Random Stalls at Warm Start-up
    Results 1 to 10 of 10
      Member
      Apr 2013
      Toronto, Canada
      Hi,
      Wondering if anyone else has experienced this. It's happening on my '02 V70XC.
      Car starts without fail when cold but recently. I've had a few instances (maybe 8x over the course of a couple of weeks) where I get back in car after having done whatever (say grocery pick-up) I start up the car, revs up to maybe 1200 rpm (whatever is normal when engine is warm) and then drop down to 700 where it very briefly holds and then dies altogether. 75% of time, when I try and restart the same thing happens.
      Ideas?
      2010 V70 3.2 125,000miles
      2002 V70XC, 175,000 miles
      2004 S60 2.5T, 160,000 miles
      Junior Member Cperkins's Avatar
      Mar 2012
      Landenberg, PA
      I had similar issue, it was the air intake hose (I think, it was a couple of years ago) leaking. It required a smoke test to diagnose it, I couldn't find the leak myself.
      05 XC70 - Nautic Blue, Yakima Rack, 50/35 Tint
      Member
      Apr 2013
      Toronto, Canada
      Quote Originally Posted by Cperkins View Post
      Thank you for that!
      SwedeSpeed.com
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      If it's an intake leak or issue with the MAF pull the MAF connector to see if it changes.
      2005 XC70 Crystal Green | Hilton | 16T | Bad Swede | 145k mi
    7. #5
      Member
      Apr 2013
      Toronto, Canada
      Quote Originally Posted by Antherzoll View Post
      Thanks, neighbor!
    8. #6
      Junior Member Drevolvo's Avatar
      Apr 2015
      Atlanta, GA
      Try replacing the fuel rail pressure sensor.
    9. #7
      Member
      Apr 2013
      Toronto, Canada
      Quote Originally Posted by Drevolvo View Post
      Yeah that was my first thought but the 02 has no regulator on rail.
    10. #8
      Oct 2012
      Kansas City
      Mine did that after it blew off the poorly installed OTE pipe off the turbo... Finally took it to a local shop and he said he cleared 'stored codes' (CEL was not on) and it cleared up...
      2000 C70 HPT 5 spd; ~110-151k miles IPD high-flow air filter; Snaab high-flow Intake; Snaab short throw shifter.
      2004 V70 AWD ~150-165k 16T; Snaab high-flow intake; Snabb downpipe; ARD tune
    11. #9
      Junior Member deano66's Avatar
      Nov 2017
      Cambridge,Ontario
      No codes ?
      2001 Mystic V70 B5234T3 T5 267kms , seems okay, too bad it's auto. :-(
      2001 Black V70 B5244S m56 385kms Wife's daily. Love your Volvo...Use OEM parts
      2002 Mystic S60 B5244S m56 280kms My daily.. awesome MPG!!
      2002 BMW 540iA,, THE Beast
      2002 Nissan Frontier KingKab 2.4l 5speed uninspired driving at it's finest
    12. #10
      Oct 2014
      Boston
      First thing is to read the codes and look at the LTFT and MAF values.
    13. Remove Advertisements
    Similar Threads
    1. Replies: 36
      Last Post: 07-01-2013, 12:44 PM
    2. Replies: 11
      Last Post: 04-01-2012, 09:34 PM
    3. Replies: 4
      Last Post: 06-21-2011, 06:29 PM
    4. Warm Starter Valve Fuse Blows When Starting Warm
      By ncrisafi in forum 240, 242, 244 & 245 (1974-1993)
      Last Post: 04-18-2009, 01:10 AM
    5. Random stalls, loss of power, 1998 s70 GLT
      By joshturse in forum S70, V70 & V70XC (1998-2000)
      Last Post: 12-02-2005, 10:10 PM
