2008 3.2 missing core plug
    Results 1 to 7 of 7
      Nov 2019
      Noticed a pool of oil under my car the other day. Turns out the "core plug" or sealing plug, whatever its called, is missing. This is the plug that covers the end of the crankshaft on the passenger side.
      I've located the part itself, but have searched all over and cant seem to find any information on fixing this. Is this part serviceable from outside of the engine? It looks as if it just needs pressed into place but I've tried that and it just pops back out. Is there something supposed to hold it in place or am I going about this entirely the wrong way?
      May 2018
      You probably need a new plug if you can't get this one reseated. These covers aren't super easy to press in. Access should be quite good from the passenger wheel well.
      -Ryan
      Current fleet:
      1987 Volvo 245
      1989 Volvo 245
      1991 Volvo 745 Dog Waggin' 2.0
      1995 Volvo 945 Turbo
      2011 Volvo XC90 3.2 AWD
      2013 Volvo XC60 3.2 AWD (Wife-mobile)
      Nov 2019
      Quote Originally Posted by RyanR View Post
      -Ryan
      So it does just need pressed in? I ask again because there is a bolt hole right next to this. Had me thinking there was another part missing.
      I keep trying to seat this thing and it just keeps popping out after a few seconds of starting the car. It's a new part, not like I'm reusing the old one.
      SwedeSpeed.com
      Oct 2018
      San Diego, CA.
      Pictures? Part number?
      If it's anything like the "freeze" plugs on the older engines, it's set with a little sealant and two hammers. I had a quick look at on engine parts diagrams, and see no end plugs for the crankshaft. Transmission, maybe?
      If you verify the part, we can advise on proper installation.
      2009 XC90 FWD 3.2, 2013 S60 T5
      In the past: '89 745, '91 940, '82 242, '67 122S, '67 123GT, '71 142E, '62 PV544.
    7. #5
      Member
      Aug 2017
      United States
      It just presses in. Put some oil or grease on it first.
    8. #6
      Nov 2019
      Quote Originally Posted by Capndirk View Post
      Part #30637986 Sealing Plug
      I've already replaced my pcv. This plug keeps getting blown out a few seconds after starting the car. I'm not sure if I'm just not seating it right or if theres just too much crank pressure still or what's causing it.
      Or the simple fact I havent used any sealant on it.
    9. #7
      Member
      Aug 2017
      United States
      No sealant is used. I'd run a cylinder leakage test to see how much leakage is going past the rings.
    10. Remove Advertisements
    Similar Threads
    1. 2008 Stereo - Missing AUX Connector, Strange Plug?
      By tdotclare in forum XC90 (2003 - 2014)
      Last Post: 07-28-2017, 11:42 AM
    2. Replies: 10
      Last Post: 12-30-2016, 08:24 AM
    3. Replies: 4
      Last Post: 11-26-2014, 11:22 AM
    4. Alternator v8 new $382 no core or $247.50+$75 core oe parts
      By VFLXC90 in forum XC90 (2003 - 2014)
      Last Post: 12-12-2012, 05:43 PM
    5. Alternator v8 new $382 no core or $247.50+$75 core oe parts
      Last Post: 12-09-2012, 04:56 PM
