Forge K24 wastegate
    Results 1 to 4 of 4
      Member
      Sep 2009
      Boston, MA
      Forge K24 wastegate
      BNIB
      $170 shipped
      Sent from my ASUS_Z01RD using Tapatalk
      "...you are the Leonardo DaVinci of Swedespeed!"
      Junior Member TristanScott's Avatar
      Feb 2014
      Milwaukee
      Is this pretty much a go to for hybrid k24s? Do you happen to know?
      Sent from my ONEPLUS A6013 using Tapatalk
      2004 S60R M66 Electric Silver Nordkap
      KW V2s, Kaplhenke Front Strut Mounts with 2.5" springs, PDV Rear Strut Mounts with KW springs, IPD V70R Track Spec Sway Bars, IPD Rear Toe Links, Kaplhenke Delrin Front Subframe Bushings, Powerflex Race Bushings, Snabb Tial Recirc Kit, Snabb Downpipe, IPD Catback, TTV SMF with 06/07 Volvo Clutch, IPD SS Brake Lines, CFE+, UR Front Strut Brace, IPD Poly Top Engine Mount and Torque Mount.
      2004 V70 2.4 NA AW-55 FWD Ruby Red Metallic
      The $900 daily. IPD Poly Subframe Bushing Inserts, Everything Else OEM.
      Member
      Sep 2009
      Boston, MA
      I don't know what hybrid guys do but if the problem is heat at the diaphragm then it would be a good idea.
    5. #4
      Jul 2014
      Would you do 140 shipped by chance?
      Sent from my SM-G965U using Tapatalk
    6. Remove Advertisements
    Similar Threads
    1. S40 / V50 Forge Wastegate Actuator for sale
      By Evolv0 in forum FWD & AWD Parts For Sale
      Last Post: 05-03-2016, 12:37 PM
    2. Replies: 24
      Last Post: 02-27-2016, 11:32 PM
    3. Forge wastegate and extra springs n rods k24
      By Red_Devil in forum FWD & AWD Parts For Sale
      Last Post: 09-12-2014, 09:44 PM
    4. Forge Wastegate actuator - 22lb. spring Goodness
      By heavyiron in forum S70, V70 & V70XC (1998-2000)
      Last Post: 12-15-2009, 11:10 PM
    5. Replies: 0
      Last Post: 09-10-2007, 08:27 PM
