running into problem with ECU swap between 2 2000 v70s
    Results 1 to 4 of 4
      Oct 2013
      Long story short. If you're gonna lock the keys to your volvos in a safe to keep your wife from taking them it's probably wise to that she doesn't have access to the gun safe.
      Anyways, I have 2 2000 volvo turbo cars. One has significant body damage but a good motor. The other has a perfect body but 2 bullet holes to the ECU.
      I want to take the ECU from one and use in the other. What electronics have to be moved over to facilitate this. Trans control module switched over with no problem but when I use the ECU it just turns over with no start. I have the complete electrical system to donor car from the harness to the key to the immobilizer to whatever else might be needed.
      Any help would be appreciated. She makes bail on Friday so I'd like to get it figured out by the time I pick her up from the courthouse.
      98 Saffron, titans, two tone seats, jewels, dual tips, rip kit,
      98 t5m, dual exhaust, RN motor, R bumper, pegs
      99 Laser,[I] lifted, push bar, jewels, 3inch exh, s60R motor, manual trans, c70 front/ rear subframes, ARD tune, crappy paint, satelites
      00 Venetain Red, IPD tune, sways, KW coilovers, RIP kit, DO88 IC, ABM's, dual magnaflows
      99 Red v70R, Dual tip, propus rims,
      Oct 2018
      San Diego, CA.
      Have you tried holding the key from the donor near the ignition switch while using the other key? A simple try, and you may get lucky, but two signals may be an issue for the ECU reading from the immobilizer antenna. It may be necessary to defeat the original key chip so the ECU only sees one code. There may be some threads on how to disassemble the key with transmitter, so you can segregate the key and the chip. This is all guesswork, by the way, since I'm looking at the issue with an '09 XC90 outlook, but a quick look at Volvo Parts shows an immobilizer antenna surrounding the ignition lock fascia. It looks like it might read the near field chip in the key for authorization by the ECU, like later models. The thing isn't likely big enough to process the info. The description indicates that software changes must be made when changing keys for that YM.
      https://www.volvopartswebstore.com/p...rm=immobilizer
      I hope that works for you, and once you get out of range you could tell us about your spirited wife's temper
      2009 XC90 FWD 3.2, 2013 S60 T5
      In the past: '89 745, '91 940, '82 242, '67 122S, '67 123GT, '71 142E, '62 PV544.
      Oct 2013
      Quote Originally Posted by Capndirk View Post
      Thanks Capndirk for the help and suggestions. I tried keeping swap key next to ignition to no avail. Also slid off the key surround thing so it would help with signal. I believe you are right about 2 signals or confusion from the 2 keys being there. Taking your advice/reasoning a step further I swapped out the steering column with the donor car so that I would have the correct ignition that went with donor car. And presto.....she fired right up.
      Thanks again for your assistance. let me know if need any help with your XC90. I will actually be in San Diego in January.
    5. #4
      Oct 2018
      San Diego, CA.
      Quote Originally Posted by jaketheear View Post
      You're welcome. Glad it worked out! Send a PM when you hit town!
    6. Remove Advertisements
    Similar Threads
    1. NEW LED Converted ABM Projector Headlight Set for 1998-2000/02 C/S/V70s
      By ScottishBrick in forum FWD & AWD Parts For Sale
      Last Post: 02-10-2020, 02:56 PM
    2. t5 ecu swap into a 98 v70xc
      By 4cfedbrick in forum S70, V70 & V70XC (1998-2000)
      Last Post: 08-05-2013, 10:10 AM
    3. Need help choosing between 2000 V70SE and 2000 xc70
      By fairladyz_gt-r in forum S70, V70 & V70XC (1998-2000)
      Last Post: 12-05-2008, 10:54 PM
    4. 3rd seat for ALL 1998-2000 V70s'
      By JRL in forum FWD & AWD Parts For Sale
      Last Post: 04-13-2008, 10:14 AM
