Advantages of 0W20 over 5W30? - Page 6
    Page 6 of 6 FirstFirst ... 2 3 4 5 6
    Results 176 to 190 of 190
    1. #176
      Junior Member Ultrarunner511's Avatar
      Jul 2017
      Arizona
      Quote Originally Posted by stick_shift View Post
      Do you have a link to those 'sources'?
      Without calling out individuals who gave me that info, no, I don't.
      Sent from my SM-G975U using Tapatalk
      Jul 2017
      Arizona
      If you search hard enough on this forum, ask enough questions, use Google, and ask the right people, you'll find the same answer.
    4. #178
      Sep 2016
      Austin, TX
      Quote Originally Posted by Ultrarunner511 View Post
      Like this?
      https://forums.vwvortex.com/showthre...135&viewfull=1
      That still says nothing about this oil meeting the Volvo spec. How does it matter that two Castrols "are the same"? We need something available in the USA that meets our spec.
      2018 Onyx Black T6 Momentum: Amber, 20" wheels
      DIY Oil Change:
      https://forums.swedespeed.com/showth...ange-with-pics
      DIY Brake Pads:
      https://forums.swedespeed.com/showth...ment-with-pics
      SwedeSpeed.com
      Member inteller's Avatar
      Aug 2009
      Tulsa, OK
      Per sources from Volvo and Castrol, the Edge and Edge Professional are exactly the same, with the exception of the leak detection dye which is in the Professional.
      Wtf dude....did you not even read the specs I posted? Their own MDS sheets show they are different.
      Sent from my SM-G973U1 using Tapatalk
      2016 Bright Silver Metallic XC90 T8 Inscription, everything
      2015.5 Rebel Blue S60 Polestar 18/40
      2006 Passion Red S60R
      Packages: Premium, Climate Options: Sport Appearance Package, 18" Pegs, 6Spd Geartronic, Navigation
      Accessories: Sunglasses holder, Sirius Radio, Volvo Digital Jukebox Mods:SS DEM Mod
      "Just say no to LV VIN codes"
    7. #180
      Just put a high quality @&)*ing oil in it and drop the oil **** debate already. If you want extra then use additives, no cat ZDDP, with cat ,stick to Lucas or Amsoil, super low temps use a lower weight, constant high temps use heavy weight, racing....use what gets you results: that oil is gonna be change religiously, whatever that is.
    8. #181
      Aug 2009
      Tulsa, OK
      "High quality oil" isn't going to win a warranty debate with Volvo with the drive-e ****ter starts consuming oil
    9. #182
      Quote Originally Posted by inteller View Post
      Precisely. “If” warranty is the concern put in what Volvo recommends. If it seams shady, document it every time. Don’t gamble..why ask.. Asking what, when, why , where, type and all all the crazy numbers being thrown around is absurd. If the oil doesn’t perform the way you want, warranty issues aside, then switch. I change oil often, summer 1500-2000 miles or less depending on the dipstick.
    10. #183
      Jul 2017
      Arizona
      Yep, I read the specs and saw the differences. I'm guessing Volvo reps and Castrol are incorrect then .
    11. #184
      Sep 2016
      Austin, TX
      Quote Originally Posted by paradoxicallymodified View Post
      Are you doing UOA to determine that performance?
      DIY Oil Change:
      DIY Brake Pads:
    12. #185
      Yeah, with my slide rule and hydrogrammometery meter. No silly. With visuals. Unlike most I check the oil at every fill up. Color and odor. Change as needed. Sometimes sooner-sometimes even sooner. Lol.
    13. #186
      Aug 2009
      Tulsa, OK
      Wow you must have a great nose, can you smell cancer too?
    14. #187
      No No No, I leave that to the pups. I know my limitations. Lol
    15. #188
      Come on guys. If we all spent all damn day wondering about every single aspect of oil we’d never be out driving and using said oil. Which would make this conversation even more irrelevant. As I said before, if it’s warranty that is the issue then play the game. If you own it (car) then stick to high quality companies (no mlms or snake oil) and put in what suits your climate or driving style. If your climate swings drastically then use the 0 weight. (Which is probably why Volvo Switched in the first place A convenient one size fits all.) this whole discussion reminds me of another on here recently: what’s the best coolant. The “best” is water with water wetter agents. Tests show it (water) is the best coolant. But obviously straight water freezes so enter glycol and other (preservatives) since the manufacturer’s know that the average (look for Joe) isn’t gonna bother with replacing said fluid when they should. It’s just like the human body, no maintenance, no longevity. Pretty simply really.
    16. #189
      Feb 2019
      Long Island NY
      Just to throw this into the mix. 2010 Lexus rx350 0w20 for the past 187000 miles ,redline every morning no warm up. Still running smooth. Drive the car guys like the post above me said.
    17. #190
      Nov 2019
      Quote Originally Posted by rkohou View Post
      Having owned Toyota products, i would say there is a difference between them and other car makers I have owned in terms of quality/reliability. My Volvo experience has been limited to only a few months now, therefore I am not sure, although hopeful, that Volvo can achieve a comparable reliable performance.
    18. Remove Advertisements
    Similar Threads
    1. 2019+ models require 0W20 oil
      By gunshow in forum S60 & V60, V60CC (SPA: 2019- )
      Last Post: 11-21-2019, 01:13 PM
    2. 5W30 vs 0W20 at oil change
      By nh_ets in forum XC90 (SPA: 2016 - )
      Last Post: 10-15-2017, 10:39 AM
    3. Advantages of 06' 2.5T over 04',05'??
      By yenga80 in forum XC90 (2003 - 2014)
      Last Post: 05-23-2013, 10:32 PM
    4. p0101 over and over and over and over and over and over...
      By MrUncanny in forum R Forum (2004-2007)
      Last Post: 03-11-2013, 01:23 PM
    5. Advantages of 18s over 17s?
      By ChuckV in forum R Forum (2004-2007)
      Last Post: 09-29-2003, 04:36 AM
