Anyone ever replace a prop shaft bearing?
    Results 1 to 9 of 9
      Apr 2013
      Toronto, Canada
      Just wondering what’s involved, specifically can it be done in situ or does shaft have to come right out?
      Here’s the state of mine which is causing some vibrations at certain RPM:
      https://youtu.be/ae5T6j1E6JY
      2010 V70 3.2 125,000miles
      2002 V70XC, 175,000 miles
      2004 S60 2.5T, 160,000 miles
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      IIRC, you can purchase the part separately, but it requires pressing out the pin in the U-joint to service it. Better to find a used, low mileage shaft from the JY. I think they are all the same for all years.
      2005 XC70 Crystal Green | Hilton | 16T | Bad Swede | 145k mi
      Apr 2013
      Toronto, Canada
      Quote Originally Posted by Antherzoll View Post
      Thanks, A. Was just looking the part up on volvopartswebstore and it’s quite confusing. They have a few different t parts listed for the prop shaft but many/most list the full range of years with chassis cut-offs. Might have to resort to heading to wreckyard just to do a visual.
      SwedeSpeed.com
      Oct 2014
      Boston
      What you show in the video is a collapsed rubber dumper around the bearing. This can be replaced separately, if you'll be able to source the part. It does not say the bearing is not dead, but it is not shown in the video.
    7. #5
      Apr 2013
      Toronto, Canada
      Quote Originally Posted by vtl View Post
      Yep, good point. Thank you!
    8. #6
      Feb 2015
      Deep River, CT
      I'm going to try to measure the bearing and housing and 3D print one from polyurethane.....
      2006 S80
      2002 V70 AWD
      2000 V70XC AWD/SE
      Others in my garage: 2000 Ford Explorer V8, 2007 Golf, 1968 Chris Craft Apache 37
      Previous: 2002 Porsche 986S, 2000 V70SE (put to sleep);1973 164E w/4 Speed & Electronic Overdrive (oh, I should have kept it);1968 142S Dual-Carburetted (should have kept this one too!)
    9. #7
      Oct 2014
      Boston
      Vibrations will be terrible. There's a good reason for the dumper to be made of a soft rubber.
    10. #8
      Feb 2015
      Deep River, CT
      Vibration will be dependent upon how I fill the model.... doesn't have to be solid polyurethane all the way thru, infill density is adjustable.
      2006 S80
      2002 V70 AWD
      2000 V70XC AWD/SE
    11. #9
      Apr 2013
      Toronto, Canada
      Wow, well I attacked my prop shaft again today. Thanks to suggestion by @osmossis I got the rear end out from the VC. Ended up going old school with a chisel and med size sledge. Hammered away in six spots and created notches. Sprayed PBB. Let sit for 60min. Pounded away at a couple of notches cutting the angle sharper as the notch got deeper. After what felt like about 20min of hammering it finally gave. Now for the front. Ouch, really not much space to access the end of prop shaft up there. I do see an access hole at back of flange (in between two of the six hex bolt holes). I think I’m suppose to put something in there to help push prop out. Just can’t remember if I screw something in or just put much something in there...
    12. Remove Advertisements
    Similar Threads
    1. Anyone tried dropping the prop shaft? Haldex pump change
      By Schmoyoho in forum V70 & XC70 (2008 - 2016)
      Last Post: 12-03-2019, 03:01 PM
    2. prop shaft / drive shaft CV joints
      By shelby_sho in forum R Forum (2004-2007)
      Last Post: 12-27-2017, 05:45 PM
    3. 04 s60 drive shaft/prop shaft
      By leesvolvo in forum FWD & AWD Parts For Sale
      Last Post: 05-01-2017, 10:29 PM
    4. rear drive shaft (prop shaft) vibration
      By colin2211 in forum R Forum (2004-2007)
      Last Post: 12-21-2014, 11:06 PM
    5. Drive shaft / prop shaft removal help
      By 4eyes in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 05-05-2014, 11:10 PM
