Boost levels...
    Results 1 to 14 of 14
    Thread: Boost levels...
      Junior Member blacksaphireS60r's Avatar
      Sep 2018
      Wilmington NC
      Boost levels...
      Iíve heard 14.7 roughly for stock boost numbers. The car pushes around 10-11 pounds but reaches 12 pounds on a good pull. Not sure where my loss is coming from... I have a snabb intake pipe and a stock downpipe with 3Ē exhaust and muffler from the downpipe back. I donít know if that may be a cause but I figured Iíd list them. Also looking to get a new intercooler setup and all of the piping as an upgrade... any recommendations ?
      Jun 2017
      Have you checked for leaks?
      Member LloydDobler's Avatar
      Aug 2007
      Littleton, CO
      Do88 and Snabb kits are both good and good quality.
      How is the rest of the tune up on your car? The ECU will pull boost if it detects knocking or misfiring of any kind, or if the mixture is off. Make sure all your sensors are in good shape, MAF, boost pressure sensor, spark plugs, coil packs, oxygen sensors, etc. Also run good gas of the highest octane you can buy.
      2003 C70 T5M Convertible - Eibachs, Koni FSDs, Enkei RSF5s, OBX downpipe, Snabb intake, RIP kit, & drop-in intercooler, Quaife LSD, 19T, Green Giants, 22 psi Hilton tune.
      1966 122s - Collectible project, restoration and many mods on the way.
      2005 V50 T5 AWD - Daughter's first car. No mods unless she does 'em herself.
      SwedeSpeed.com
      Member 91shelby's Avatar
      Apr 2011
      Poulsbo, WA
      What year is your R? Auto or manual?
      2004 C70 T5 AT vert 77k Black Sapphire
      2004 V70R GT 144K Silver/Nordkap
      2005 S60R M66 151k Passion/Nordkap
      2007 XC90 V8 Sport 215k Passion Red
    7. #5
      Sep 2018
      Wilmington NC
      Quote Originally Posted by 91shelby View Post
      2004 manual
    8. #6
      Apr 2011
      Poulsbo, WA
      I wonder if you're acutally limited to 11-12 being an 04 and all, I know mine was when i got it being an 04 but is an auto. I know they weren't supposedly limited on the manuals but I wouldnt be surprised if that was the case here. Check the intake pipe from the IC to throttle body, also check your PCV hoses as well.
    9. #7
      Sep 2018
      Wilmington NC
      Itís all brand new
    10. #8
      Apr 2011
      Poulsbo, WA
      This it is probably limited to 11-12, did you ever see 14-15 since buying it?
    11. #9
      Sep 2018
      Wilmington NC
      No
    12. #10
      Apr 2011
      Poulsbo, WA
      If you dont have any leaks, your ecu is not pulling timing, and everything else is good then I'd say a tune would probably correct it. I did that not too long ago and got a Hilton tune. There might be away to check and see what its set to in Vida but I'm not sure, Hilton might be able to give you some direction on that.
    13. #11
      Sep 2018
      Wilmington NC
      I plan on getting it tuned and a downpipe in the near future I just replaced the engine itís a long story I had a rod go through the block... but yeah everything is good on the car just have some charging issues Iím pretty sure itís the alternator but weíll see... I drove it one day and it died not long after I left the garage but the battery holds a charger and thereís no leaks.
    14. #12
      Junior Member JeremyR's Avatar
      Dec 2016
      Oregon, IL
      Mine is exactly the same. I thought there was a problem, went through testing the turbo and confirmed with Contrast that it was factory de-tuned.
      Here's my 05 GT detuned boost numbers and 0-60 time.
      https://youtu.be/3nRFuXBNym0
      2005 S60R | DRag 18" DR34, ET40 (838) | 235 Thunderer Mach IV 302 | Delrin | PowerStop | Eibach | Fixed/replaced everything at my shop, just rolled 185k, like new. Original engine, trans, & drivetrain.
    15. #13
      Junior Member LeeT5's Avatar
      Apr 2005
      Kent, UK
      Stock boost on a 2004 R is 12psi not 14.7psi.
      It is also Load dependent. Meaning the ECU will try to achieve target boost at a given load situation. 4th gear pull at 50mph WOT should give you peak boost at around 2500rpm and beyond.
      Black V70R 2004 6-spd JR Tuning remap, Atacama leather, IPD rev.3 R boost guage, CFWerks door mirror pod, Eibach 5mm spacers, Jetex Performance filter + windowed air box, SAT NAV, Dynaudio sound with Sub, 4700k HIDs, 5000k LED fogs, 5000k LED H7, Custom exhaust, IPD Engine brace brackets, Forge CBV, TW FMIC, Brembo 'drilled' discs, D5 Oil cooler, iMiV 'Classic' Bluetooth/reverse camera, Powerflex, TTV SMF
    16. #14
      Junior Member stomish's Avatar
      Jun 2016
      South Jersey
      Quote Originally Posted by LeeT5 View Post
      Uhhh are you sure? My 04 vR when stock hit 15psi all day. Is there a chance it could have to do with production dates throughout the year?
      completely unable to go through drive thrus
      Had to shorten my flair because it was becoming disgustingly long
      2004 M66 Passion Red V70R // StevO tuned, Rolling Motors built B5244T5 w/ Spec lightweight flywheel, stage 1 head, custom catted/catless DP plus more
      2004 M66 Electric Silver S60R (Sold) // 2004 AW-55 XC70 // 1996 AW72L 965 (Sold) // 1987 AW77 745 Turbo (Sold)
      1993 AW70 245 Wagon(with only 97k!!) (Sold) // 1988 AW70 245 Wagon (Sold) // 1987 M47 244 Sedan (Sold)
      1997 M56 850 Estate (Sold) // 1979 BW35 242DL // 1996 AW30-43 960 Sedan (Sold) // 2007 AW55 XC70 Adventure package
      2007 AW55 XC70 Adventure package parts car // 1996 AW50-42LE 850R Estate w/ 16T and Blues (Sold)
      1993 M47 245 Slicktop (Sold) // 1986 M46 245 Slicktop // 1994 945 Turbo // 2005 M66 Passion Red S60R // 2005 M66 Electric Silver S60R
    17. Remove Advertisements
    Similar Threads
    1. Replies: 8
      Last Post: 05-25-2006, 03:22 PM
    2. Boost levels for LPT
      By Sherman in forum S70, V70 & V70XC (1998-2000)
      Last Post: 01-03-2004, 01:57 AM
    3. Low Boost levels and vacuum leak...
      By gr82882 in forum 850 (1993-1997)
      Last Post: 09-29-2002, 12:07 PM
