Catless DP p0132, p0134
    Results 1 to 11 of 11
      Jun 2016
      Wondering if any of you R guys can help me out. Here's my original post: https://forums.swedespeed.com/showth...ck-engine-woes
      basically, I am trying to clear P0134 code I get with the catless revolv downpipe. I bought a O2 spacer kit but can not get a configuration where I do not get a check engine light containing the code P0134 or P0132.
      Currently using a straight spacer paired with a plug non fouler but am still getting a p0132 code.
      no codes before dp upgrade.
      2004 Volvo S60 2.5t AWD
      Junior Member garbonzo's Avatar
      Mar 2018
      Elgin, TX
      P0132 and p0134 both pertain to your pre cat 02 sensor. So, sounds like you need to either remove the spacer/Fowler off the front o2 sensor and/or replace your precat o2 sensor.
      Sent from my VS995 using Tapatalk
      Junior Member KDM Mods's Avatar
      Nov 2017
      Minnesota
      P0420 is usually the code for a catless downpipe install. That’s the code I have currently
      Sent from my Nokia 3310
      Even though I walk through the valley of the shadow of death, I will fear no evil, for you are with me; your rod and your staff, they comfort me.
      Psalm 23:4
      2005 Hyundai Elantra 2.0 AT
      2007 Volvo V70 2.5T AT
      SwedeSpeed.com
      You definitely have the spacer on the wrong o2 sensor. Check again and make sure the spacer is on the o2 sensor farthest from the engine. I have a spark plug anti fouler on my now wrecked 04 because the cat is gutted and never got a code. (PO sold it to me like that without telling me).
      2006 S60R, 90k miles.
      Sonic Blue w/NordKap.
      2005 S60R, 122k miles.
      Flash Green w/NordKap.
    7. #5
      Jun 2016
      The spacer is definitely on the downstream sensor.
    8. #6
      Jun 2016
      I had no codes before the downpipe install. Immediately after the install I got a p0134 code. Does this mean anything?
    9. #7
      Jun 2016
      This was with no spacers.
    10. #8
      Jan 2018
      Have you confirmed that after the DP install the O2 sensors were put back into their correct positions? Have you checked your wiring/connectors for damage?
    11. #9
      Member BlkT5's Avatar
      Oct 2003
      Victoria, BC
      Just get a tune with cat delete
      Yellow 95 850 T-5R - SOLD
      Black 98 S70 T5M - Heavily modded
      Laser 00 V70 R 6MT - 03 T5 motor M66 AWD swapped
      Sappicama 04 V70 R 6MT - Hilton Stage 1
      Magicama 05 S60 R 6MT - Stock
    12. #10
      Junior Member b5v6's Avatar
      Sep 2004
      San Diego, CA
      No code before downpipe + codes for upper stream sensor probably means bad sensor, whether it ironically went out at same time or got damaged during swap.
      instagram: @oliepyle
      '05 S60R - 2.4R, RaceS60R FMIC, RaceS60R Downpipe, SPEC LWFW/Stage 3 clutch, Elevate upper mount, Forge CBV, Phuzzy HDTCV, Eibach, IPD Sways, Powerflex/Superflex CA bushings, JVC M730 Head Unit (Android Auto, Subwoofer, Back Up Camera)
      '99 Audi A4 1.8T Stage 3...
    13. #11
      Quote Originally Posted by b5v6 View Post
      I mean, I agree. They are wideband sensors after all and just jarring them (at least the Bosh ones AEM uses) I have broken them before.
    14. Remove Advertisements
    Similar Threads
    1. 04 S60R Random P0134 Analysis
      By Rodwoosh in forum R Forum (2004-2007)
      Last Post: 04-02-2016, 11:13 PM
    2. Downpipe install issues code P0134 / Exhaust tip sport kit confusion
      By Righteous R in forum R Forum (2004-2007)
      Last Post: 09-12-2014, 07:03 AM
    3. Throwing a P0134 code
      By collindaly in forum S40 & V50 (2005-2012)
      Last Post: 07-01-2014, 11:42 AM
    4. Returning p0134....after new o2 sensors?!?!
      By colin2211 in forum R Forum (2004-2007)
      Last Post: 04-23-2014, 07:37 PM
    5. P0134 and P0306
      By automatic in forum S80 (1998-2006)
      Last Post: 12-15-2009, 08:04 PM
