2010 XC90 3.2 noise on idle
    Results 1 to 12 of 12
      Oct 2019
      Los Angeles
      Hello,
      I have a 2010 xc90 3.2 R Design with around 78K miles which I bought about 2 months ago.
      I have been noticing some strange noise when the car is on idle ( for example at the traffic lights). I dont know if it's coming from the gearbox or something else. seems to go away when the engine is off for some time. and then comes back after some running.
      Here is the link to the short audio recording I did. If someone can identify the source it's coming from would be a great help.
      https://drive.google.com/file/d/1Eqn...w?usp=drivesdk
      Thanks,
      Utsav
      May 2017
      Chicago & D.C. Metro
      It is difficult to understand what you are trying to let us hear. Where is the audio taken, inside, outside, in the engine bay? Are you revving the engine? Does the noise change when you rev or when you are driving, or is it consistent? Is it a metallic noise or electrical noise?
      So, I remember hearing a strange noise inside the cabin at times and wondered what it was. It turned out not to be anything wrong. It was the audio and I had an auxiliary line plugged into the center console and when I unplugged the phone, it would make a weird noise from the speakers. Almost like you are trying to listen for aliens in outer space.
      2008 XC90 3.2 AWD - 150k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Bridgestone Dueler H/L Alenza Plus 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Amazon Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
      About the XC90 3.2 - The good, the bad, and the ugly
      Upgrade front end rebuild with OEM, aftermarket, and original parts
      Ultimate Transmission Fluid Guide for the 3.2 & V8
      The better transmission JWS 3309/T-IV fluid for your 5 or 6 speed
      Strut Recommendations based on your specific XC90
      Oct 2019
      Los Angeles
      Quote Originally Posted by ChitownV View Post
      I actually did a little troubleshooting today and it turns out to be related to the AC. sound goes off when AC is turned off.
      The audio was taken from the cabin. car was on idle. the sound is not noticeable if you rev the engine because it's not that loud. the sound is like small growl you hear in the recording, and is harmonic.
      Since now I know that its coming from AC, I assume it could be the AC compressor or something?
      SwedeSpeed.com
      Junior Member generic_volvo_driver's Avatar
      Nov 2017
      British Columbia
      Mine does the same thing. Sounds like squirrels or rats in a wall. There was a TJ on this - the fix was a re-designed AC line to the cabin.
      My solution is to turn up the radio a bit louder.
      Me:
      2013 Volvo XC90 AWD Platinum (Caspian Blue Metallic, climate package, walnut inlays + wheel, BLIS, active bi-xenon headlights) 150k km
      2012 Volvo XC60 T6 AWD Platinum (Technology package, climate package) 30k km
      1988 Nissan 300ZX Turbo (2+2, T-top, Aztec Red, collector plates) 80k km
      Family members:
      2015 Volvo XC60 T6 AWD Platinum (Technology package) 96k km
    7. #5
      Oct 2019
      Los Angeles
      Yeah, but I am worried if it's the compressor and if it would create more expensive problems.
      wondering if it's the compressor clutch since it's only happening when the AC is on.
    8. #6
      May 2017
      If you turn the A/C off, but the fan is still on, do you still hear it? The blower motor is a common wear part and it is located under the passenger dash. This is also where the cabin filter is located.
    9. #7
      Oct 2019
      Los Angeles
      There is no noise with the A/C off but fan still running.
    10. #8
      Nov 2017
      British Columbia
      I'll try and find the video. It's made by a Volvo tech but has a bad title. It's the exact noise. He did a before and after with the new hose.
      Me:
      Family members:
    11. #9
      Member ggleavitt's Avatar
      Jun 2005
      Seattle
      Couple links come up for the AC thermal expansion issue (if that's what is the cause), bulletin is SC-253 but I'm not easily finding a copy. See https://www.volvoforums.org.uk/showthread.php?t=229701 as one example.
      2005 XC90 B5254T2 019 201k
      2008 XC90 B8444S Sport 452 132k
    12. #10
      Oct 2019
      Los Angeles
      Quote Originally Posted by generic_volvo_driver View Post
      I'll try and find the video as well. Thanks.
      Quote Originally Posted by ggleavitt View Post
      Thanks a lot. This seems like the issue that I have. and this will surely help in the further research.
    13. #11
      Nov 2017
      British Columbia
      This is what I meant! Great find!
      Me:
      Family members:
    14. #12
      Jul 2015
      Calgary
      Hopefully that SB takes care of your problem.
      Also, don't let your serpentine belt pulley bearings get too worn out before replacing them.
      Our 07 AC had noises that were fixed with a compressor change just at the end of the warranty period.
      07 XC90 3.2
    15. Remove Advertisements
    Similar Threads
    1. Replies: 3
      Last Post: 06-09-2014, 10:16 AM
    2. 2010 XC60 T6 vs 2010 XC90 3.2
      By earthling in forum XC60 (2010 - 2017)
      Last Post: 05-14-2014, 04:20 PM
    3. Replies: 9
      Last Post: 06-07-2013, 01:24 PM
    4. Rough Idle - Idle Air controller valve
      By dcunited122 in forum 740 & 760 (1982-1992)
      Last Post: 01-07-2006, 08:37 PM
    5. 94 850 turbo 101,000 auto air Bad idle no idle stalls
      By volvobryan in forum 850 (1993-1997)
      Last Post: 02-10-2005, 02:44 PM
