1 More Lower Manifold Left - will be Ported
    Results 1 to 17 of 17
      Member EngTech's Avatar
      Jan 2007
      Knight's of the Round Table - TN
      c3 1 More Lower Manifold Left - will be Ported
      These go for Considerable Amount as You may Know ~
      I Custom do these Once a Yr , Lower Unit is Gasket Matched to Over Sized Ports of an Upper Ported Unit . . more then just Blue Printing Stage 1 see Picture ..
      His Porting is Good but Generally Found ( Not to Match ) as well as Not Inspected 10 Times on an Individual Basis -Per Runner on Both Ends ..
      The Lower Unit takes about Week do do $375.00 with Your Core in Exchange , No Core $455.00
      Before these are pretty Ugly Inside ~
      We Know what Elevate Charges : https://www.elevatecars.com/store/vo...-manifold.html
      ** V50 AWD - Handling & Performance Tweaks = New Stance / VW CC - Handling Tweaks - Testing & Porting - Intake Mods
      A Garden Gate will Last You a Life Time . http://s261.photobucket.com/user/Eng...0Trim%20%20etc
      Jan 2007
      This one was Polished _ Way more then Necessary with Diamond Dust Approx 320 RMS - only 180 _ 240 RMS is Needed above Picture is approx 60~80 RMS
      https://youtu.be/O92wmyCQhg4?t=12
      Junior Member peacock's Avatar
      May 2013
      Buffalo
      I was like upper and lower?? P1 thing gotcha.
      Sent from my SM-N960U1 using Tapatalk
      SwedeSpeed.com
      Jan 2007
      More Like a Porting Thing ~ as in ~ I'm a Machine
      I'veAttachment 56815 Ported Race Sleds , Built Big Bike Motor Heads & Ported those , Chainsaws , Turbo's , Turbo Manifolds Attachment 56813
    7. #5
      Jan 2007
      I'd just like to say - it such Fun seeing a 40ft High Rooster tail and 120ft long - screaming across the ~ Adirondack Lakes ~ all 100% Deep Frozen for Months ~
      https://youtu.be/lLGv-l-Zbhk?t=28
    8. #6
      Jan 2007
      Turbo's rebuilt
      Ported & Some Polished and Some Ported & Polish ~ Matched ~ with Thermal Gaskets
      This Turbo was also Rebuilt with ~ New CHRA with Better Balancing ~
      Just a Few Volvo's ~ Not Sleds or Motorcycles ~
      in These Pictures Anyhow ~
      Beginning Turbo Stage 1 ~ Examples is all
    9. #7
      Jan 2007
      This One is Sold
      This One is Sold
    10. #8
      Jan 2007
      Here it Is - Just in Time for Christmas ~
      Porting Lower Unit Matching to Thermal Gasket Polishing to around 180-220 - should net 11Hp with Upper Performance Plume = 14Tq
      Combo should Net around 24-26Hp depending - State of Tune @ Motor
      ~ Biggest Gains in ~ TQ Mid_Range ~
      Turbo's get Ported & Polish to 280-320 Unless Thermal Ceramic Coatings are being Polishing done to Produce Best Adhesion .
      Matching of Upper & Lower with Thermal - Guaranties - Best Results
      This One is Sold ~ Have 1 more to Port takes about Week as there are many Steps Involved ~
      $365 Plus Shipping , If No Core Swap or send Back Your Original - then $455.00
      https://youtu.be/pfLJXGdZhZw
    11. #9
      Jan 2007
      Other Volvo's & Older Manifolds are Welcome :
      Older R Turbo Exhaust Manifolds etc. , Volvo 140 Intakes etc.~ Those would be Quoted
      Here's another Video : https://youtu.be/O92wmyCQhg4
    12. #10
      Jan 2007
      New Improves Payment Method ~ Just Drop Down Payment - Through Pay Pal - Ebay to Get 6 months Deferred Easy Payments
      This Gets You Off to the Spring Performance Up Grades U always wanted ..( Also New Photo's ) @ Link
      https://www.ebay.com/itm/333448508999
    13. #11
      Oct 2019
      so we would ship you a un-ported unit, say the lower intake manifold and for $200 it is ported and polished? or is it the 365 as mentioned in a reply above?
    14. #12
      Jan 2007
      Thank You for Your Inquiry ~ I tried to set it up as a Down Payment , Most everyone here on SS "sends it as Friend" .. I Know that sometime is a Bit much .. even 9 years ago when Plumes were $450.00 Bucks
      some of these are Now $655 Plus $400 Porting is really getting up there ..
      I'm Offering $365. SS Member Discount for Porting Stage 1 Lower Unit and If You ship Upper with it I'll Match It to Lower Unit and Match Thermal Gasket for $120 . . so U end Up with
      (( Stage 1 Matched - Plus set up )) Plus mean If I do the Upper together then I also Clean Up the Throttle Body Portion ..
      If a Thermal Gasket is Being used .. as in an Elevate .. I do Recommend U Add Thermal Gasket - PM Me and I'll Fill U in ..as to Why ( Thermal from Elevate ) May be Used on all Plumes Currently Being Offered . .P1 Platform . .
      As Far as Down Payment It would be What Your able to do . U would be able to do - 100% that ~ or Half Way some or All of it could be - Deferred ~
      Hope this Helps ..
      Either way in End -
      Adds Valve to Your Performance Volvo .. Plain lower manifold is worth $90-100 Bucks - when this is Done it's Worth $600 ..and so On ..
      423-270-4180 Text is way Faster ..
      Dan
      ps: Matching the Gasket ~ some of U may very well be able to do that Little Task , but it takes an Hour .
      Has to be Lined Up just So .. Taped and Held with No Movement ..
      Painted Plumes are More as I must be very Careful with Clamping ..
      I do Paint Prep which Includes - taking down all the Seams for a Real Nice Look on Outside of all Runners ( Paint comes out Far Better .. )
      Also some Ship straight from E-bay the Lower Unit . I have one in stock let Me Know .. Stage 1 - Matched and Upper with Plus now that is Worth $1000.
    15. #13
      Jan 2007
      I have Two Manifolds in Stock , ready for Porting ~ it's 1 week from Time You place Order .
      You'll receive Freshly Ported Clean & Polished Stage 1 Lower Unit .. shipping is Generally Only around $19.00 bucks then U have plenty of time to get Core Back _ No Rush [email protected] All
    16. #14
      Mar 2012
      Charlottesville VA
      Once I figure out my misfire issue, I'll be looking for one of these!
    17. #15
      Jan 2007
      Yes, This also goes for 2.4i Intake and P2 Lower Intake ~
    18. #16
      Jan 2007
      Yes, Your Intake system will be @ Least Worth Grand , Better Performance Matched Upper & Lower also . .
    19. #17
      Jan 2007
      Remember Matching is Not Porting or Stage 1 - Matching Certainly is Better then Mis-Matched gaskets and Runners - in the Middle of Intake System
    20. Remove Advertisements
    Similar Threads
    1. P2R exhaust manifold - ported and ceramic coated
      By BlkT5 in forum FWD & AWD Parts For Sale
      Last Post: 09-07-2014, 06:58 PM
    2. Replies: 49
      Last Post: 01-29-2013, 02:05 AM
    3. FS: Fresh professionally Ported + Polished exhaust manifold
      By Darth_Maul in forum FWD & AWD Parts For Sale
      Last Post: 08-11-2012, 12:29 AM
    4. Ported Intake Manifold & Polished
      By LightAngel_1202 in forum R Forum (2004-2007)
      Last Post: 04-15-2011, 01:30 AM
