Rear dash cam wiring/tailgate help
    Results 1 to 5 of 5
      May 2014
      NYC
      Hi All,
      Recently acquired 2019 XC60 RD after the 2015 RD was totaled and I am trying to install dash cam in the rear. On my 2015 i had no major issues installing it but this 2019 is kicking my ass. I cant figure out how to get the rear trunk paneling off and disconnect the wire loom grommet between the rear hatch and the body to snake my wires in.
      Has anyone had experience removing it? I am trying not to break it and be as gentle as possible but the damn thing wont budge.
      Any help or tips or trick will be appreciated.
      2019 XC60 R-Design - work in progress
      2015 XC60 R-Design - Totaled
      2016 VW GTI - modified
      2005 G35 -modified
      Junior Member PSamy's Avatar
      Sep 2019
      Southern CT
      Found few threads which are talking about rear camera wiring, may not be the same as XC60, see if these of any help.
      https://forums.swedespeed.com/showth...light=dash+cam
      https://forums.swedespeed.com/showth...-Cam-Installed
      https://forums.swedespeed.com/showth...=1#post6930217
      2019 XC60 - T6 - R-Design - Polestar - Air Suspension W/Four-C Chassis - Advance - Crystal White Pearl - 21" R-Design Wheels
      Oct 2019
      Yeah, I had the same problem. I ended up doing the ugly route and just hide the cable along the weather strip. Just like one of the posts = https://i.imgur.com/VjZwAMTl.jpg
      These videos I found helpful for: 1. A pillar 2. Access the 2019 passenger fuse box 3. hardwiring the dash cam
      This video the guy actually shows you how he accessed the fuse box, (skip the video to where you want to see, it can get boring watching the entire video) https://youtu.be/u7hX_Iwzfho
      This video explains the basics of hardwiring the dash cam very clearly including how the fuse tap orientation goes, how to locate positive and negative https://youtu.be/C4CkStK45io
      SwedeSpeed.com
      May 2014
      NYC
      Got around to getting it done today. Thanks for the help above guys. Still didn't finish as I didn't have the correct micro fuse taps. Ordered some and will complete the job this week.
      The hardest part was figuring out how to undo the wire grommet between trunk and body but I figured it out.
      Will try and post some pics later maybe a tutorial for others who want to tackle the project.
      I'll have to do some custom modification to intelisafe plastic housing to mount the camera. Trying to make my particular camera (ThinkWare u1000) be as oem mounted as possible.
      2005 G35 -modified
    7. #5
      Oct 2019
      Quote Originally Posted by LVE2DRV View Post
      Awesome, I'd like to see that. Keep us updated!
    8. Remove Advertisements
    Similar Threads
    1. Dual Dash cam wiring advice needed
      By mdkf in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 10-28-2018, 06:21 PM
    2. New Dash Cam/Hard wiring
      By Strawbewwy in forum XC60 (SPA: 2018- )
      Last Post: 04-16-2018, 05:05 PM
    3. Access to rear of exhaust cam (to lock the cam)?
      By iRenaissanceMan in forum XC90 (2003 - 2014)
      Last Post: 02-03-2016, 12:16 AM
    4. Replies: 3
      Last Post: 10-21-2014, 07:57 PM
    5. Replies: 8
      Last Post: 06-05-2013, 06:32 PM
