Fixing speedometer after wheel size change?
    Results 1 to 11 of 11
      Dec 2015
      What do people do here when switching between winter/summer wheels when they are sized differently? Do you just get used to the wrong speedometer/odometer reading for half the year? Or is this something a shop or dealer can fix?
      If this can be fixed by a shop, any idea which tool/software they use for it?
      Member partridge's Avatar
      Mar 2005
      Maryland
      Quote Originally Posted by whoami View Post
      If you pair the wheel/tire combo properly the difference is negligible.
      I use a calculator like willtheyfit.com
      Just enter in your parameters and you can get the %error. It’s usually not worth bothering about.
      Current:
      Linnéa: 2017 Osmium Grey XC90 T8 R-Design Vision/Climate/Conv/Air/B&W/Booster
      Deceased:
      Inga: 2004 Titanium Gray/Gobi S60R - Navigation, ipd tune, hood vent, rear window spoiler
      Astrid: 2015.5 Sapphire Black/Nubuck XC60 T6 AWD R-Design Platinum BLIS Climate Polestar
      Dec 2015
      Willtheyfit shows it's off by about 3.5mph - which matches the difference I feel when driving.
      SwedeSpeed.com
      Mar 2005
      Maryland
      Wow. What did you switch to?
      Current:
      Deceased:
    7. #5
      Dec 2015
      From 21" Pirelli Verde to 19" Andros w/ 235/55 Blizzaks dm-v2.
      I'll need to double check dimensions on the 21" wheels, but I believe I got them right (275/45).
    8. #6
      Feb 2019
      Long Island NY
      That seems excessive size difference. Wasn’t there closer fit tire size? In any case as far as I know from reading around vida at dealers has a setting for the Speedo adjustment. Not sure if that is available through the 3day subscription.
    9. #7
      Member chillg8r's Avatar
      Jan 2005
      Durham, NC
      I bought larger wheels and tires from my dealer and he told me that they would have to input the change into the computer so the speedo was correct, so its valuable and doable. It didn’t seem to take significant time either.
      ”Adventure may hurt you but monotony will kill you.”
    10. #8
      Dec 2015
      Awesome, that's promising to hear. Will talk to the dealer then. Thanks!
    11. #9
      Feb 2019
      It's not as easy as changing a setting, the dealer has to download and install a new piece of "software". For the 21" wheels, the Part Number is 32270048. I was charged $37.50 for the software, plus 1/2 hour of labor.
      Hers: 2018 XC90 T6 AWD - Momentum - White/Black [OSD May-2018]
      Mine: 2018 Audi A6 2.0T Quattro - Premium Plus - White/Brown
      Also Mine: 1995 Land Rover Defender 90 - Soft Top - White/Black
    12. #10
      Nov 2015
      South Dakota
      Are you sure the original size isn't 275/40R21?
      Your snow tire size 235/55/R19 is a standard size for the Momentum. Both of these tire sizes are standard and only 1.7% different in circumference, so you shouldn't need to make any speedometer adjustments.
      2016 XC90 T6 Momentum Plus, Vision, Climate, CarPlay, Invisihitch
    13. #11
      Feb 2019
      Quote Originally Posted by SDspeed View Post
      I was told the software has more to do with the power steering parameters of switching from 235 to 275mm wide tires than the speedometer accuracy (although it adjusts that, too)
    14. Remove Advertisements
    Similar Threads
    1. Replies: 17
      Last Post: 09-14-2017, 02:19 PM
    2. Slight idle drop even after fixing most common problems
      By Legtayor in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 03-03-2017, 11:00 AM
    3. Problems after "fixing" trans solenoids
      By AGUYNAMEDFRE in forum S60 (2001-2010)
      Last Post: 05-17-2015, 08:42 PM
    4. Way too much boost after fixing a leak
      By andersh67 in forum R Forum (2004-2007)
      Last Post: 08-04-2013, 12:49 PM
    5. M40 to M41 Speedometer cable thread size.
      By bobbyz in forum Amazon P120, P130 & P220 (1956-1970)
      Last Post: 07-31-2013, 08:04 AM
