Car not reaching temp on highway
    Results 1 to 20 of 20
      Junior Member zmarshm1's Avatar
      Mar 2019
      Binghamton NY
      Drove to Elmira and back the other day, about 2 hrs of driving and each way on the highway the temp gauge wasnít going past the 3rd or 4th tick. Now when I drive in the city it gets right up to the middle and heat works fine. Itís like the temp goes up when itís idling. Just replaced ect sensor, what could be the issue?
      ||1998 s70 t5m - Stock, future gambler 500 car | 140k? miles
      ||2001 v70 t5 - IPD Sway bars | Delrin subframe bushings | Transmission cooler & mounted inline filter | Rostra long snout transmission solenoids | IPD catback exhaust & Rolling Motors 3" downpipe | Simota Carbon Charge Intake | Bilstein B4 & Eibach prokit lowering springs | 124k mi
      ||2003 v70 2.4t - First volvo | SOLD! Still driving around with 190k+ miles.
      Kanjo!!
      Jun 2018
      portland Or
      Thermostat may be failed in the "open" position.
      Mar 2019
      Binghamton NY
      Quote Originally Posted by IPD_stefen View Post
      Thanks, would that give any codes? Heat also smells like French toast or maple syrup when hot but Iím guessing thatís the cabin filter or something
      Kanjo!!
      SwedeSpeed.com
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by zmarshm1 View Post
      Sure you don't have a heater core leak? Doesn't take much to produce a sweet-like smell.
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
    7. #5
      Mar 2019
      Binghamton NY
      Quote Originally Posted by Exocet View Post
      Might be. The rubber in the engine bayís definitely seen better years, probably the same by that. Iíll give the floor a look
      Kanjo!!
    8. #6
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Thermostat
      2003 V70 T5 - Mystic/Graphite - M56LK - 197k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 291k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 174k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 238k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 212k - Sisters
    9. #7
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      Combo t-stat and heater core leak.
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15.5 XC60 T6, '16 V60 P*
    10. #8
      Mar 2019
      Binghamton NY
      Quote Originally Posted by Wayne T5 View Post
      C-c-c-combo! Well damn. Tstat first then Iíll look at replacing the core.
      Kanjo!!
    11. #9
      Dec 2014
      Connecticut
      Nissens heater core only!
    12. #10
      Mar 2019
      Binghamton NY
      Quote Originally Posted by ScottishBrick View Post
      Link?
      Kanjo!!
    13. #11
      Dec 2014
      Connecticut
      Link?
      Fcp
    14. #12
      Mar 2019
      Binghamton NY
      Fcp
      Thought you were telling me to use a Nissan heater core lol
      Kanjo!!
    15. #13
      Dec 2014
      Connecticut
      Yea. Buy it from fcp. Use genuine volvo o rings though
    16. #14
      Mar 2019
      Binghamton NY
      Like I thought you meant pull one from a Nissan. But the brand is called nissens Iíd never heard of it lol.
      Will do boss, thanks for the tip
      Kanjo!!
    17. #15
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      Thermostat
      If it comes back up at idle and/or slow city operation, it's not a leak, but it's easy enough to look at the core just to be safe, just pull the carpet back to expose it.
      Email: jrl1194 ( at ) AOL (dot) com
      2007 V70 2.5T White/Oak/Tan/Arena, 114K miles. My DD with no plans to sell it anytime soon
      2000 V70R, Wife's, she won't sell. Now she hit 150,000 miles and still near perfect!
    18. #16
      Dec 2014
      Connecticut
      https://www.fcpeuro.com/products/vol...-c70-s70-v70-1
    19. #17
      Mar 2019
      Binghamton NY
      Yea Iíd found it already thanks brotha!
      Kanjo!!
    20. #18
      Mar 2019
      Binghamton NY
      Quote Originally Posted by JRL View Post
      Thermostat
      Yea my buddyís had the same smell before he replaced his, probably is leaking a lil
      Kanjo!!
    21. #19
      Junior Member mattlach's Avatar
      Jun 2013
      Boston, MA
      I'm concerned my V70 has the same problem. When ti gets cold out it takes unreasonably long for the temperature gauge to reach the normal center position.
      Seems like the theormostats are fairly cheap and easy to replace, so I figured I might just do this as a precaution.
      I searched IPD's catalogue for thermostats for my car, and they listed a few different brandw, at different temp specifications, some at 87 degrees, some at 90 degrees.
      Does anyone have any guidance as to which one to get?
    22. #20
      Dec 2014
      Connecticut
      Quote Originally Posted by mattlach View Post
      90.
    23. Remove Advertisements
    Similar Threads
    1. Replies: 22
      Last Post: 07-13-2017, 08:14 AM
    2. MTE tune not reaching boost target?
      By KFuerstenberg in forum R Forum (2004-2007)
      Last Post: 03-31-2013, 03:05 PM
    3. Perks of reaching 50!
      By JRL in forum Off Topic Forum
      Last Post: 08-20-2008, 11:36 AM
    4. S60R reaching new levels
      By Elmoworld in forum R Forum (2004-2007)
      Last Post: 08-01-2006, 05:09 PM
    5. Replies: 9
      Last Post: 02-16-2006, 12:36 PM
