2008 3.2 AWD replacing Power Steering Pump. Need Advise. Pls Check Video.
    Results 1 to 9 of 9
      Junior Member Turbo_Boss's Avatar
      Jun 2015
      Panama Rep. of Panama - Central America
      Hey guys,
      I have a 2008 Volvo XC90 with 3.2 engine with 89,000 KMS
      Yesterday just at half mile from my home the steering got super heavier and there was a screaming wheezing sound. I immediately turn off the AC. I drive slowly to my house.
      Thank GOD this happened late at night and there was no traffic so I will say I drive this way less than 10 minutes and only when I steer was the screaming noise.
      So today I check under the hood. Open the power steering fluid reservoir and it full. Start the engine and its look like the power steering pump pulley lock/stuck itself momentary when it has to make force to steer.
      So I am pretty sure the power steering pump is FUBAR. I will order an aftermarket one.
      Also I see the serpentine belt got some damage because of the friction with the power steering pulley problem. I also can see in some places rubber parts of the belt so its look like I also will need to order the belt too. I will order a Continental Contitech Brand.
      BTW, I will also order the O Ring kit to repair the Power Brake Booster Vacuum Pump since is leaking oil.
      I have wrenched my cars before and could use a hand. Please check the video and I will really appreciated your comments or any advice on other parts you advise me to order.
      Thx for your help and time
      Isaac
      2008 XC90 3.2 AWD
      May 2018
      Any luck so far replacing the pump?
      -Ryan
      Current fleet:
      1987 Volvo 245
      1989 Volvo 245
      1991 Volvo 745 Dog Waggin' 2.0
      1995 Volvo 945 Turbo
      2011 Volvo XC90 3.2 AWD
      2013 Volvo XC60 3.2 AWD (Wife-mobile)
      They are a real pain in the butt to replace. I called the dealer to get a quote, and they told me $1800.00 without looking at it. You have to really tear into the engine bay to get to the pump on a 3.2, mine after I got the under hood fuse /brwaker box out of the way, I had to move the air box and associated plumbing. I also fully removed the tray for the ABS computer which has 6 hard lines plumbed to it. There are only about 3 or 4 bolts you can get to, after that everything else is all wrenches, do not even dream of using a socket, unless your arms are like twigs and as flexible as a rubber band. I did mine in my driveway, and it was a pain to do. Also I would like to add that I did mine in the middle of January two years ago when the weather was colder than a wildcatter's arse in the Bakken Oil Patch in my driveway, as I lack a garage. I had a couple friends over to give me a hand as well. I wound up replacing the pump, both idler pulleys, and the serpentine belt, as the belt got shredded when both idler pulleys grenaded. (On another repair I had a shop do); I had a shop replace my hood release cable and the mechanic told me it was a "P.I.T.A." to do & there is a grommet through the firewall (which LOOKS LIKE) it is easy to get to, however in reality you need arms the size of a squirrel & about six feet long to replace said grommet; I told the mechanic to not worry about the grommet if it saves me money & time at the shop; he sounded VERY relieved.
      SwedeSpeed.com
      2010 XC90 V8 - 140k miles
      2012 S60 T5 - traded with 177k. Lost compression on cyl 5.
      2009 C30 - Totaled. It ate a minivan at 35mph.
      2006 S40 - at 217k it was tired and needed too much.
      2008 XC90 3.2 - traded with 220,780 miles
    7. #5
      Oct 2009
      that p/s fluid looks really bad,i would flush the system before installing a new pump....by the way p/s pumps just dont fail on these cars...
    8. #6
      Jul 2015
      Calgary
      Your video did not play.
      While the pump is out I would do the other belt stuff like idler and pulley or tensioner and maybe water pump if it feels like it may be getting at all loose.
      07 XC90 3.2
    9. #7
      May 2018
      If you plan to keep the car, I'd do all the stuff while at it. I think the pump should come out quite easily if you pull the A/C compressor and bracket.
      -Ryan
      Current fleet:
      1987 Volvo 245
      1989 Volvo 245
    10. #8
      May 2017
      Chicago & D.C. Metro
      Yeah, anyone who has done their own water pump and serpentine belt replacement knows you have to unbolt the power steering pump. It isn't that bad if you follow the instructions for doing the belt and water pump. Nothing special besides undoing the lines and reattaching hoses.
      Agreed, if you are replacing the power steering pump, then do the rest of the maintenance (ex: water pump, tensioner, idler, and thermostat) while you are there. And as said earlier, a good idea to flush the fluid. Even though this sounds like an early time to do it, the age can still get to components and you won't have to worry about them for a long while.
      Not using parts with grease, oil, and rubber can be just as bad as having high mileage. The grease & oil oxidize, getting old and dry, while the rubber gets dry (especially if oil has not circulated to lubricate it). Also, moisture can get to components and sits. In Panama where the original poster is, moisture could cause premature failure for lower mileage vehicles, like in his 3.2.
      2008 XC90 3.2 AWD - 150k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Bridgestone Dueler H/L Alenza Plus 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Amazon Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
      About the XC90 3.2 - The good, the bad, and the ugly
      Upgrade front end rebuild with OEM, aftermarket, and original parts
      Ultimate Transmission Fluid Guide for the 3.2 & V8
      The better transmission JWS 3309/T-IV fluid for your 5 or 6 speed
      Strut Recommendations based on your specific XC90
    11. #9
      Jun 2015
      Hello Guys,
      Sorry for my late reply
      My problem was not the Power Steering Pump. After checking it was the Tensioner Pulley the problem.
      I replace the serpentine belt, Tensioner Pulley and Pulley and it working without any problem.
      I follow this post https://www.freel2.com/forum/topic33363.html where is a step by step DYI with photos for replacing Serpentine belt.
      There you can find my advises of what I do differently.
      Thx & Rgds,
      Isaac
      2008 XC90 3.2 AWD
    12. Remove Advertisements
    Similar Threads
    1. Replies: 13
      Last Post: 11-26-2019, 04:00 PM
    2. Replies: 5
      Last Post: 11-21-2017, 10:10 AM
    3. Pls. advise (FPS and relation to outside temp reading)
      By EricV in forum S40 & V50 (2005-2012)
      Last Post: 08-16-2016, 05:18 PM
    4. Power Steering Pump leaking - Pump or Reservoir?
      By DaveP189 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 04-28-2016, 03:53 PM
