P* question... trans or no?!
    Results 1 to 5 of 5
      Nov 2019
      OK, picked up @posaune's massively immaculate '09 T6, and absolutely loving the car. Been a high performance car guy and driver my entire life, so of course I'm looking for more LOL... a question for all of you early-P3 Polestar guys...
      When it's in fully auto mode, I'd say it is a bit lethargic and not willing to downshift unless you really press it. The power is there, but the auto makes you work to get it. Manual mode is definitely better, boost is mostly on tap yet I notice a ~0.5s or so differential between the time I upshift or downshift and the time it actually executes the shift.
      I know with P* the power output is notably changed, I'm all for it, but do you think the upgrade modifies the transmission programming at all? Are shifts quicker/snappier/more responsive in either auto or manual modes? Is there anyone here who can speak with authority on the subject specifically for the XC70 T6, or could refer me to someone who could? Thanks in advance guys.
      Jun 2016
      Sweden
      No upgrade on trans on your model, only VEA.
      VW Passat GTE
      Junior Member mhon's Avatar
      May 2002
      I second that as confirmed with Polestar themselves.
      The Geartronic Adaptation will change itself to suit the new engine mapping which may/may not improve things.
      Only the 8 speed gearbox in the 4 cylinder VEA models get remapped.
      SwedeSpeed.com
      Nov 2019
      Interesting, OK much thanks for the info.
      It would be great to hear some feedback from those of you who have performed the mod.
    7. #5
      May 2002
      Quote Originally Posted by Rrrracer View Post
      Sadly can only speak from using the black stuff. Similar gearbox but different engines to the T6.
      Might be worth peeking over at the XC60 forum to see how T6 owners got on as there are probably more out there with Polestar upgrades.
    8. Remove Advertisements
    Similar Threads
    1. FYI fix: ABS light, no odometer, no MPG, no cruise, no map lights
      By milicem in forum S40 & V50 (2005-2012)
      Last Post: 05-15-2017, 08:54 AM
    2. Trans B4 servo cover for 5 speed trans question
      By sjmcarz in forum S70, V70 & V70XC (1998-2000)
      Last Post: 06-23-2012, 07:49 PM
    3. synthetic trans fluis vs regular trans fluid
      By michaelp4 in forum 850 (1993-1997)
      Last Post: 01-25-2011, 03:51 PM
    4. need aw50awd trans for my 1999 volvo v70 awd which has wrong trans (aw5042LE) in it!
      By lincolnwarner in forum S70, V70 & V70XC (1998-2000)
      Last Post: 04-10-2008, 04:16 PM
