Use iPhone's cellular connection over USB?
    Results 1 to 6 of 6
      I can get my XC40 to use my iPhone's data over either Bluetooth or Wi-Fi, no problem -- my carrier supports tethering. Can't figure out how to use data if it's plugged into the top USB port. Is that even possible?
      Junior Member kevinG's Avatar
      Jul 2003
      Northern California
      Do you have an iPhone? The top USB port with the white frame supports Apple Car Play. With Car Play you can use all kind of media apps on the iPhone like iTunes, Spotify, Waze, iMessage, phone, and others.
      https://www.volvocars.com/en-eg/supp...e-via-usb-port
      It might work with Android too. Not sure.
      2020 XC40 R Design T5 Polestar, bursting blue, July 2019
      2015 V60 T5, crystal pearl, platinum/tech/BLIS, July 2015
      2012 XC60 R Design, electric silver, off-black, platinum/climate/tech/BLIS, OSD in Nov 2011
      2004 XC90 2.5T, silver, OSD in Oct 2003
      Jul 2003
      Northern California
      The first time using Car Play, you need to swipe right in the screen and enable it. The details are in the link above. Car Play is awesome
      SwedeSpeed.com
      The question isn't about using CarPlay. It's how to get the various Sensus apps to use the iPhone's data over USB, instead of Bluetooth or Wi-Fi.
    7. #5
      Junior Member RootDKJ's Avatar
      Jul 2010
      North Jersey
      I can not find anything that supports Sensus being able to use an iPhone hotspot via USB. WiFi and Bluetooth tethering works great.
      2019 Bursting Blue XC60 R-Design T8
      | 21" Wheels | Exterior Style Kit | Advanced | 4C Air | B & W | CPO 10yr/Unlimited |
      2010 Maple Red XC60 T6 retired at 173,375 miles
    8. #6
      Sep 2019
      So Cal, USA
      OP, I'm not sure what your concern is with the "top port". Both can supply power to your iPhone, only the one with a white boarder will work with CarPlay. The USB ports don't have anything to do with data flow to Sensus if you're not using hardwired CarPlay. Without CarPlay, data access (along with voice) becomes available to Sensus and related apps only wirelessly like other vehicles I've owned, once your car has Bluetooth or WiFi connectivity to your iPhone. I'm not aware of any iPhone ability to connect generic data over its hardware lightning/USB port to something like Sensus, except for what Volvo implemented with CarPlay.
      If you are trying to provide access to your iPhone "data plan" to other devices in the car, you can do that by defining a Personal Hotspot on your iPhone, and then just giving those WiFi credentials to other devices that connect to your iPhone directly. I don't see any reason to use the car's tethering option (if you even can) unless you have a separate data plan using the car's SIM (instead of your phone's data plan.)
      You likely need to explain more precisely what you're really trying to do with "data" for us to assist, as I think we may be going down a rabbit hole with all the possible permutations or getting hung up in semantics or technicalities. Give us a usage case and that may help get us moving along.
      Bert
      Present: ‘20 XC60 T8 Inscription
      Past: ‘15 Tesla S90D; ‘14 SLK250; '13 RX450h; ‘09 335i; ‘06 RX400h; ‘02 SC430; ‘99 RX300; ‘95 SC300; ‘91 Legend...
    9. Remove Advertisements
    Similar Threads
    1. SELL: iPhone 5 32GB, iphone 5c 32gGB, iphone 5s 32GB & Galaxy S4
      By lincon07 in forum Miscellaneous Classifieds
      Last Post: 09-23-2013, 08:07 PM
    2. p0101 over and over and over and over and over and over...
      By MrUncanny in forum R Forum (2004-2007)
      Last Post: 03-11-2013, 02:23 PM
    3. Hands-free Cellular Kit
      By bobp01 in forum Car Audio, Video & Mobile Electronics Forum
      Last Post: 08-09-2004, 02:04 AM
    4. Cellular antenna is already prewired in roof bay??
      By gmark2000 in forum XC90 (2003 - 2014)
      Last Post: 05-29-2003, 01:40 PM
