Mazda Lowering Springs
    Results 1 to 22 of 22
      Dec 2019
      New thread since subject has changed from last one.
      What Mazda lowering springs should I go with for a v50? I'm looking to drop the car for cheap as its just a cheap beater that I want to look good. I've read that mazda 3 springs will work for v50s and s40s but no one says what year so I'm just a little nervous. If someone could tell me what springs will work and will look good that be great. Thanks for the help everyone.
      Member AutoGeek's Avatar
      Jan 2008
      MD, Howard Co.
      There are lowering specifically for the S40/V50. Eibach, H&R, Elevate and Volvo all offer lowering springs. Them there are various coil-overs available.
      2005 V50 T5 FWD M66 Passion Red (Radio Flyer) Bilstein HD, ECU spacer, Snabb Turbo Pipe
      1998 V70 NA - Sold, 2002 S40 1.9T - R.I.P., 2005 V50 T5 - RIP
      Remember kids, Speed doesn't kill ... impact does!
      Dec 2019
      Yes but from what I've gathered Mazda springs will work and seem to be half the cost.
      I'm just trying to get rid of the 3 inch gap I have in the rear for cheap. I'm not going to be doing autocross or cross country trips. Just want to have a car I like to stare at as I walk into work that's 15min from home. If I can accomplish that with Mazda springs for 100 bucks then that's where I want to go.
      SwedeSpeed.com
      Mar 2019
      cape town
      Just throwing it out there...i have 17inch springs that is brand new...well it was was replaced with 18inch springs when S40 T5 was purchased new. Make a decent offer.
      Sent from my SM-G960F using Tapatalk
    7. #5
      Member Veefifty T5AWD's Avatar
      Feb 2009
      Lakes Region NH
      FWIW, I installed C30 rear springs on my V50 T5 AWD - made a huge difference in the appearance!
      Logan
      2015 S60 T6 AWD R-Design Polestar
      2008 S40 2.4i - hers
      Former:
      2013 C30 Polestar Limited Edition #87/250 | 2005 V50 T5 AWD | 1995 Yellow 850 T5-R
    8. #6
      Dec 2019
      Quote Originally Posted by fsp15923 View Post
      17in springs? Or did you mean rims? My already has the factory 17s if that's what you meant.
      Quote Originally Posted by Veefifty T5AWD View Post
      That does look really good but would mine be different because I'm fwd?
    9. #7
      Junior Member mechanical_freak's Avatar
      Mar 2016
      Lincoln, Ne, USA
      I have a 2010 S40, still P1 platform, and i finally decided to go with a set of the Eibach springs, i went to eibachs website and they had the spring set listed at some hellacious discount i paid 135 for the kit was pretty sure it had to be an error on the pricing but i got charged what it said, i cant even find the springs on their website now however these coupled with some cheap struts / shocks and the car still rights like stock and sits about 1.5 inch lower i also took the opportunity to replace any worn bushings / mounts and sway bar links and all in total i paid about $550 for shocks/struts, springs, mounts, links
    10. #8
      Dec 2019
      Quote Originally Posted by mechanical_freak View Post
      I just found some Eibach lowering springs for an awd v50 for around that, are they the same for a fwd v50 thought?
      *edit* From what I just read it sounds like I'm good to go, unless someone says otherwise I'm going to order those, worse case scenario I'll return them if I learn they won't work after they ship.
    11. #9
      Jan 2018
      The AWD will fit may be a bit stiff in the back as they are for the higher weight of the awd
    12. #10
      Dec 2019
      That's what I saw but someone else in the same forum post sayed the weight difference is only 30 pounds. Either way if that's the only thing im happy with it.
    13. #11
      Mar 2019
      cape town
      Quote Originally Posted by LemonyGUy View Post
      Yes it came off a S40 with 17 inch rims. What you paying for the ones you ordered?
    14. #12
      Dec 2019
      I'm lost, what do you mean 17 and 18 inch springs? Are you just measure the overall height or something?
    15. #13
      Mar 2019
      cape town
      For those respective size wheels
    16. #14
      Dec 2019
      Well I'm back, the place i ordered my eibach springs from (autoanything) says they can't get me my parts as they are discontinued. So I'm back on the hunt, so what year Mazda springs fit so i can get a set order off eBay for less than the 200 that Volvo ones cost.
    17. #15
      I used 2006 Mazda 3/6 in my 2006 S40 for the fronts. I haven't messed with the rears yet.
      Curb weight between the Mazda 6 and the S40 AWD was only about 150lbs difference (Volvo heavier), however yours is an additional 150lbs on top of that since it's a V50.
      1996 HD Electra Glide - Big Bertha - 10:1 Wisecos; EV13 Cam: Ultima Digital Ignition; Buell Head Conversion; E85 Carb Tuned;
    18. #16
      Dec 2019
      Are Mazda 3 and 6 not different? I don't know the cars but i assumed they had some difference, even if it's just weight i should go with the heavier one then.
    19. #17
      The Mazda 5 looks like a Honda Fit. The Mazda 3 is a sedan like ours. They both use the same shocks and quickstruts in the fronts at least (2006 Models). I figured if it was able to be useful for both of them despite their weight difference, the additional 150lbs to go on a volvo s40 awd model wouldn't be a big woop. Putting these on the V50 would mean a 300lb weight difference which might make them a little less responsive when driving, so that's just soemthing to be mindful of.
    20. #18
      Member LizardOfBodom's Avatar
      Aug 2016
      Rainy Island (aka Ireland)
      Quote Originally Posted by avenger09123 View Post
      The Mazda 6 looks like a Honda Fit. The Mazda 3 is a sedan like ours. ....
      Unless you have much different names in US, I think u confused some of those:
      Mazda 6 - top, Honda Fit - middle - Mazda 3 bottom
      Our cars uses most of Mazda3 parts as Mazda 3 and Ford Focus used similar platform, mazda3 was available as sedan or hatch but in US u probably got only sedans?
      Mazda 6 is much bigger and to my knowledge most parts WONT fit, unless you are only talking about performance MPS6 model, maybe they used diffrerent parts similar to MPS3 but those are so rare here that I am not very familiar with them.
      Titanium Grey 2005 V50, T5AWD, M66, Stage 1 Hilton tune<-Click me
      E-Focus Torque mount, E-46 bi-xenon retrofit (see the PDF for pictures and full story) , de-nanny mod, Brembo discs+ATE ceramic pads
    21. #19
      Jul 2014
      Boston area
      I think it was supposed to be the Mazda 5:
      I know the Mazda 3 and 5 share many suspension components with our P1 Volvos.
      2010 XC70 T6 148k; 2006 S40 T5 AWD M66 205k; 2004 XC70 275k; 1998 V70 288k (sold); 1970 Dodge Super Bee 383 Magnum 122k
    22. #20
      Member jondevieonS40's Avatar
      Oct 2011
      ABQ New Mexico
      The more info you get, the more confused you will be - dont even get started on the ford parts... lmao
      2008 S40 T5 AWD ("Shadow") |ELEVATE 3" Intake, 2.5" Charge Pipe, Intercooler, Torque Mount, ECU Mount, TCV, Turbosmart CBV, Turbosmart Actuator, stage 3 APC Tune, 3 Stickers (5HP)ea||ClockWorkCalibrations Custom 3" Exhaust||EuroSportTuning 3" downpipe.||CF Cone Filter||De-Badged||custom Mesh Grill||Intercooler Cut out||Porsche 911 Throttle body upgrade||18" Enkie PDC Wheels wrapped in 225/45/18 Sentury UHP||M3 Spoiler|| 8k Morimoto HID Kit|| White LED Fog,City,trunk light|"embody God, then go crazy"
    23. #21
      Dang, my bad...he's right, too many late nights and early mornings. I meant Mazda 5 and Mazda 3. Fixed in the original post.
    24. #22
      Apr 2018
      It looks nice, it's 225/45r18? Do You have the part number for c30 springs?
    25. Remove Advertisements
    Similar Threads
    1. Lowering FWD S40 on Mazda 3 Springs...will these work?
      By narco944 in forum S40 & V50 (2005-2012)
      Last Post: 08-18-2014, 05:54 PM
    2. Volvo S40 Lowering Springs ( Sprint Mazda 3 )
      By Talamant3z in forum FWD & AWD Parts For Sale
      Last Post: 02-05-2014, 02:09 PM
    3. AWD S60 Eibach lowering springs (S60R lowering springs)
      By Dozzy in forum FWD & AWD Parts For Sale
      Last Post: 01-02-2014, 10:55 PM
    4. Lowering Options: Cheap Mazda Springs, Spring Claps, etc?
      By chromecarz00 in forum S40 & V50 (2005-2012)
      Last Post: 08-10-2011, 12:05 PM
    5. S40 on mazda lowering springs
      By Talamant3z in forum S40 & V50 (2005-2012)
      Last Post: 08-09-2011, 01:00 AM
