Replace the Steering Column Coupling Shield?
    Results 1 to 11 of 11
      Junior Member mattlach's Avatar
      Jun 2013
      Boston, MA
      Hey,
      I love my V70, but one thing that is driving me absolutely nuts is that the rubber in the coupling shield down near the U-joint on the steering column has gotten old and dried out, and it makes a horrible dry rubber-on-rubber grinding sound when the outside of the U-joint and the inside of the coupling shield rub together as the wheel is turned.
      I have tried lubing it with all kinds of lubes to fix the issue, first with silicone oil, then with silicon grease, and last with Jet Lube. IN some cases it helped for anywhere from a day to two weeks. In some caes it didn't help at all. The awful noise always comes back.
      Here is a view from inside the drivers side footwell:
      And the diagram and parts listing:
      Looks like it should be fairly easy to pop out the old one, and pop in the new one...
      ...expect for the fact that I have to get them off and on to the column
      So, Can I loosen the screws just north of the u-joint and thus separate the column, and get enough space to slip the old shield off, and a new one in? Or would this require more drastic surgery?
      Appreciate any recommendations!
      --Matt
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Theres a bearing in there that has likely seized. Your eon the right track, just disconnect the U joint upper tang and take the pieces out from there.
      2003 V70 T5 - Mystic/Graphite - M56LK - 197k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 291k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 174k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 238k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 212k - Sisters
      Jun 2013
      Boston, MA
      Quote Originally Posted by ScottishBrick View Post
      Oh cool. Thank you. Where is the bearing? Inside the universal joint assembly? Or on the shield side? From just looking at the parts it is not apparent where it would be.
      I'm trying to figure out which parts I should replace for this.
      I found a picture of the universal joint part. Is the bearing inside that round metal colored part so that it spins freely and doesn't rub against the dust shield?
      SwedeSpeed.com
      Jun 2013
      Boston, MA
      Looks like I'd need to loosen the black bolt on top, and then a bolt underneath the dust shield, and that entire U-joint should come out.
      I've never messed with steering before though. Any pitfalls I should be aware of? I'd imagine I'd want to keep the wheels and the steering wheel straight throughout, and maybe even do an alignment after?
      Any other gotchas to look out for?
      Many thanks,
      Matt
    7. #5
      Dec 2014
      Connecticut
      Lock the wheel
    8. #6
      Junior Member kampman's Avatar
      Jan 2013
      Columbus, Ohio
      I think what SB is saying is that there's a bearing inside the rubber boot, which you can see in the pic on Skandix: http://www.skandix.de/en/spare-parts...olumn/1037134/
      The silver section in the middle of the piece you posted rides inside the bearing.
      You should be able to undo the bolt where the column connects to the upper shaft of the U-joint, slide it off, and then pry the donut/boot up over the top of the u-joint. Don't touch the splined part that connects to the steering rack.
      1966 220: dormant project
      1999 S70 #base: 192K
      2000 V70R: 135K
      2006 V50 T5M AWD: 147K
    9. #7
      Jun 2013
      Boston, MA
      Quote Originally Posted by kampman View Post
      Oh, that is interesting.
      I've stuck my finger between the column and the boot when I was troubleshooting and to try to lube it, and there isn't a bearing there on mine. Just smooth rubber.
      I wonder if someone at some point before I owned the car installed a subpar aftermarket rubber boot.
      Thank you for that!
      Do you know how that boot attaches? Does it just press in? Or do I need to remove that plastic ring around the outside in order to get it out?
      Well, the ring is cheap enough. I might just buy it even if I don't need it, just in case it breaks during removal.
    10. #8
      Jun 2013
      Boston, MA
      Lock the wheel
      Appreciate the suggestion!
      How does one do this? Just using the ignition lock, or is there some sort of tool or clamp I should use?
    11. #9
      Dec 2014
      Connecticut
      Quote Originally Posted by mattlach View Post
      Just the ignition lock
    12. #10
      May 2014
      I have had this noise and mine is not the lube or cleaning of the little white plastic split ring in there either.
      I'll be watching this thread.
    13. #11
      Feb 2010
      Wellingbrough ,England
      On my 1998 V70R the bush had sized to the shaft with rust and worn the rubber, and it would not stay in place.I needed a new(second hand)rubber bellows.
      I believe as a service modification Volvo fit the later type with a needle roller bearings in there.
      Saffron V70R 1998 Auto FWD,
      Silver 2006 V70 D5 manual FWD, fixing slowly.
      Blue 2002 V70 D5 manual FWD, striped and gone.
      Champagne 2003 V70 D5 AWD Auto, striped and gone.
    14. Remove Advertisements
    Similar Threads
    1. Replies: 5
      Last Post: 05-30-2017, 10:58 AM
    2. Steering shaft spline count/size info (not splines at steering column)
      By ronin7 in forum Amazon P120, P130 & P220 (1956-1970)
      Last Post: 09-13-2015, 02:08 PM
    3. missing handle to adjust steering column. how hard is this to replace?
      By vspady in forum S70, V70 & V70XC (1998-2000)
      Last Post: 08-26-2012, 09:33 PM
    4. Loose Steering wheel /play in steering column
      By onebadR in forum R Forum (2004-2007)
      Last Post: 03-10-2010, 11:41 AM
    5. Replies: 9
      Last Post: 02-26-2010, 11:48 PM
