-40 on ECT and code P0420 Catalyst Efficiency 2004 XC70
    Results 1 to 6 of 6
      Oct 2010
      Was hoping fresh coils would clean up a nagging P0420 code on this 2004 XC70 in our fleet, 180 K miles, but apparently not.
      It set not one, but two P0420 codes after being driven in heavy rain yesterday.
      The odd thing is the freeze frame data on both codes showed ECT (engine coolant temp) at -40 that seems like maybe a bad sensor, or wiring?
      Or maybe Volvo doesn't report accurate ECT's on generic code readers?
      Has anyone encountered this?
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      If the ECT was that far out it wouldn’t run.
      I’d just space the rear o2 sensor.
      2003 V70 T5 - Mystic/Graphite - M56LK - 209k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 303k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 245k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
      Oct 2010
      Wonder if its having some sort of periodic fault, though think you would feel it in the engine. ECM sees momentary ultra cold engine adds fuel and that causes the catalyst efficiency to drop.
      SwedeSpeed.com
      Sep 2018
      At least get a Volvo-specific OBD-II scanner, if not DiCE/VIDA. It's too frustrating owning one of these Volvos without this tool.
    7. #5
      Feb 2015
      Near the pimple on Philadelphia's ass
      If both 02's and the ECT are originals at 180 thou replace all 3. They are all over due. FCP probably has a good Black Friday deal.
    8. #6
      Member
      Jan 2011
      Arizona
      -40 degrees on an ECT means there's an open circuit.
      2007 S40 T5
    9. Remove Advertisements
    Similar Threads
    1. Replies: 9
      Last Post: 04-11-2016, 02:31 PM
    2. 2007 SR, CEL, P0420 - ECM-400C - Catalytic converter efficiency
      By volvolars84 in forum R Forum (2004-2007)
      Last Post: 01-05-2016, 10:28 AM
    3. 2004 XC70 with P0420 Code, Intermittent Misfire
      By erikgrad in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 02-06-2015, 08:31 AM
    4. Replies: 37
      Last Post: 09-02-2011, 11:16 AM
    5. catalyst confirm
      By volvoom1 in forum S60 (2001-2010)
      Last Post: 10-20-2007, 10:22 AM
