Driver headlight (Lowbeam) out due to loose wire at socket connector
    Results 1 to 6 of 6
      Aug 2011
      Los Angeles
      So, my newest discovery on my 2004 2.5 is that the driver headlight is out. I pulled the headlight out and found that one of the two black wires feeding the connector (that the back of the H11 bulb plugs into) is loose / was able to pull it out (where the Red box is on the pic below). I pushed it back in while the car was running and the bulb lighted up but the wire won't stay.
      There's a replacement part (below) but how do you replace it? The wires go back into the headlight assembly somewhere. I assume the other end of that wire is plugged/connected into some slot but it doesn't appear to be accessible. Has anyone done this?
      https://www.fcpeuro.com/products/vol...volvo-31299732
      Mine - 2017 Corvette Stingray.
      Hers - 2013 C250.
      Handed down to daughter - Silver 04 2.5T XC90
      Jun 2012
      Tidewater, VA
      Just cut off the old connector and splice the new one onto the wires:
      https://sparkys-answers.com/2013/01/...-not-work.html
      It’s been a few years now so I can’t recall exactly how I did it, but my connector melted on my ‘04 and I replaced the entire harness inside the headlamp assembly with another that I pulled from the junkyard. It wasn’t too hard, just a tight fit and a bit of fishing to get the harness to curl correctly.
      BD
      Current Fleet:
      1998 S70 Base (New project), 2006 S40 T5 M66 FWD, 2008 C70 Premium Plus M66, 2011 XC90 V8, 2013 C70 Platinum P*
      RIP:
      1994 854T FWD, 2004 XC90 2.5T AWD, 2005 S60 2.5T FWD
      Aug 2011
      Los Angeles
      THanks. I'll splice in the new connector and call it a day.
      Hers - 2013 C250.
      SwedeSpeed.com
      Jul 2014
      Omaha, NE
      Check to be sure, but if you have H7 bulb, but the H7 headlight connector, the ceramic type is supposed to be better.
      Local auto parts store, ebay or FCPEuro should have it.
      The debate is plastic vs ceramic...
      Polarity is NOT important here, but you may want to keep the same wiring, just watch which wire goes where.
      Use a butt connector and crimp it.
      This is a good video, but where the guy connected (he twisted the 2 wires together), don't follow his advice, instead, use butt connectors...
      In fact, if you watch carefully, there were already 2 butt connectors (YELLOW connectors in his video).
      So the connector was already replaced at least once before in his car...
    7. #5
      Aug 2011
      Los Angeles
      Thanks. I have the H11 bulbs as my low beam on my 04 2.5T and not the H7. As far as I know, that's how it came (oem). I ordered the connector from FCP and it should be here around wednesday. I think it's plastic but I don't think it' matters since the issue was not the connector melting but rather one of the wires coming lose from the back of the connector. I can't get it to go back in and stay so I'll just swap in a new one. The h11 bulbs are 55 watts so i'm sure there's heat generated. I thought about LED bulbs but it's a 15 year old car so... cost / benefit that one.
      Quote Originally Posted by cn90 View Post
      Hers - 2013 C250.
    8. #6
      Aug 2011
      Los Angeles
      Just fixed it.
      Cost me about $70 or $80 in parts (connector from Fcpeuro, wire stripper, butt connector pack in various sizes) but it’s cheaper than a new headlight and I avoided the labor cost of taking it to somebody.
      Miller time
      Hers - 2013 C250.
    9. Remove Advertisements
    Similar Threads
    1. lowbeam relay/fuse? 2012 s60 rdesign
      By volvos70turbo35 in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 07-26-2019, 05:09 PM
    2. What's this loose blue connector under the driver's seat?
      By rbwinchell in forum XC60 (2010 - 2017)
      Last Post: 01-09-2019, 02:42 PM
    3. 2007 V50 frequent Intermittent HID lowbeam failure
      By Jirv0id in forum S40 & V50 (2005-2012)
      Last Post: 02-11-2018, 10:41 PM
    4. 04 s60 2.5t lowbeam headlights quit working
      By DirtyDubbS60 in forum S60 (2001-2010)
      Last Post: 09-03-2016, 11:15 PM
    5. H11 LED bulbs /fog lights/lowbeam
      By jondevieonS40 in forum FWD & AWD Parts For Sale
      Last Post: 01-12-2012, 10:31 PM
