Snow tire recommendation for 2018 XC60 T6
    Results 1 to 6 of 6
      Jun 2018
      I am thinking of putting a set of snow tire on my 2018 XC60 T6, original equipped 255/45R20. I live in central Ohio and see big snow few times a year, need to drive though some steep slope to work
      Down to 2 selections, which one would you pick and why, or other recommendation
      1. Tirerack ($1,802): downgrade size to BRIDGESTONE BLIZZAK DM-V2 235/55R19 PLUS SPARCO PODIO rim 19X8.5
      2. Discount Tire ($1,179): NOKIAN TIRE HAKKAPELIITTA 8 SUV STUDDABLE 255 /45 R20 105T XL BSW
      Thanks in advance for any input
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      They're both good choices but I'd give the edge to Nokian just based on folks' reviews here. Only thing is it looks like you would need to get a set of wheels to mount them on. I don't recommend mounting and dismounting tires every season - over time the tires or wheels will get damaged.
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15 XC70 T6, '15.5 XC60 T6, '16 V60 P*
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      You probably don’t want the hakka 8. They’re very open tread and quote loud especially when studded (I own and run a set). That being said they have insane grip.
      My suggestion would be nokians wrg4. They’re amazing in snow, the only tire I’ve ever driven in slush that was at all effective.
      https://simpletire.com/nokian-p255-45r20-t431019-tires
      $932 a set
      OR
      Hakka R3 non studded these will be very good snow tires and gain you an ice edge. Special grip grit, extra soft rubber.
      https://simpletire.com/nokian-255-45r20-t430691-tires
      $1148 a set
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 295k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      SwedeSpeed.com
      Jun 2018
      Thank you both @Wayne T5 and @ScottishBrick. So I decided to get a set of Nokian Hakka R3 SUV 235/55/R19 and 19” Konig rims from Discount Tire
    7. #5
      Dec 2014
      Connecticut
      Quote Originally Posted by dublin168 View Post
      Superb choice. You should be quite happy with those. I’ll just mention that as soon as it gets warm out take them off immediately they wear very fast when it gets over 45, as you’ll soon learn when they arrive the rubber is insanely soft.
    8. #6
      Jun 2018
      so will my tires be in trouble if we have some warmer days during winter?
    9. Remove Advertisements
    Similar Threads
    1. Snow chains recommendation for 2018 XC90 w/ 235/55 R19
      By RedCloud75013 in forum XC90 (SPA: 2016 - )
      Last Post: 01-14-2019, 07:49 PM
    2. Replies: 5
      Last Post: 12-01-2017, 09:33 PM
    3. Anyone have a tire recommendation? Snow tires and non-snow tires?
      By m4gician in forum S40 & V50 (2005-2012)
      Last Post: 08-25-2010, 09:08 PM
    4. Snow, snow, and more snow
      By 02s60t5 in forum R Forum (2004-2007)
      Last Post: 02-07-2007, 07:13 PM
    5. Let it snow, let it snow, let it snow...
      By R Kelly in forum R Forum (2004-2007)
      Last Post: 11-27-2005, 12:07 PM
