85 240 Turbo fluttering idle
    Results 1 to 2 of 2
      Mar 2011
      tampa,fl
      Looking for any ideas. In need of help. Out of the blue developed a strange idle. See video. Stays idling and drives perfectly fine until you are in motion and coast in which case it dies. I changed ignition components, tried several IAC's, couldn't locate any vacuum leaks. Seems to be worse when engine is warm. ECT sensor is new. Fuel filter is new. Any ideas? It's almost like it can't get good fuel stream at idle but it drives strong when on the accelerator.
      https://i.imgur.com/YNftUTA.mp4
      1985 240 Turbo 330K | 1995 Yellow T5-R 238K | 1996 850 Turbo 250K | 2005 S40 2.4i 178K | 2005 XC90 2.5T 240K | 2006 C70 T5 214K | 2007 S40 T5 170K
      Dec 2018
      Probably the warm up regulator taking a crap. You can remove it and clean out the screens where the inlet and outlet lines go in. There’s a 99% chance they are plugged with debris.
    4. Remove Advertisements
    Similar Threads
    1. Wanted: 240 *** 240 *** 240 *** 240 *** 240 *** 240
      By lovemyvolvo in forum Want Ads
      Last Post: 02-19-2014, 10:08 PM
    2. Boost fluttering under high boost
      By ridgwaym27 in forum S60 (2001-2010)
      Last Post: 07-13-2011, 10:58 PM
    3. surging/fluttering after ecu upgrade
      By bigairart414 in forum R Forum (2004-2007)
      Last Post: 08-22-2010, 09:35 PM
    4. Fluttering noise from HVAC?
      By fosman316 in forum XC90 (2003 - 2014)
      Last Post: 12-30-2004, 01:17 AM
    5. 85 240 TURBO WAGON rebuilt motor, turbo, auto w/ od
      By trackside in forum RWD Cars For Sale
      Last Post: 12-24-2004, 04:00 PM
