Missing 2 press in clips after oil change
    Results 1 to 10 of 10
      Aug 2017
      Hi Everyone,
      I went in for a the 20k mile service on my 2017 S60. They did the oil changed but the 2 clips that are on the cover that has 8 screws in it were missing after the oil change. Does anyone have a picture and part number for those clips? The dealer sent me 2 clips as a replacement but even after knowing my VIN number they gave me the wrong clips! The 2 plastic clips are to hold the cover in place so that you can get the 8 screws in. The cover is some sort of aero cover that completely covers the oil pan and oil filter area of the car.
      Member mgm7890's Avatar
      Nov 2013
      USA
      I think 9182822 is what you are looking for.
      2005 S40 2.4i
      Junior Member Stef1's Avatar
      Mar 2017
      South Shore of Montréal, QC
      These clips are very fragile and I broke some at each oil change.
      I don't even bother to replace them now.
      Bright Silver 2015.5 V60, T6 3.0 AWD, P* tune, Simons Touring Catback, Eibach ProKit, various retrofits including adaptive OE xenon
      SwedeSpeed.com
      Member
      Aug 2017
      They break all the time and aren't necessary. The screws are more than enough to hold the splash pan on.
    7. #5
      Aug 2017
      Thank you! I checked that part against googling for this volvo link: https://usparts.volvocars.com/p/Volv...0/9182822.html
      One question though, are the two clips that go into the lower panel under the oil pan, are the clips identical?
    8. #6
      Nov 2018
      new cumberland,pa.
      they are on my 2012....
    9. #7
      Nov 2013
      USA
      Quote Originally Posted by Tech View Post
      I don't see them so much as helping hold it up, I see it as helping align the shield on the bottom of the car, especially when on a creeper on your back at an awkward angle.
      In that regard, they are helpful, but yes, they break all the time and I eventually gave up.
      2005 S40 2.4i
    10. #8
      Member
      Aug 2017
      Quote Originally Posted by mgm7890 View Post
      Never thought about it that way, good point. It's easy to hold the pan in place with a lift but not so easy on your back I imagine.
    11. #9
      Junior Member msmith's Avatar
      Sep 2009
      Ottawa (Kanata), Canada
      You may want to consider an IPD aluminum skid plate. Reasonably priced and once installed you're done. They don't have t be removed when changing oil. Here up north the stock skid plate can't hold up to the hits from snow and ice blocks. The aluminum one can take a good hit.
      In the driveway: 2012 S60 T6 AWD | Black/Beechwood | Premium/Climate/Convenience Packages | BLIS | Sunroof | Active Bending Bi-Xenon | iPd Skid Plate | TFT DIM upgrade (mine), ... Former - 2006 S40 2.4i M56
      2009 Acura RDX & 1995 Celica GT Convertible (wife), 2017 GMC Sierra SLE | Elevation Edition | Crew Cab (son)
    12. #10
      Member Config's Avatar
      Jun 2003
      Mountain Time
      Quote Originally Posted by msmith View Post
      +1. Worth the extra protection and convenience of not removing the cover at each oil change. Too bad the sale is over.
      '00 Mystic Silver metallic V70R, Rear Wing, Dolby
      '02 Desert Wind S40 Sports premium/winter pkg
      '12 Savile Gray metallic S60 T5, Premium/Climate/BLIS/City Safety/rear spoiler
      '13 Seashell metallic XC60 T6, Platinum/Climate/BLIS/Polestar-tuned/IPD anti-sway bar
      '16 Seashell metallic S60 T5 AWD (replaced '17 S60)
      '13A DICE/VIDA, x's '93 850 GLT, '04 XC90, '17 S60 T5 (Totaled!)
    13. Remove Advertisements
    Similar Threads
    1. How to press out & press in new lower ball joints in 10 minutes flat
      By Arch Stanton in forum R Forum (2004-2007)
      Last Post: 02-01-2014, 09:13 PM
    2. Missing some odd clips
      By DrBrutal in forum R Forum (2004-2007)
      Last Post: 03-18-2013, 01:16 AM
    3. oil filter leaking after oil change
      By redbaronace in forum R Forum (2004-2007)
      Last Post: 02-12-2013, 01:34 AM
    4. How similar is a 2.4 oil change to a t5 oil change?
      By chromecarz00 in forum S40 & V50 (2005-2012)
      Last Post: 10-06-2009, 11:35 PM
    5. Oil filter leaks after oil change?
      By ncS60 in forum S60 (2001-2010)
      Last Post: 04-04-2007, 11:50 PM
