Axle Play
    Results 1 to 5 of 5
    Thread: Axle Play
      Axle Play
      I am chasing another noise in the front end of my 2001 V70XC and noticed that the drivers side axle shaft has a bit of play in it where it connects to the motor. What is excessive play and how would I know if it needs to be replaced? Sometimes when turning sharp to the right it will also make a thunk noise.
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by michaelunderway View Post
      Is it rotational play in the inner tripod joint or up/down play in the transmission output shaft? But, neither is likely to produce a noise while turning. The outer joint would be more likely to produce noise when turning. Has anything else been replaced on the front suspension?
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
      Quote Originally Posted by Exocet View Post
      I guess it would be in and out play where the shaft goes into the transmission? I have replaced the tie rod end links, ball joints and spring seats. It just started the clunking noise after I put my winter tires on.
      SwedeSpeed.com
      Nov 2017
      Southern Tier NY
      What about the strut bearings?
    7. #5
      No I haven't changed the strut bearings. I have tested them by trying to turn the nut on top and making sure it doesn't spin around.
    8. Remove Advertisements
    Similar Threads
    1. Rear end axle play
      By goodyeareagle in forum PV 444 / 544
      Last Post: 08-12-2015, 12:53 PM
    2. Replies: 1
      Last Post: 04-28-2014, 08:50 AM
    3. 05 S40 Axle play noise clunk bad seal splines? NEED HELP
      By RedMenace in forum S40 & V50 (2005-2012)
      Last Post: 02-02-2014, 02:44 PM
    4. Excessive Play in the Axle?
      By joseybird in forum XC90 (2003 - 2014)
      Last Post: 09-10-2003, 09:30 AM
