Advice
    Results 1 to 5 of 5
    Thread: Advice
      Junior Member V50-SEMA's Avatar
      Nov 2019
      MA
      Advice
      Have a chance to pickup a 2012 S60 T5 84K for a good price...It is a 62 engine code ...piston rings..timing belt..brakes...plugs...done at dealer at 65k. Seller says that it doesn't burn anymore. What should I do? Currently have a 2008 V50 which I would keep for now...HELP!...V50-SEMA
      2008 V50
      2019 Toyota Highlander
      1988 740 GLE - SOLD 1986 Toyota MR2 - SOLD 1991 Infiniti Q45 - SOLD 2006 Saab 9-3 Turbo Convertible - SOLD 1999 Saab 900 Turbo - SOLD 1998 Acura TL - SOLD 2000 Jaguar S-Type - Crashed 1976 Jaguar XJS with Corvette drive train -SOLD 1995 Jeep Wrangler Sahara - SOLD 2015 Buick Enclave - SOLD
      any many, many more - I have a problem
      Member msmith's Avatar
      Sep 2009
      Ottawa (Kanata), Canada
      Coming from owing an S40 for 10 years to now having an S60, the difference in ride is quite a bit. I find the S40 was like a car on rails and extremely fun to drive aggressively. The S60 is more refined and as far as I am concerned a nicer ride overall, just not that good in hard corners.
      Since the engine code falls within the problem area AND the work was done, I would be inclined to ask the seller if they can show maintenance records for the car. Is he/she the original owner or second owner. Where was the regular maintenance done? If you can find our where regular maintenance was done, you might be able to talk to a tech from there and see if they remember the car. They might be able to give you a little more and put some concerns to rest.
      In the driveway: 2012 S60 T6 AWD | Black/Beechwood | Premium/Climate/Convenience Packages | BLIS | Sunroof | Active Bending Bi-Xenon | iPd Skid Plate | TFT DIM upgrade (mine), ... Former - 2006 S40 2.4i M56
      2009 Acura RDX & 1995 Celica GT Convertible (wife), 2017 GMC Sierra SLE | Elevation Edition | Crew Cab (son)
      Nov 2019
      MA
      Quote Originally Posted by msmith View Post
      The last record is the work done at the dealer at 65K....says he changed the oil with synthetic but not at dealer....until then all dealer serviced...spoke to dealer they said it was ok after rings etc were replaced....just trying to see if the consumption typically reoccurs after the rings etc are replaced.
      2008 V50
      SwedeSpeed.com
      Aug 2016
      Stillwater, OK
      Went from S40 to V60 now. Love the move. My understanding is if the oil problem was taken care of by the dealer then you should be fine.
      2013 XC60 T6
      2015 V60CC T5
    7. #5
      Sep 2009
      Quote Originally Posted by V50-SEMA View Post
      I would agree with the others. If the work was done on the rings and moved to full synthetic, I think you should be okay. From what others have also said, the problem seems to go away after the replacement. If the car is in good shape, go for it. You'll like the car.
    8. Remove Advertisements
    Similar Threads
    1. Question/Advice Upgrades - Wheel Spacer and Lowering Kit - Advice Pls.
      By FutureGeneration in forum S40 & V50 (2005-2012)
      Last Post: 02-27-2012, 10:19 AM
    2. Replies: 1
      Last Post: 12-26-2010, 09:16 PM
    3. Buying Advice
      By treedom in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 04-19-2010, 07:56 PM
    4. Painting Advice for Badges and Grill Trim
      By so_calR in forum R Forum (2004-2007)
      Last Post: 04-11-2010, 03:05 PM
    5. NEWBIE, ADVICE TAKEN.
      By chinsoulja in forum S70, V70 & V70XC (1998-2000)
      Last Post: 03-15-2010, 10:32 PM
