Volvo
      2007 XC70 Adventure: mine
      2002 S60 T5M: because it needed to be saved
      Past: 1999 V70 5sp, 2010 Mazda5, 2000 Audi A4 Avant 5sp, 1990 VW Fox 4sp
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Quote Originally Posted by LarryM View Post
      Exactly. 22mm rear makes p2 chassis neutral.
      2003 V70 T5 - Mystic/Graphite - M56LK - 197k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 291k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 174k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 238k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 212k - Sisters
      SwedeSpeed.com
      Oct 2014
      Boston
      Front sway bar is hollow on XC70 and solid on XC90, even if they are of the same diameter (or very close, I forgot). The XC90's weights like 50% more and is way more rigid.
    7. #5
      Dec 2014
      Connecticut
      Quote Originally Posted by vtl View Post
      Xc90 25mm. Others 24mm hollow. 24mm hollow acts like a 22mm solid.
    8. #6
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      That's what she said.
      Are IPD bars hollow or solid? Pretty sure they're solid.
      2005 XC70 Crystal Green | Hilton | 16T | Bad Swede | 145k mi
    9. Remove Advertisements
    Similar Threads
    1. Replies: 10
      Last Post: 04-27-2016, 03:15 AM
    2. Replies: 0
      Last Post: 07-07-2010, 05:59 PM
    3. V70R rear sway for use as S60R Anti-Sway Bar Upgrade
      By washdup in forum FWD & AWD Parts For Sale
      Last Post: 01-03-2008, 09:15 AM
    4. Replies: 10
      Last Post: 11-28-2006, 09:28 AM
