Seafoam Spray? Where in the engine?
    Results 1 to 11 of 11
      Jul 2015
      Question Seafoam Spray? Where in the engine?
      (I did t quick search in this subforum but found nothing...)
      I'm thinking about running the Seafoam Spray method through my engine to give it a good clean out, however I'll be totally honest here: I'm very much 'green' when it comes to knowing the various parts of my engine beyond the fluids and air filter.
      Would someone be able to show, with pictures, where I would be injecting the Seafoam Spray into the engine? (My engine is the B6304T4, T6)
      Or is there a link someone can point to?
      Thank you in advance, it would probably be helpful to other folks here too (maybe?)
      Member mgm7890's Avatar
      Nov 2013
      USA
      Are you exhibiting issues that make you want to run seafoam through it?
      You'd normally dump it in the gas tank, dump it in the crankcase, change the oil after 200 miles or so, and suck some up through a vacuum port.
      I wouldn't recommend it unless you have a reason for it.
      2005 S40 2.4i
      Jul 2015
      No issues, just want to keep the engine's components as clean as possible and keep my performance as high as possible. I'm nearing 92k miles.
      SwedeSpeed.com
      Dec 2019
      Any update since?
    7. #5
      Jul 2015
      No updates yet - hoping someone can tell me where to insert spray (I'm still learning my way around the engine, and through my DIY processes learning about the other components like suspension and so on)
    8. #6
      Member 95WanderWagen's Avatar
      Aug 2016
      Berks Co., PA
      I used to pull it in thru the brake booster vacuum line in other cars. Not sure if that applies here. On the 850 I pulled from vac tree. Xc70 at the reference port on intake.
      For most part anymore I will run a full can thru gas tank and split a second can between intake and in the engine oil. Drive 50-100 miles and change oil immediately.
      Help fund a trip across the country for a volunteer position working with rescued wolves and wolfdogs!
      https://www.gofundme.com/Ptsd-therap..._co_campmgmt_m
      Want brighter, whiter interior lights in your Volvo? PM me for details or email me at [email protected]. Full kits in stock for p80 platform cars
      Ghosts of the past
      3x AMC XJ (84 Cherokee 2.5l, 86 wagoneer 2.8l, 87 Cherokee sport 2.8l 5 sp) || 4x Subaru (96 legacy outback, 97 legacy gt wagon, 92 svx 4.44 auto swap, 88 DL coupe) || 2x Pontiac (88 Fiero 2.5l notchie, 96 grand Prix GT 2.4L) || 3x DSM (92 eclipse GS 4g63 n/a, 99 eclipse gs 420a n/a, 3000gt vr4 sport roof) || 2x Hyunda (96 Elantra 4g63 coupe, 2000 Elantra 4g63 wagon) || 1x Geo storm || 1x VW [93 Fox) || 1x Ford(93 Escort LX 1.9l) || 1x Chevy(2000 venture extended) || 3x Volvo (96 855 2.4l, 95 855 2.3t, 04 xc70 2.5t) || 1x Mazda (2003 Protege5 5sp)
    9. #7
      Nov 2018
      Quote Originally Posted by 95WanderWagen View Post
      The brake booster line is for sure easiest, I remember on all my XCs there didn't seem to be one. I do remember letting it suck in through a small line.
      They also make one where you can put the little hose in, and get it directly into the intake or close to it.
    10. #8
      Aug 2004
      Quote Originally Posted by prendrefeu View Post
      Back on the shelf in the store you got it from. It's snake oil and has no meaningful effect on your engine.
    11. #9
      Oct 2018
      San Diego, CA.
      Quote Originally Posted by dfischer1 View Post
      +1.
      Besides, some of the suggestions are downright dangerous for some people to attempt. I can just imagine someone pouring in a giant slug of some liquid into the intake and hydro-locking the engine. Please, NEVER force a liquid into the engine air intake.
      2009 XC90 FWD 3.2, 2013 S60 T5
      In the past: '89 745, '91 940, '82 242, '67 122S, '67 123GT, '71 142E, '62 PV544.
    12. #10
      Aug 2016
      Berks Co., PA
      Umm... Snake oil that doesn’t work? Have you ever used it? YMMV of course...
      https://youtu.be/u6UeJXkzDW8
      Fast forward to 5:03 to see results
      Granted not a huge difference in one application. However if used early/often I would expect better results.
      Another one (GDI valves). Much better results
      https://youtu.be/zb7H-GBZZBk part 1
      https://youtu.be/Lay5orD-XIA part 2
      Ghosts of the past
    13. #11
      May 2018
      Quick heads up: You've got $4-5K worth of emissions equipment downstream of the engine. Not sure Seafoam is worth that gamble.
      If you use non-crappy gas and decent motor oil,you should be fine for hundreds of thousands of miles.
      So many of these "success stories" on YouTube are either hard to see, or are a worst case scenario.... or on a poorly designed engine. I mean, after 30 years of Volvo engines, I've never seen them look as bad as the *starting* point in many of these videos.
      -Ryan
      Current fleet:
      1987 Volvo 245
      1989 Volvo 245
      1991 Volvo 745 Dog Waggin' 2.0
      1995 Volvo 945 Turbo
      2011 Volvo XC90 3.2 AWD
      2013 Volvo XC60 3.2 AWD (Wife-mobile)
    14. Remove Advertisements
    Similar Threads
    1. Seafoam Your Engine :: Yeah or Nay?
      By ShadowDancer in forum XC90 (2003 - 2014)
      Last Post: 04-20-2018, 10:21 AM
    2. trying to build an oil catch can and seafoam the engine
      By coolin in forum S40 & V50 (2005-2012)
      Last Post: 09-25-2012, 06:53 AM
    3. Anyone use Seafoam for your Volvo Before ?
      By BenGlxVR6 in forum 850 (1993-1997)
      Last Post: 03-10-2008, 03:59 PM
    4. Seafoam question/lagging throttle
      By siegelj in forum S80 (1998-2006)
      Last Post: 08-06-2006, 03:23 PM
    5. 2004 V70R Seafoam/Orange 7,472 miles @ Davesmith Motors, Idaho
      By steve850 in forum FWD & AWD Cars For Sale
      Last Post: 01-09-2006, 08:50 PM
