How to remove indicator lenses
    Results 1 to 3 of 3
      Oct 2019
      I'm converting my 445 from 6v to 12v, so I need to change the bulbs in my front indicators. They are the older, flatter, harder to replace style. Am I right to think the lenses are just held by the rubber ring of the light body?
      Do I just pull them off, or is there a clip or something that needs to be removed first?
      Dec 2012
      portland or
      Yep: just the rubber holds in in place. First, remove the chrome ring by gently prying the rubber away from the ring's outside perimeter. Second, remove the glass lens the same way.
      If you break the lens (which really shouldn't happen), replacements are plentiful and cheap: Lucas L488. Not a rare Volvo specific part.
      Oct 2019
      Thanks very much. Good to know the lenses are available.
    Similar Threads
    1. Replies: 33
      Last Post: 07-03-2013, 10:28 AM
    2. Reseting Service indicator indicator message using VIDA
      By doug-s60r in forum OBD, CANBUS & Engine Management
      Last Post: 03-26-2013, 01:12 PM
    3. e-code lenses, clear corners, 35w HIDs, sidemarker lenses
      By Wagoneer in forum FWD & AWD Parts For Sale
      Last Post: 03-04-2009, 09:48 PM
    4. Service Indicator Light - Message display - "Position Indicator - Bulb Failure"
      By timyerby in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 05-04-2004, 08:53 PM
