Anyone Know
    Results 1 to 5 of 5
    Thread: Anyone Know
      Member EngTech's Avatar
      Jan 2007
      Knight's of the Round Table - TN
      Anyone Know
      I was Looking at Difference in Turbo Wheels & Turbo's ~ as I'm Porting a K04 and Blue Printing it Match T5 Head , Further I'll be Porting the Turbo Housings also ..
      Investigating these Turbo's from B5254T3 up through B5254T7 to see If there were any Differences , but when I got to T5 V60 2015 - all Info seem to Drop Out
      Even Thou it's T5 is 5 Cly with same Head Gasket - Rated @ 250 /266 T5 Turbo Gasket is the Same . so If anyone has any Stuff on these 5 cly. V60 T5 Turbo , Appreciate it , Thanks
      Dan
      I found Billet Turbo Wheel it's about 15 years into Future K04-2280 Billet .. so Hoping to Turn it into PS412 "Puma Speed 412" type set up - It should be Tune-able Even Higher then
      310hp / 330 Tq. but Stage 2R is Nice Comfortable Smoother Tune vs all out Race . .
      ** V50 AWD - Handling & Performance Tweaks = New Stance / VW CC - Handling Tweaks - Testing & Porting - Intake Mods
      A Garden Gate will Last You a Life Time . http://s261.photobucket.com/user/Eng...0Trim%20%20etc
      Jan 2007
      Certainly there are Better Turbo Designs , but Auto Manufactures are just to Cheap to Implement Unless _ Economically Forced to do so do to Fines for Not Meeting CAFE STD.'s
      1. Such as Lighter & Longer Lasting Brakes Components so as to Not Pollute all water from side of the Road .. while wasting Massive amounts of Energy to Keep Building Replacements ..
      2. Light Wheels
      3. Dual Scroll Turbo's
      4. Variable Scroll Turbo's
      5. Direct Injection Motors - that doesn't Load Up Valves with Carbon Deposited - Like VW's and some Others ~ Pistons with Built in Cooling & Progressive Injection Timing ~ Have Cured most 98% of that . .
      Back to the Turbo's , so Porting P1 Turbo Manifold is big Help along with Ceramic Thermal Coatings and Better Designed Billet Wheels - These 3 Items Certainly Going to Pick Up Eff% and HP . .
      These Older Turbo's Now with 180K on them are starting to be Really Loaded Up with Carbon or 80% Worn Out . .
      Just Thought with all the C30 AWD's and Other Improvements & Mods ~ That someone would be Fitting T5 from 2015 Model with the 8 Speed Trans ~ Certainly must be enough Wrecks By Now . .
      Thanks Dan
      Keep Eye Out for "DL555" Coming to Swede-speed . .
      Taller Longer Billet Compressor ~ does something along these Lines ~
      https://youtu.be/PsZ1Gqs0d4w
      Jan 2007
      Here some Volvo Cross Ref. for the T5 Turbo : This Newer T5 : 2012 _ 2015 is Same Turbo - sure seems like 12 years down the road this Newer T5 Motor would have Better Wheels inside it ..
      Volvo C30 2.5l 5 cylinder Turbo 2007, 2008, 2009, 2010, 2011, 2012, 2013
      Volvo C70 2.5l 5 cylinder Turbo 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013
      Volvo S60 2.5l 5 cylinder Turbo 2011, 2012, 2013, 2014, 2015, 2016
      Volvo S60 Cross Country 2.5l 5 cylinder Turbo 2016
      Volvo S60 Inscription 2.5l 5 cylinder Turbo 2016
      Volvo V50 2.5l 5 cylinder Turbo 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
      Volvo V60 2.5l 5 cylinder Turbo 2014, 2015, 2016
      Volvo V60 Cross Country 2.5l 5 cylinder Turbo 2015, 2016
      Volvo XC60 2.5l 5 cylinder Turbo 2015, 2016
      Volvo XC70 2.5l 5 cylinder Turbo 2016
      SwedeSpeed.com
      Jan 2007
      Another Thing Noted ~ Is the Addition of Lower Heat Shield so there's a Upper & Lower - Combined ~ this would Shield the Block Better from what I remember on V50 & S40 Design
      May have slightly Larger Shield , but was all on Top Turbo & Manifold Area . .
      I don't see 2 shields on C30 ? ( Hence More Block Protection from Heat Soak ) ?
      It stated this "extra" I'm calling it as I don't recall it being on My V50 is also being used on 3.0L , so I'm I looking at this Correctly - ?
      The C30 like s40 & V50 - didn't have ? or did have this Extra Shield - on C30 ?
      https://www.volvoswag.com/oem-parts/volvo-heat-shield-31380187?c=bT0xJmw9MiZuPVJlY29tbWVuZGVkIFByb2R1Y3R zJms9MQ%3D%3D
    7. #5
      Jan 2007
      Newer Style Heat Shield - Looks to Allow More Heat to Leave going straight Up or Outward - where as the Heat Shield Below ie. Older Designed Heat Shield stock Unit is a lot more Encompassing . .
      I'm wondering If anyone with Head Gasket Issues ~ has been Running extra Hard or Extra Hot states , then Fast Shut Downs . . that said Newer one looks lighter and easy to Manufacture , but the Addition of Second Shield
      States Something ~ Read Into it as ~ You may . .
      OK Found It - this Heat Shield I Recall ~ https://usparts.volvocars.com/p/Volv.../30713262.html
    8. Remove Advertisements
    Similar Threads
    1. Palmer Platinum LE Snowboard: If you know this board you know it is AMAZING.
      By carreragt7 in forum Non-Car Related Classifieds
      Last Post: 05-25-2009, 10:34 AM
    2. Chop Request... I know, I know...
      By Revolve40 in forum S40 & V50 (2005-2012)
      Last Post: 05-01-2009, 12:10 PM
    3. Changes for MY 2011? (I know, I know...)
      By rfkuehn in forum XC60 (2010 - 2017)
      Last Post: 03-12-2009, 01:33 PM
    4. Replies: 0
      Last Post: 06-26-2008, 09:21 PM
