P2402 Evap Leak help
    Results 1 to 3 of 3
      Mar 2017
      Portland, Oregon
      Hi all, I'm getting p2402 on my 07 v8 (95K miles). A few questions about this:
      What is the likelihood that this is caused by the evap pump?
      If it can be fixed by replacing evap pump, how difficult is it to do that job? (No lift, just jack and jack stands) How do I get to the evap pump and is there a DIY on this?
      thanks all!
      Junior Member PDLarson's Avatar
      Mar 2012
      Billings Montana
      Funny you should post this. I have a 2008 V8 with a few less miles, the same P2402 code and also P043E.
      I'm looking for the same answers you are.
      Sent from the demons in my head
      Quote Originally Posted by buycurious View Post
      ultimately the problem was just as pdlarson had predicted...
      1999 V70XC / Mostly stock under the hood / Several cosmetic mods inside and out
      2008 XC90 V8 Executive
      Member ggleavitt's Avatar
      Jun 2005
      Seattle
      LDP is up under the rear subframe, near the charcoal canister. Pull the spare and look up and towards the front, you'll see it.
      VIDA/DICE has a diagnostic test for LDP and I would run it if I had the car connected but if not, check all the hoses from tank neck to canister to pump to valve on the front of the vehicle and see that they're whole.
      2005 XC90 B5254T2 019 199k
      2008 XC90 B8444S Sport 452 128k
    Similar Threads
    1. 2010 R Design Throwing P2402 Code
      By 5555Thats5Fives in forum C30 (2007-2013)
      Last Post: 05-10-2019, 10:20 AM
    2. 2007 S60 R throwing a P2402
      By saum36 in forum R Forum (2004-2007)
      Last Post: 07-06-2015, 02:44 PM
    3. P2402 evap leak, bank 1 too lean
      By Chris Nanfeldt in forum S40 & V50 (2005-2012)
      Last Post: 11-19-2014, 04:47 PM
    4. P0442 Evap leak (slow leak)
      By marc91988 in forum R Forum (2004-2007)
      Last Post: 12-29-2011, 10:25 PM
    5. P2402 (search came back blank)
      By DFurst09 in forum R Forum (2004-2007)
      Last Post: 11-17-2009, 01:17 PM
