Help! XC90 Struggles to Accelerate
    Results 1 to 21 of 21
      Mar 2015
      SE Wisconsin
      Exclamation Help! XC90 Struggles to Accelerate
      Alright Swedespeed, I am hoping you can come through and give me help once again!
      2007 XC90 3.2 Awd with 122k miles
      Back story:
      I Replaced the X-pipe (which contains down stream O2 sensors and secondary cats) because the flex pipes were rusted through and mid muffler last weekend. Took it for a test drive and everything was great. My wife drove to work and home on Monday with our little one on board...and the XC90 threw a whole bunch of new issues at me which do not appear to be related to my repairs last weekend.
      Current Issue:
      I have been trying to diagnose this since Tuesday, the vehicle will accelerate normally with light throttle at low speeds, but as soon as the rpms get above 2500 the vehicle struggles to accelerate. If you jab the throttle to get it to kick down a gear and accelerate faster the transmission will drop a gear but the rpms struggle to climb. You can hear the intake sounds get deeper as it try's to get more air in the engine, but the rpms climb slowly and not smoothly. Feels like a stutter/misfire...I am not sure if one thing is causing and issue or multiple things.
      Here are the codes pulled from Vida on Monday
      The bottom codes for the manifold runner control (morning code) and misfire's (evening codes) are the new codes, the catalyst efficiency is from before I fixed the exhaust. Here is the timeline info
      Here is the freeze frame from when the Intake manifold code was set
      Here is the freeze frame for the misfire codes, since those 3 codes were set at the same time they all have the same images captured
      I have since tested the operation of the Upper Intake manifold runner control through the activation's in Vida, I could hear and feel it open and close just fine. I could not get it removed to visually see it work. I also removed the coils from cylinder 1 & 3, coils are original and visually look Ok. I also checked the spark plugs for those cylinders and they still look new (replaced a year ago). I did swap cyl 1 & 2 coils to see if the codes would change. I disconnected the battery to reset things, I have gone on several test drives, 10-15 minutes at a time. No codes have popped up but the car still struggles to accelerate.
      I took a graph screen shot in Vida of the MAF(mass air flow) and throttle postion. Gentle acceleration the 2 moved in unison on the graph. This picture is when I jab the throttle to kick it down a gear and try to accelerate, you can see the throttle opens and the MAF goes CRAZY! Is this normal to see for a MAF?
      So I removed the MAF, clean it and reinstalled it. I received the same results. I unplugged the MAF and the car stalled. I restarted it and it had a very lumpy idle. I drove it and experienced the same struggling of acceleration.
      So I ran another graph, this time showing MAF (blue), Throttle position (black), Fuel Pressure (red), Intake manifold pressure(green), and Fuel pump duty cycle(purple)
      Here is a graph of very light normal acceleration, everything appears to be good...
      This one shows deceleration and then a jab of the throttle again to accelerate. Throttle position goes up, Manifold pressure goes up, MAF is crazy again, fuel pressure didn't really change, the fuel pump duty cycle dropped during deceleration and came back up on acceleration.
      Another shot, similar driving scenario, similar results
      Anyone have any idea what's going? I have been scouring the internet all week for answers. Everything I have read any of these things could be the issue..bad MAF? Bad Coils? Bad intake manifold runner control? Bad Throttle Body? Vacuum leak? Bad thermostat causing the head to get hot and ruin the coils? Bad Fuel Pressure Sensor? Bad Pem? Bad Fuel pump? Crankshaft position sensor? Cam solenoids?
      I will add no additional codes have popped up yet, even though it drives so poor. The Short term and long term fuel trim appear to be within range as do the O2 sensors.
      My wife and I have been car pooling all week in the VR, but I need to get the XC90 back on the road ASAP
      Thank you for your help!
      Check out VikingSpeed's V70R Adventure
      2004 V70R M66 Titanium Gray/Nordkap "Kula" (his) | EST exhaust, 18" Enkei RSF5
      2003 Ford SVT Focus 3dr "Pumpkin" (his) | 1 of 301 made in Competition Orange | 20% Tint
      2007 Volvo XC90 3.2 AWD "Tank" (hers) | Moose Decals!
      2012 Volvo S60 T5 (his) | 30% Tint | KPAX exhaust...Sold!
      Aug 2015
      I am not an expert but that mileage was about the time I had a coil go bad. Engine would stutter on acceleration. I replaced them all but it damaged a cat and I now have a permanent check engine light. I am now onto 226000 miles on my 07 without issue. Planning on changing my coils again soon.
      Sent from my LM-G820 using Tapatalk
      May 2017
      Chicago & D.C. Metro
      Great information and presentation in trying to explain things.
      It sounds like you are leaning towards a hunch it is the MAF. It could very well be and I am no expert in reading different MAFs and it has been 15 years since I last used an oscilloscope on a MAF. I do remember the erratic nature of bad MAFs, but MAF graphs can also depend on the electronic throttle position programming.
      Before ordering a new MAF insert, also change cylinder #3 coil with #6 and see what happens. So, you can also see if you will need any coils.
      Problems like this happen all the time when you replace one part. The reason could be as simple as using the vehicle more and parts that are going bad finally break. Your mileage is within the normal range of wear parts to start popping up.
      2008 XC90 3.2 AWD - 150k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Bridgestone Dueler H/L Alenza Plus 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Amazon Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
      About the XC90 3.2 - The good, the bad, and the ugly
      Upgrade front end rebuild with OEM, aftermarket, and original parts
      Ultimate Transmission Fluid Guide for the 3.2 & V8
      The better transmission JWS 3309/T-IV fluid for your 5 or 6 speed
      Strut Recommendations based on your specific XC90
      SwedeSpeed.com
      Member Hong Kong's Avatar
      Aug 2006
      sLOVEnia Country EU
      Measure also fuel pressure and when is the last time that you changed fuel filter? Also fuel control module can cause similar problems. Hidden under rear right wheel under splushing material. Maybe different on your car. We talked about this module here will find a post.
      1. Change fuel filter first if never changed than we see if change something.
      2. i have almost 14 years coils original and changed only 1.
      This problem can be also bad harness connectors Pin oxidation on coils - i changed all cables last year and solved.
      Now its time for O2 sensors. Both.
      Please try first with fuel filter and report. 10 min you need to change it. 10-15 min max.
      Sent from my SM-G950F using Tapatalk
      XC90 2.5T VOR AWD 2006 320.600 km
      Proudly GUINNESS WORLD RECORDS and VOR XC90 2.5t Nr. 615 from 1574 Volvo's 31.03.2019 UK
      + 5704 km longest distance traveled to #Volvo600 UK meeting.
    7. #5
      Aug 2006
      sLOVEnia Country EU
      Cam VVT solenoids dont made such a problem.
      I had bad connector pins on new cables afyer i changed all harness they simply pop out wire from bad crimped pins and car pulling normally.
    8. #6
      Aug 2015
      Quote Originally Posted by Hong Kong View Post
      Agree on fuel filter literally took 10 minutes and didn't have to lift car. Fuel will spill though so watch the videos.
    9. #7
      Aug 2006
      sLOVEnia Country EU
      I will suggest fuel filter first. Repeat many people forget years to change it. Years litteraly over 5 and more...last one that i know the guy get so funny offers from mehanics to even change sparks ignition coils ect ect 1200 euro and was only cloddged never changed 8 years fuel petrol filter. In some countries as Serbia they sell crap bad dirty mixture of oils water un petrol ect ect...
    10. #8
      Aug 2006
      sLOVEnia Country EU
      1 bolt 10mm and push 2 clips button on hoses but before you do push valve to release pressure. use and cover with cloth to not spill petrol in face or floor.
      Bear of direction arrow.
      The small filter is used in line just to show how dirty is petrol here. This was accumulated in less than 3 months. Of course fuel tank can be after years also full of dirt but anyway this is prove. Many old petrol stations have rusted inside and brings dirts directly to our tanks.
    11. #9
      Oct 2018
      San Diego, CA.
      The fuel filter on my car hadn't been changed, so I did it for PM at 90k. I was surprised at the instructions in VIDA, which I checked for grins. It said to run the engine and then pull the fuel pump fuse until it dies! Then change the filter as Hong Kong says above. Then, refit the fuse and you're done. I don't know for sure, but it may have made the job cleaner. I was a little disppointed that there wasn't some kind of reset in VIDA for the job
      Then, when draining the filter from the inlet, there was some real serious dreck coming out. That surprised me for a US operated car. I thought all US fuel stations would filter their delivery stream.
      Also, my average mpg improved immediately, and the cat converter stink going up hill abated, too. That was actually one reason I changed it, as another poster had said that the stink went away after changing the fuel filter. I was definitely skeptical about that, before.
      2009 XC90 FWD 3.2, 2013 S60 T5
      In the past: '89 745, '91 940, '82 242, '67 122S, '67 123GT, '71 142E, '62 PV544.
    12. #10
      Aug 2006
      sLOVEnia Country EU
      No body filter on petrol stations fuel. No one. There is NO huge filtration system at all.
      Second I change filter regularly as I also first time feel huge difference in pressure of course.
      As you mention dont worry about few drops of petrol when you removing filter. Just push valve
      to release pressure. Its there for this reason. Few drops of petrol from hose and if you use
      cloth around and with finger close both sides of old filter very small petrol will pop out.
      So simple to change. Im glad to read also your experience with. Forget Vida for such a simple job.
    13. #11
      Mar 2015
      SE Wisconsin
      I replaced the original fuel filter about 4 years ago. Yes it is easy to do, however I don't think it is the issue. I did order a new MAF and 6 new ignition coils and have installed them. My MAF reading with the old one was lower at idle from what VIDA said they should have been. I can say with the new MAF that my readings at idle are now where the should be.
      I was finally able to remove the upper intake manifold runner control actuator and confirm that it is working properly (no binding, grinding, or weird noises). I also tested the throttle body actuation through VIDA, the ouputs said it was working and the values were matching, but it was really noisy while moving. It was making high pitched electronic motor noises, not sure if that's normal???
      So with the new MAF and 6 new coils installed......I went for a drive and still have the hesitation to accelerate. So when accelerating the intake makes some very deep noises like its trying to suck a watermelon through a straw....Currently I am leaning toward there being a vacuum leak somewhere in the intake. Good news is there aren't too many hoses or connection points to check, but I don't have a smoke machine to test with.
      Here is a link to the Intake Manifold https://www.volvopartswebstore.com/s...rimLevel=24666
      Anyone know if #14 is a common failure item? It is listed as a Vapor Canister Purge Solenoid https://www.fcpeuro.com/products/vol...60-s80-8653857
    14. #12
      May 2017
      Good work! This could be more than just one part, but a collection of parts that have worn over time. Just for sh**s and giggles, did you try to remove the dipstick while the engine is on to see if you could hear any vacuum noise...indicating the PCV needs replacement? At 122k miles, it could very well need replacement whether it is causing major issues with the acceleration or not.
      Having worked with other electronic throttle bodies, they can make that electric noise. The variable intake runners could contribute to the issue if they are not fully open or closed. If you slowly accelerate to a higher rpm, does it become smoother?
    15. #13
      Mar 2015
      SE Wisconsin
      Quote Originally Posted by ChitownV View Post
      I replaced the PCV box on top of the engine last year along with 6 new Volvo Spark Plugs. The old pcv box was nasty and it solved some of my oil consumption issues I had. I will say that with the actuator removed the inside of the intake manifold that I could see looked fairly clean, no signs of excessive carbon build up.
      Thanks for the info on electronic throttle bodies making noise. I will have to try slowly accelerating to higher rpms (this will require using manual mode on the transmission to hold the gear long enough), that would be a good test for the intake actuators.
    16. #14
      Nov 2017
      Auckland, New Zealand
      you've ruled out fuel, I'd check air next... also I thought the car with absence of MAF signal would fall back to some default profile so it'd run slightly rich.
      When I do my ATF fluid exchange I often disconnect the air filter box, and if I leave the MAF connected it would stall, so I'd disconnect it.. and just wrap some cloths around intake so it's not sucking random crap into the engine.. hope your issue's resolved soon!
      2011 XC90 B8444S R-Design 614 120k km RHD
    17. #15
      Mar 2015
      SE Wisconsin
      So I gave up on having the time and energy to look into this and took it to the dealership for repair. I shared with them all the information I have posted on here. I just got the call back from them and after 4 hours to diagnose it, they are leaning toward it being clogged/fail catalytic converters....which from Volvo are $2k each, and it would need 2 of them...Honestly I don't feel it is a failed catalytic converter, but I'm not sure what else to look at.
      The mechanic tested compression and it was good.
      He inspected the new exhaust I installed and put a scope through the new x-pipe to make sure no packing was stuck inside.
      He tested the throttle body and it came back good.
      They test ground wires, and the O2 sensor wires. All good.
      They said I am getting fuel, spark and air...so that leads them to believe the the Catalytic converts have clogged
      They also said it was throwing misfire codes and a code for the camshaft profile control, performance bank 1, intake A.....I will have to get a copy of the codes from them when I go pick up the vehicle
      So I am not sure where this leaves me....find a second opinion? install new catalytic converters? (I can get them off rockauto for $280ea...replacing them would not be a fun job, I see broken bolts with that), sell the car?
    18. #16
      Nov 2017
      that sounds simple enough to verify right? disconnect the cat and it should at least accelerate fine(while polluting the earth)? If that's the case I'd just replace the cat and all it a day?
    19. #17
      Oct 2017
      New Hampshire
      They should be able to measure the back pressure in the exhaust system before the converters.
      Probably totally unrelated, but mine would act like the throttle was disconnected (I know, it's electronic, but try to imagine it isn't) or would only open about 10% at random times on th first start of the day. When I replaced the steering angle sensor, the problem went away. (Actually, it's done it once in the last 2 years. Not loosing sleep over that.)
      John C
      2011 XC90 3.2 176,000 miles and counting...
    20. #18
      May 2017
      So, the one time I encountered a clogged cat in one of my cars, the car wouldn't just hesitate, it would sputter, mainly dependent on engine load, which was also related to rpms. If you blip the throttle in lower rpms or try to accelerate hard, does it sputter or hesitate? There is a difference, but the 3.2 has two banks of cats which could give a combined sputter/hesitation feeling if one cat is clogged.
      However, now looking at all the information you provided in this thread, the only thing that changed before the running problem is the post-installation of pipes and center resonator. The original secondary cats/downpipe system does not have an X-pipe. It is a 2 pipe into the center resonator and then resonator goes into one.
      Did you replace these all with aftermarket universal parts or an aftermarket bolt-on replacement? Seeing how your entire exhaust system was completely rusted, it isn't terribly out of question this could be a result of one bad primary/pre cats. If there was any restriction in the old exhaust and then you freed up flow, again, it wouldn't be out of the ordinary for the primary/pre cats on the manifolds to loosen up or fail internally.
    21. #19
      May 2017
      Quote Originally Posted by kiwiV8 View Post
      The cat he is talking about is part of the exhaust manifold. It is one unit so it cannot just be disconnected and tested on a drive. Well, unless you want a no header engine spitting some fire into the firewall.
    22. #20
      Mar 2015
      SE Wisconsin
      I just realized I never followed up on this issue. You are correct the cat is built into the exhaust manifold and there are 2 of them. each covers 3 cylinders. That is why the dealer wanted $2,000 for each plus labor! I ended up having a local shop replace both with Walker units to a grand total of $1600 installed. The car drives great now. Never would I have guessed that clogged cats would have caused those drivability issues.
    23. #21
      May 2017
      You are one of the first 3.2 owners to post about needing to change those primary (manifold) cats and has gotten them changed. Appreciate the update.
      You are also a good example of how to troubleshoot and start with the wear parts first. While getting the primary cats changed may have fixed the problem, changing all those known wear parts makes it run great and to ensure the cats don't get clogged again.
      Bravo!
    24. Remove Advertisements
    Similar Threads
    1. ABS pump/ecu Part Number Struggles (pls help) - first thread
      By C30Newbie in forum C30 (2007-2013)
      Last Post: 10-20-2018, 06:41 AM
    2. Help! help! help! My S60R struggles to start when hot
      By Ruboduncan in forum R Forum (2004-2007)
      Last Post: 03-08-2012, 08:24 AM
    3. Car struggles to start and lights flicker
      By drmonabark in forum S40 & V50 (2005-2012)
      Last Post: 01-12-2011, 09:28 PM
    4. Video Statement About Mid-East Struggles...
      By 2k2S80t6 in forum Off Topic Forum
      Last Post: 04-08-2008, 09:03 PM
    5. Replies: 31
      Last Post: 08-11-2007, 04:07 PM
